Question about Combi Centre DX - Mango
Baxie 80e hi' im having a problem with my hot water, it only works when the heatings on, and not on its own
    Problem Solver:
  • 5 Answers
The usual problem with the hot water fault you have is that the domestic hot water diaphragm needs replacing,they usually last 2 to 3 years, if you haven't had the boiler serviced on a regular yearly basis then you will need it serviced and the fault repaired by a corgi registered engineer.
Posted on Mar 04, 2009
My Baxi Combi 80e boiler turns the heating on randomly. With the wall thermostat turned down and even with the boil switched to hot water only the heating still fires up when unwanted.
If the thermostat wire run passes anywhere through, beside or inside any metal surfaces and the wires touch any of the metal its the same as if you turn the stat to on. I've seen this a few times. Easiet way to detect it, if its inside the house is at night in the dark. Look around when its doing this you may see the small spark when it goes on. Otherwise you will need to inspect the entire run from the stat to the untis, etc.
Jun 23, 2014 | Heating & Cooling
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
No hot water...can any1 help i have a baxi combi 80e
check daiphragm, or micro switch best of luck
Oct 12, 2009 | Water Heaters
Water gets hot then turns cold and runs cold then hot again
Secondary heat exchanger is blocked on sealed system side.
Remove and de-scale heat exchanger or fit new one.
Feb 04, 2009 | Combi Centre DX - Mango
I need a protherm 80e manual, any idea where I can download one from? The baxi site does not do support manual downloads. :(
This is the manual for 80E. It isn't a manual for the 80e, it's a manual for the 80E, dunno if they are the same or not.
http://www.protherm.cz/upload/1117176168.pdf
If that's is not it, you can browse here =>
http://www.protherm.cz/component.php?cocode=download&dcid=4
Dec 30, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Baxi combi boiler 80e safty thermostat light on
baxi boiler relief valve blows off when heat is turned on when hot water is working it is fine
Oct 15, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Baxi Combi 80e
i need to know boiler specifics- make and model but sounds like either the air pressure switch seized or the main printed circuit board, if the boiler has an overheat thermostat please ensure that the little red button hasnt popped out because this will prvent the boiler firing up- refer to the manufacturers instructions for location of the o/heat stat
May 05, 2008 | Combi Centre DX - Mango
Combi Centre DX - Mango Logo
242 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
