Question about Onkyo HT-S5100 Theater System
Sounds is lower than it should be, possible short.
We have our sound system hooked up through the cable reciever. We are using the white and red out with the coaxial hookup (orange) to the satellite/cable reciever in on the Onkio unit (white and red) and hooked the coaxial cable through the coaxial 2 input on the Onkio unit. I have set the reciever to cable/satellite input and made sure to set our input to coaxial two on the front of the unit. The sound is very weak and all the speakers are hooked up correctly. Once we hit 50 on the volume level the system shuts down. I assume it's a short but I can't figure out where.
    Problem Solver:
  • 10 Answers
Having read the problem report two or three times, it appears that you're running ~three~ cables from your cable receiver to the home theater system - orange, and red&white.
Often, when you can hear a low-level signal on an input, it's due to 'leakage' from another input, and it's my hunch that the cable receiver is sending audio through the red and white (analogue) connections, which you've plugged to the main sat/cable receiver inputs.
To confirm this, I'd be interested to know if, when you unplug the red and white connectors from the back of the Onkyo, the quiet signal completely disappears.
If that's the case, I would suggest either going into the cable receiver's cofiguration to see if 'digital audio out' is set (if such is possible) or switching the input to 'cable/satellite'...
Hope this brings you closer to the root of the problem!
Posted on Feb 07, 2009
Dont know how to connect tv to reciever so sound go threw surround sound reciever
Well depending on what kind of tv or reviecer you have ,,,if you using standard rca jacks,,red,yellow,white,,,,the hook to reciever to tv ,,or availble input,,should be a place on the tv that just has the red and white by itself ,,hook there,,but tru surround sound is digital,,either a optical cable or hdmi,,depending on your gear,,but tv doeant run surround ,,really,,but dvd,,or blu ray like that does,,k good luck,,
Nov 20, 2010 | LG Televison & Video
I want to hook -up my audio from from my flat screen thur my samsung surrond sound!
Use an HDMI cable from your surround sounds output to your t.v.s input or use a three wire red,white,andyellow r.c.a. cable from surround out to t.v. in.
Sep 18, 2009 | Samsung 500w Rrss Rear Reflecting Surround...
How to hook up my 32" vizio lcd hdtv to my sanyo home theater
If your audio system doesn't have optical inputs you're going to have to use RCA (red and white) jacks.
I would suggest upgrading to a system in the future that does have optical inputs if at all possible. Excellent sound.
Jun 22, 2009 | Vizio VW32L 32 in. LCD HDTV
How to hook up wii to surround sound
Put all the wires to the tv. Now you need another A\V cable (yellow, red, white) only use red and white from, audio out on tv to audio in on surround system and set it to TV. OR Put the red and white from Wii to surround system and the yellow to the tv. this way you have to use surround to hear it. The other way you can use the tv or both. The first way is ideal if you have an extra cable.
Mar 15, 2009 | Nintendo Wii Console
Hook up Cox Dig CBL Box to receiver and TV for home theater
The easiest way to proceed is by using RCA cables (the red, white, yellow) to connect the cable box.
Jan 02, 2009 | Pioneer HTD-510 System
Just hooked up Coax cable; now talking is barely audible
is the center speaker turned up in the reciever speaker settings? each speaker can be adjusted to a level that is higher or lower or all the same as the rest. also is the dolby digital turned on in the reciever settings? and changing the surround sound pre set sounds can also improve the type of audio you are listening to in 6.1 surround sound
Dec 31, 2008 | Sony STR-DE597 Receiver
Audio from tv
It sounds like you have the red,white rca cables hooked from the back of the tv to the red,white input on the stereo or the same connection from you hd sat box or hd cablebox. In order to get the same sound quality from tv service as you do on dvd is to run a fiber optic cable or digital coax audio cable from you hd sat box or hd cablebox to your stereo which means no red,white rca cables at all, take them out. Also once you do that you must be on a hd channel to get equal sound quality of a dvd movie. I know on some hd cable or hd sat boxes you have to go in and set them up to dolby digital as well after you hook it up the way I was explaining. Try this and I hope this is helpful.
Nov 09, 2008 | Koss KS4192 System
Help with AG-D9320
These recievers are prime for running surround sound through you TV. It all depends on your TV service, Now if you have a cable box from Dish network, this is the easiest in the world, all you need to look for is an output labeled "OPTICAL OUT". It's a small port with probably a small glowing red light coming out of it. You'll need to buy and optical cable and plug it in there, and then run the other end to the optical input of your surround sound reciever, and then assign a video input to that digital audio signal. It's the best audio you can get by far.
Now if you down't have that, it is still very easy. Find you reciever look for a video input and plug an audio cable in(Red and White cable). Plug the other end into your TV's audio output, a red and white output that is probably labeled audio out, plug that in, switch TV to whatever you are viewing, turn on the reciever to whichever input you assigned and there you go.
If your TV doesn't have an audio output, then you need to go to your cable or sattleite box, and find the audio output, the R/W(Red & white), and run that out to your reciever, the sound won't come through the tv unless you run a second audio out from the reciever into you tv's audio input on the same signal your picture is coming from.
I hope that helps.
Jan 07, 2008 | Teac AG-D9320 Receiver
WIRE ELIMNATION
For the TV:
There are a few possibilities.
1)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the TV Audio OUTPUT to the "Audio In/TV" portion of the HTS (NOTE: Many TV's do not have an Audio OUTPUT).
2)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the Audio OUTPUT of your cable or satellite box to the "Audio In/TV" portion of the HTS.
Note: Using a red and white cable may not give you sound on all 5 speakers.
3)Get a digital audio or SPDIF cable and run it from the TV, Cable or Satellite Box's Digital Audio OUT to the "DIGITAL IN" of the HTS. This will give you the best sound quality. When using this (or any of the other) type of connection, press SURR until you get sound from all 5 speakers.
For the Xbox, try hooking a red/white audio cable from the Xbox into the Audio IN/AUX on the back of the HTS, and then switching the source on the home theater to AUX.
Also, the manual can be obtained from www.usasupport.philips.com
-Tha Mp3 Doctor
Jan 06, 2008 | Philips HTS-6500/37 System
Onkyo HT-S5100 Theater System Logo
130 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Dennis McCollum
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
