Question about Maytag PAV2300 Top Load Washer
Maytag mav5000 spins but clothes are still very wet?
Changed the belt already not much difference
  • Anonymous Feb 07, 2009
    I have the same problem. Units spins very slow
  • 20 Answers
Slipping belt
Posted on Feb 10, 2009
Clothes still wet
Usually due to blockage in filter or hose or pump, but may be motor brushes not spinning drum to proper speed
May 09, 2012 | Maytag Washing Machines
Cloths are wet after spin cycle
ceck for kinks in the drain hose .if you have a wet vacuum try sucking on the drain hose, or fallow the drain hose into the back of the unit to see if there is a blockage or a belt off .. jay florida
Nov 23, 2011 | Maytag EPIC MFW9700S Front Load Washer
My machine is spinning, but clothes are still very wet, have to drain and spin at least twice to get them dry enough to put in the dryer
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Feb 08, 2011 | GE Washing Machines
Maytag MAV5000 washer will not agitate
HI.
Lift the washer up and see if drum drive belt is broken or direct drive coupler is defective.
Mar 29, 2010 | Maytag Atlantis MAV5000
Spin doesn't seem to work - clothes are dripping
Sounds like the belt is slipping. I would check that first. You don't say what model, or how old it is.
Jan 07, 2010 | Maytag Washing Machines
I replaced both belts on my washer. Last night I smelled burning rubber. Today the cycle will fill, and spin yet will not agitate. What should I do ?
The pump belt has to be adjusted correctly or the drive belt will slip. If it already slipped enough to burn the new belt, you will probably need another drive belt.
Jan 06, 2010 | Maytag Atlantis MAV5000
Maytag model MAV208DAWW washer, clothes still damp to wet after spin cycle. DIYer, want to try to fix it myself.
excellent love a guy willing to try
ok wet cloths
with this model i would the first thing to check is the height of your drain,,,, if the drain ios highter than 6 feet the unit just cant do it
next check your belt, this sometimes becomes stretched, more than 1/2 deflection id change it
Oct 25, 2009 | Maytag Legacy MAV208DAWW Top Load Washer
Clothes still wet after final spin cycle
It sounds like you might have a broken belt or the belt just slipped off the pulley!
Jan 22, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Clothes are wet at end of spin cycle
Dear Customer
Please perform the following
Clothes are too wet after spin cycle:
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Dec 17, 2008 | Maytag Washing Machines
Maytag PAV2300 Top Load Washer Logo
74 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
