Question about Gigabyte GA-8I915PL-G Motherboard
My computer is only recongising one ram slot
And when i place a second dimm of ram in the computer does not start properly and makes a ticking sound.
  • grahamtate Feb 08, 2009
    Yes the yes dimms are identical as i did have 2 x 512mb in i upgraded to 1 x 512 and 1 x 1024 and it worked ok but when i upgraded futher to 2 x 1024 it would only recongise one of the dimms i know can only get the computer to work with one dimm in,
  • Franklin Heinis May 11, 2010
    is the second dimm identical to the other one ?
    and if so are they both in the dual channel slot usually on gigabit boards they have the same collor on each side probbly orange.
    Genius:
  • 1,913 Answers
May be your ram frequency is conflicting. so it is not run with each other.
Posted on Feb 07, 2009
A7v8x-mx 2GB (2x 1GB) don't recognize
Sounds like you have run into a compatibility problem between your RAM and motherboard. These kinds of problems have been very common and that is why most motherboards have a supported memory list. Usually if the RAM does not work properly you can try reversing the slots that they are plugged into and make sure that your motherboard is set for the proper voltage and speed for the RAM. If it still does not work then you would most likely need either different RAM or a different motherboard.
Feb 17, 2012 | ASUS A7V8X-MX Motherboard
I have recently upgraded my brothers Acer T180 computer with approved crucial 2 x 1GB ram ddr2 PC2-5300 667 NON ECC UNBUFFERED CL5 which was scanned by the crucial website and purchased from them. When the...
Some motherboards are only upgradable to their allotted amount that board may only handle up to 2 gigs of RAM which is a shame. But this is the way it is. That is why I always check the board memory capacity before I buy computer boards or RAM for them. The beeps indicate error on the slots for the RAM that is why you can start up when you remove ram one at a time and replace. So use the allotted amount of RAM for that board specification or get another mother board that can handle more than 2 gigs of RAM. Sorry for the loss. Thanks for using FixYa! John
Apr 13, 2011 | Acer Aspire™ T180 PC Desktop
How do add ram or is it even possible on this unit
Hello, yes it's possible. There are 2 memory slots under the keyboard. Take a look at
http://www.ehow.com/how_6234021_install-memory-compaq-armada-e500.html
for quite a lot of info on the Armada E500. Also youtube for some useful info. if you type 'Compaq Armada E500' into the search box.
Regards
nicam49
Oct 30, 2010 | Compaq Armada E500 Notebook
Just bought 2 1GB PNY dual Chanel memory modules for my Computer Make: HP Pavilion 061 Computer Model: RJ181AA-ABA a1600n Currently has Memory: 4 slots: 512 MB, 512 MB, empty, empty QUESTION: which slots...
Start off by putting the first memory module in DIMM slot 0 this is the slot nearest the processor. DIMM slot 1 is the slost after DIMM 0.
Regards.
Jun 28, 2010 | HP Computers & Internet
IBM T42p doesnt start all of a sudden.
You possibly have a RAM issue. If you have never done a RAM upgrade to your computer, then eventually most PC's have RAM issues with the more you load programs, download music, and run other processes. Most computers come with basic RAM which is about 1Gig. You can install up to 3 or 4Gigs of RAM on laptops.
You may purchase the RAM from Best Buys, Microcenter, Radio Shack, or any local computer parts store.
Here are instrutions on how to replace the RAM once you have purchased the needed RAM.
You may also need to check your hard drive memory to see if you are getting close to the limit or if your memory is already full. If you download alot of music or alot of programs then this is possibility.
  1. Turn off the computer; then disconnect the AC adapter and all cables from the computer.
  2. Close the computer display, and turn it over.
  3. Remove the battery.
  4. Loosen the screw on the memory slot cover; then remove the cover
If the SO-DIMM is already in the memory slot, remove it to make room for the new one by pressing out on the latches on both edges of the socket at the same time. Be sure to save it for future use.
5. Find the notch on the contact edge side of the SO-DIMM.
Note: To avoid damaging the SO-DIMM, do not touch its contact edge.
6. With the notched end of the SO-DIMM toward the contact edge side of the socket, insert the SO-DIMM into the socket at an angle of about 20 degrees (1); then press it firmly (2).
7. Pivot the SO-DIMM downward until it snaps into place.
8. Make sure that the card is firmly fixed in the slot and does not move easily.
9. Replace the memory slot cover by aligning the back side of the cover first and then tightening the screw.
Note:
When you have added or upgraded an SO-DIMM, do not use your computer until you have closed the cover. Never use the computer with the cover open.
10. Put the battery back in place, turn the computer over again, and reconnect the cables.
Replacing memory in the slot under the keyboard
  1. Turn off the computer; then disconnect the ac adapter and all cables from the computer.
  4. Remove the keyboard.
  5. To replace the SO-DIMM, refer to the procedure given earlier.
  6. Reinstall the keyboard.
  7. Put the battery back in place, turn the computer over again, and reconnect the cables.
Verifying the install was successful
  1. Turn the computer on.
  2. While the "To interrupt normal startup, press the blue Access IBM button" message is displayed at the lower-left of the screen, press the Access IBM button. The ThinkVantage Rescue and Recovery screen opens.
  3. Click Access BIOS. The System Restart Required window is displayed.
  4. Click Yes. The computer restarts, and the BIOS Setup Utility screen opens. The "Installed memory" item shows the total amount of memory installed in your computer.
    For example, if your computer has 256 MB of memory and you install a 256-MB SO-DIMM in it, the quantity shown in "Installed memory" should be 512 MB.
Lastly, you will need to check to see if you possibly have a virus/spyware on your computer. You will need to log into your virus program and run a system scan "Scan Now". Once it runs and if it detects any threats, be sure to have them removed/deleted. Once you have them removed/deleted, restart your computer.
I hope this was helpful and thank you for contacting the experts.
Jan 08, 2010 | IBM ThinkPad T42p PC Notebook
Why does the computer not see the 1 gb memory
Assuming "memory cards" refers to RAM:
First, make sure you have the right type of memory; the Gateway 510x uses either (DDR333 PC2700, 184p DIMM) or (400MHz DDR400 PC3200, 184p DIMM) 1 gb memory sticks. If the RAM type is correct check that it is properly installed. Firmly press the sticks into the slot until the plastic clips on the side snap into place.
Dec 08, 2009 | Gateway 510 X (10272197) PC Desktop
A7s333 motherboard with 3 dimm ram slots 2 x 1GB pc2700
That board type does not show on the ASUS web site. I think that your problem may be incompatibility of the RAM with the board specs. Placing faster RAM on the board will not make it go faster.
Oct 24, 2009 | ASUS A7S333 Motherboard
I tried to intall new RAM in a new Gateway DX4200-09. The computer came iwth 2 x 2 gig sticks of 667/800 dual channel 240 DIMM DDR2. I tried to add 2 more sticks of GEIL Black Dragon dual channel 800 DDR2...
From what you've described, it sounds like you've got a bad DIMM slot, since it's not recognizing RAM that you know is good (because it works in the other DIMM slots).
Since it's the DIMM slot, which is part of the motherboard, your safest bet is to let Gateway repair it under warranty.
It's a bummer to go without a computer for two weeks, but at least you won't have to pay to fix it.
Apr 03, 2009 | Computers & Internet
Asus P6T Deluxe motherboard won't post with 3rd RAM DIMM
that port is bad. If all three is known working the only explanation is that its a bad ram slot
Mar 29, 2009 | Computers & Internet
Increasing memory in e-machine t2240
Hi slcdane 13. One thing with DIMM slots is that, first of all they are color coded there. Im assuming that you have 4 DIMM slots and two of them are one color, and the other two are another color. What that means is that is if One DIMM slot has a RAM module of a certain capacity, then the other DIMM slot of the same color has to contain a RAM module of the same capacity as the first module. Now i am assuming that you have more than two RAM modules and More than 2 DIMM slots. HERE IS AN EASIER EXAMPLE
Lets say you have DIMM slots 1, 2, 3, and 4. Slots 1 and 3 are yellow, and slots 2 and 4 are red. Now lets say you also have 4 Ram modules. 2 of them are each 2 Gigabytes ready, and the other 2 are each 1 Gigabyte ready. Now lets say you take one of the 2 Gigabyte RAM modules and you place it into DIMM slot 1 which is yellow, what this means is that you have to place the other 2 Gigabyte RAM module into the DIMM slot 3 which is also yellow. The remaining 1 Gigabyte modules will have to go into DIMM slots 2 and 4 which are red.
Now do you get it? Same capacity modules have to go into same color slots. Now try it and see.
Dec 31, 2008 | E-Machines T2240 PC Desktop
Gigabyte GA-8I915PL-G Motherboard Logo
91 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
