Question about Indesit W 123 Front Load Washer
Fault message When put on 30 min short spin, nothing happened but machine counted down the 30 mins. Flashing F 02. Is this a fault code and what does it mean as lost manual.
  • Indesit Master
  • 3,463 Answers
Yes, F02 is a fault code, and is indicating a problem with the motor, it means that the motor is jammed, or the tacho is broken or detached. The tacho being a magnet on the end of the motor away from the pulley.
You will have to remove the motor to see if you can see anything obvious.
If you cannot sort it yourself, then I would recommend that you call an engineer.
You would not find an explanation for this error in the handbook.
Please rate my fixya solution.
Thanks.
Posted on Feb 07, 2009
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
E50 fault
An imbalance during the spin cycle has occurred. It's possible that the appliance has been overloaded, or the load is causing the drum to be unbalanced.
If the machine has been used repeatedly in a row, which can cause the motor to be overloaded, leave it to cool down for approx. 30 min. and then try again.
If the problem continues to occur, there is a problem with the motor. This has to be repaired by a Service Engineer.
Dec 21, 2013 | AEG T57800 Electric Dryer
PF MESSAGE APEARS ON DISPLAY
the water level malfunctioning
Nov 07, 2013 | LG Washing Machines
Hotpoint WMF760 wont fill with water..spin cycle not working either
replace the water inlet valve under the top cover from the manufactures website quoting the model nr eric
Jan 18, 2018 | Hotpoint Washing Machines
My front load has a f 6 code flashing
F06 is an error code that meansthat the control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz1goJUbb8i
Dec 05, 2011 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Hi i have a fisher & Paykal IW812 Intuitive Eco washing machine it gets to the rinse drains a little water then nothing happens time still counts down but nothing happening gets to the spin cycle then...
Hi just read your posting.Unless the machine shows an error code the diagnostic mode will not help.Does the machine agitate in the wash cycle?Does the machine drain the water completely?Does the machine spin the clothes dry.Please reply with additional information on the questions I have posted and I am sure I can help you rectify this fault.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Takes 2 hrs to run a 45 min cycle
defo a heating element fault or an ntc fault. More likely to be the element though.
Mar 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Error message f 09 and f 02
remove bottom panel..reach up from bottom to door lock area pull down on small tab hanging there door will release ..dip all the water out you can ..shop vac will help..remove the knob on front of pump have towels handy clean pump trap ck pump impeller for obstructions reassemble and ck if problem persists may be loose impeller on pump
Aug 27, 2008 | Kenmore 46462 Front Load Washer
Electrolux 1087 E90
call frigidaire for factory service or have the dealer replace it
May 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing time & quality
Look for wash cycles in your users'manual. It is best the read the manual well before operation.
Apr 05, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Indesit W 123 Front Load Washer Logo
343 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
