Question about Dell Computers & Internet
Computer wont boot up
Have a ideq system with a P4TBA motherboard which won't boot up, when I turn system on all that happens is the screen shows the following BIOS ROM checksum error
detecting floppy drive A media
Drive A error system halt
with the cursor flashing
thats how it comes up have tried f1,f2 and del keys to try to get in bios but cant do anything with it, can ayone help me with this and possible causes, I only have limited knoledge with computers
thanks in advance
paul.
    Genius:
  • 1,913 Answers
First reconnect your keybord and mouse jack in computer then power up the compter then press del or F1 or F2 to nweter in bios setup then just press F10 and save settings .
Posted on Feb 07, 2009
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
My system with asus p5n73-am mother board shows BSOD
if nothing else is affected and everything runs fine after this then i would be careful on what you install because this could become a serious issue this happens because the computer notices an error on startup then either fixes itself or ignores the problem write back if the problem worsens
Dec 27, 2009 | ASUS P5N73-AM Motherboard
Ideq graphic card
The 200N has,
Nvidia Nforce chipset
Nvidia Geforce 4 mx integrated graphics with dual output
But I'll need to know your model # to get a better idea.
Alternatively, you could just open the thing up and look. If the video card is in the video card slot, you could just read the model #, etc.
If it's integrated, then look at the motherboard for a model #, etc and let us know. Those are fairly easy to find, and sometimes come bundled with the chipset drivers already.
Let me know!
Nov 29, 2009 | Biostar iDeq 210AB P4 or Celeron Mini Cube...
Ideq evesham motherboard
Visit the motherboard website in the internet and look there for the video driver for your motherboard. You can find it the download section of the site.
Nov 29, 2009 | Biostar iDEQ N1 Socket754/GeForce...
Cant boot my system
Check all your power cable if they are losened and the memory if is fully inserted
Aug 04, 2009 | ASUS P4SDX Motherboard
Hi please help me with my acer 3003 wont boot
try to power up with power cord only and see if it works. If no lights turn on than your motherboard is dead. If it turns on and nothing happens make sure there is memory installed(RAM). If it turns on and you see windows screen than it shuts off than your operating system needs to be installed again. Also, you can try booting in safe mode by hitting f8 when you initially start your computer and see if it stays on and if it does you have a virus most likely. Good luck.
Aug 18, 2008 | Acer Aspire 3000 Notebook
SONY VAIO PCG-7G1M Wont boot
First you understand yourself is that after the windows logo screen apperars and its get restart means there is some changes or malfunction happened to your hardware - Although you changed your hard disk will not solve your problem. Please clarify as follows
1) did you load you operating system to this hard disk by any other computer help - if you load it with the same system try to reinstall the system.
If the problem existing 100% your motherboard is partially damage I think the uniprocessor side voltage variation is happening while you press keyboard some charge (voltage) you are supplying to the motherboard, sometimes some key pulse is more than 5 volt so that pulse support to get moved some points
First check your windows try to reinstall agian - I predict that you got this hard disk installed through some other laptop so the hardware configuration is different.
Thanks Hothawk
Jul 17, 2008 | Computers & Internet
Wont boot fully
Try resetting the system BIOS.
There are three ways to do this, depending on the mainboard style.
Check for a jumper near the mainboard battery.
If there is one, and it is a three pin style, move the jumper from the side it is on to the other side, then turn the power on (generally it will spin up, but nothing will happen), and then back off. Replace the jumper as it was originally and boot the system.
If there is a two pin jumper, remove the jumper, turn the computer on (again, it will probably not do anything), then turn the computer off and replace the jumper and reboot.
If there is no jumper, remove the battery, turn the system on, then off, then replace the battery and reboot.
Feb 14, 2008 | IBM eServer xSeries 346
Biostar IDEQ 300g MCE-I - Pentium-D supported?
Try Support at this site
http://www.biostar.com.tw/
Dec 22, 2007 | Biostar I-DEQ 300G (IDEQ300G) Barebone
Computers & Internet Logo
164 people viewed this question
Alun Cox
