Question about Kenmore 22422 Top Load Washer
Kenmore 70 series is slow to spin
I have a Kenmoer 70 Series and when it reaches the spin cycle I have to help it spin it does this in the rinse cycle. Please help these economic times are tough and need to try to fix myself if I can.
    Master:
  • 848 Answers
It sounds like you have a bad clutch in the washer. To diagnose this failure, you would need to pull off the washer cabinet and pull the transmission. It is likely that you would find the clutch band glazed over. It is probably not exerting enough torque to release the brake and spin the washer.If you find this problem, you can try sanding the band to rough it up. Reassemble the washer and check for proper spin. If this fixes the problem, you will need to order and replace the clutch band.
This type of procedure is usually performed by a service technician. I don't recommend attempting this repair unless you are completely confident that you can safely perform the work.
Posted on Feb 07, 2009
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
May 11, 2014 | Washing Machines
Kenmore 70 series Washer will not drain and spin
You have a bad lid switch . Try inserting something into the hole on the top and see if that starts the machine in drain/spin . If not , still bad lid switch . If so , tells you still bad lid switch .
Jul 26, 2009 | Washing Machines
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer will not go to rinse cycle. 70 series
I had the same problem and it was a broken switch that prevents the washing machine from going into spin with the the top door open. The switch is located in the upper left corner, you can see 2 screws that hold it in. Reach under and check that the middle point when pressed pulls the ends where the actual switch is, you should hear a click.
I was able to temporarly repair by focing the swtich to always be depressed with 2 strips of duct tape. - Warning the washer will go into spin cycle with the top open.
Jan 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
168 people viewed this question
Sal De
fordexpert
Robert Rankin
