Question about LG LRSC26940ST 36" Side-by-Side Refrigerator w/ 26 Cu. Ft. Capacity, OptiChill Crisper & Jet Freezin...
What is the "Jet" and "Express" freeze settings - LG26940st refri
I find nothing in my manual that tells me what this (these) setting(s) are suppose to do. Is there a right or wrong setting?
Fridge works freezer does not freeze
Always start by emptying the total refri and freezer until dry. check for settings for your freezer you may not see when full. If that checks out, plug it in. There is a little air fan underneath your refrig. It says cannot lubricate. Horse s**t. It it's stuck or making a noise, blow it out and spray a little WD-40. See if it's turning. Listen to hear the compressor kick in. Do what I said and you will be OK or find the problem.
Aug 27, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Tip
How to improve quality with the right paper setting
One of the most common reasons for complaints about ink-jet output quality, is that the driver is set for the wrong type of paper. Different papers require different amounts of ink and different proportions of ink colors to produce the correct final colors. Setting the paper type tells the driver which color tables to use. Some ink-jets are supposed to recognize the paper type automatically, but the feature doesn't always work. So if you're not getting the results you expect, don't give up on the printer until you've made sure you're setting the driver manually for the paper you're actually using.
on Mar 25, 2010 | Office Equipment & Supplies
Refrigerator freezer problem. Kenmore Elite bottom freezer refrigerator, model # 795.75546401, manufactured 9/2004 (LG is actual manufacturer). The Express Freeze LED turns on and 2 "beep"...
Press and hold FRZ TEMP button and REF TEMP button at the same time for 3 seconds.And see if that makes any difference in the problem. ---------- If the problem is same then try the manual reset procedure.In manual reset the unit has to be unplugged from power outlet for 24 hours.Then empty both the fridge and freezer section completely.Then after 24 hours.Clean the melted ice water from the inner parts.Then reconnect the power cord of the unit to power outlet.Set the temperature to normal settings.It will take near to 4 hours for your unit to run its regular cooling cycle.Once this is done then check,if the same problem is seen.-----------This will help.Thanks.Helpmech.
Dec 20, 2010 | Kitchen Ranges
Cycle isn't using Jet Dry
Open up the dispenser and there should be numbers inside[use a flashlite] change the setting to a higher number and try that!!
Jun 17, 2010 | Hotpoint 24 in. HDA3400G Built-in...
My samsung8000 jet has suddenly not allowing text messages to go through make a call and no access to the internet?
i think u have changed sim settings in by changing send my caller identity to NO thats why it misfunctions
Jun 12, 2010 | Samsung Jet S8000 Cell Phone
Hi i was wanting to know what the exhaust valve setting is supposed to be and also i need to know what the carberator jet is supposed to be set at thank u
Ask your dealership mechanic ,or if possible get hold of the suzuki workshop manual for your bike ,it will have all the settings and jet hights in there .
Mar 13, 2010 | 2004 Suzuki RM 250
Can't connect to the internet with my Airport Express
Make sure your network settings are set to DHCP manually and that you are getting an IP address that does NOT start with 169.258
If you are using a Windows PC you may have to use the ipconfig /release and ipconfig /renew to refresh your DHCP settings.
Also try using the Airport utility (located in the Utilities folder) if you have a Mac. It will tell you if there is an issue.
Dec 29, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Freezing up
Primary Cause is Thermostate
Secondary Cause only Anti Freez Switch which is attached to the Evaporator Coil unit
Good Luck
Oct 11, 2008 | Miele K8452S Refrigerator
LG LRSC26940ST 36" Side-by-Side Refrigerator w/ 26 Cu. Ft. Capacity, OptiChill Crisper & Jet Freezin... Logo
447 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
