Question about Microsoft Windows XP Professional
2 windows xp on my computer
I have 2 operating system in my computer, both windows xp, when i boot my computer it ask me what o.s. will i choose, i want to delete my other o.s. , and retain only 1 o.s. how can I do it?
  • Anonymous Feb 27, 2009
    when i open my computer it two xp one work but the other doesnot work tihs problem occur after i format
  • 4 Answers
You might have corrupt boot files on windows...look on google for how to display hidden/system files in windows..
then look for boot.ini inside C:\ remove the entry you don't want..I would personally format the drive using emergency recovery cd out on the net, and then would do a clean install if you upgraded or tried a second install to fix a first.
Posted on Feb 07, 2009
    Scholar:
  • 127 Answers
Heres a tutorial on how to remove dual boot. also you can find it here
please take note that it may break your other OS...so follow the instructions properly.
let us know
HOW CAN I FIX THIS.WHEN I TURN IT ON IT SAYS STARTING WINDOWS AND THEN IT JUST GOES BLACK I.ALL YOU CAN SEE IS THE CURSOR.
If your computer boots to a black screen when using Windows 7 you can always try to recover a working system by using your Operating system disc!
1. Boot from the Windows 7 operating system disc. If your computer is not set to boot from cdrom first then you need to be able to enter the BIOS to change your boot options.
2. Choose your language from the list.
3. Choose the Repair your computer option on the install now section.
4. Choose the System restore option.
5. Choose a restore point. If you have installed a program today that caused a problem choose a restore point prior to that?
6. Let it take you back to when you didn\'t have a problem.
These instructions above will work for Windows Vista as well.
If you have XP
I am assuming you have your operating system cd. If you do not see the option to repair and you only see an option to set up Windows then this tutorial is not for you.
  1. First you must put your Windows XP CD in the drive.
  2. Then restart your computer.
  3. When it says press any key to boot from cd, Press any key on the keyboard. (Go to step 6)
  4. If it doesn\'t ask you this then restart your computer again.
  5. Go into the BIOS settings of your PC, usually by pressing the F1, F2, F10, or maybe the delete key. If you are not sure watch the screen at startup and it will say "To enter setup press.......". You have to be quick and press it. If you miss it restart again. Once you are in the bios you have to change the boot options. You have to make your cd rom the first boot option. Save and exit.
  6. A blue screen will appear and you are on your way..
  1. Press Enter to setup Windows XP now. Do not choose to Repair yet.
  2. If there is a copy of Windows XP on your computer setup will find it.
  3. See below where it says C:windows "Microsoft Windows XP Professional" Make sure this is selected. It may say Windows XP home also.
  1. Now choose to Repair the selected Windows XP installation by pressing the letter R on the keyboard.
  2. Now windows will seem to run through the usual setup process, however a lot quicker. Don\'t panic because it will not wipe your files if you have chosen to repair.
  3. At some point you will have to enter the serial number and restart the computer.
  4. When you login again your files will still be there but the Windows errors you had will not.
Notes:
  • This article relates to an original Windows XP cd. If you use an OEM Version of Xp it may actually format your entire computer and you will loose all of your data.
Aug 13, 2014 | Computers & Internet
Tip
HOW TO REINSTALL WINDOWS XP OR INSTALLING CLEAN COPY
How to reinstall Windows XP operating system or installing fresh copy of Windows XP on your computer.
If your Windows XP operating system had problem due to corrupted files, viruses problem or you want to upgrade your system. This procedure will guide you in reinstalling your current Windows XP or installing fresh copy.
After this installing process, you need all your hardware drivers like Chipset Intel driver, LAN driver, Sound driver, WAN driver, Webcam driver and others for the computer to be fully operational. Otherwise, do not proceed on reinstalling you operating system if your do not have those hardware drivers.
CDROM drive is required for installing Windows XP. If you don't have in your notebook computer, use external CDROM drive to connect in your computer using a USB cable.
1. To start with, you need to back up your in blank CD all your important files before you begin installation produre because all the data will be wipe out.
2. When ready, start your computer and when booting press F2 to
BIOS setting.
3. On BIOS menu, choose the BOOT setting and change the priority boot to CDROM, exit and save.
In some laptops, you can skip this BIOS setting process by repeatedly pressing F9 key or F10key when booting your computer and it will run boot priority on CD.
4. Once you exit from BIOS, you computer will reboot and a message will appear " Press any key to boot from CD", press any key to enter into WINDOWS XP SET UP.
5. Belows instruction messages will appear:
* To set up Windows XP now, press ENTER
* To repair Windows XP installation using recovery console, press R
* To quit set up without installing Windows XP, press F3
Press ENTER to initiate the installation.
6. You will go to Windows XP license agreement and press F8 to agree.
7. You will ask you if you want to REPAIR or REINSTALL the operating system. It will appear like this. Just press ESC to proceed.
A. To repair the selected Windows XP installation, press R.
B. To continue installing fresh copy of Windows XP without repairing, press ESC.
From repairing your operating system, it will not removed all your files and other software installed in your computer including your hardware drivers installed. Just fixing the operating system.
For reinstalling the operating system, you need to back up all you files because it will wipe out all you datas in your computer.
8. After that, it ask you where partition you want to install the operating system. The message will display like this :
C : Partition1 [NTFS]
D : Partition2 [NTFS]
Unpartitioned Space
Use the directional key to navigate and choose C: Partition1 if you want reinstalling Windows XP and press enter.
If you want clean copy of Windows XP, you need to delete both partition by pressing L and install clean copy at Unpartitioned space. By these procedure, you will have C: drive only. D: Drive is delete.
9. After choosing the desire partition. this will appear :
* Format the partition using NTFS files system
* Format the partition using the NFTS file
I suggest to choose the first line which is the quick format. The 2nd line take too much time to install the operating system. Press to initiate the installation and it will be finish and reboot automatically. PART OF WINDOWS INSTALLATION IS FINISHED.
If you had interrupted installation which is asking for certain driver file, your CD installer maybe damage which cause files to be unreadable. Try to replace the new Windows XP installer CD to proceed and until finished installing OS.
10. Once it reboots, this time do not boot from CD or do not press any key to go to PART2 OF WINDOWS XP INSTALLATION PROCESS.
11. On the opening, regional and laguage option will appear, jus click next.
12. The it will ask to type your name & organization. Put you name and company if any and click next
13. Then, it will ask for CD key and type the 25 character CD key and click next
14. Then it will ask for computer name. You can change or leave it and click next.
15. Then, set your date and time zone and click next.
16. Then, it will ask you for workgroup and computer domain, just leave it and click next.
17. Now wait until the installation process end and it will again restart automatically.
18. Again, do not boot from CD and display setting will appear. Just click OK.
19. welcom to Microsoft Windows screen will appear. Just click next.
20. Helps protect your PC will appear and choose Turn on Automatic Updates ( Only if you install genuine Windows XP). Otherwise, I suggest to choose "Not right not" if you are installing copy only of Windows XP.
21. Who will use this computer message will appear. Just type your name on the first box and click next.
Also for your reference, here is the video for your convenient .
A thank you message will appear, Just click next and it is finished.
I hope it helps you and thank you for using FixYa !
For repairing the operating system here is the blog as other want it.
As per others demand, here is the video for Windows 7 and Windows Vista Operating system
on Dec 23, 2010 | Computers & Internet
I has delete file on memory's intermec cn3, How to recovery file ?
REPAIR YOUR OPERATING SYSTEM AS FOLLOWS
Download the operating system from this link: http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
or
if you have it, install it using the procedure below:Boot From the Windows XP CD
  • You must boot from your XP . Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
    you will be asked to press any key to boot from CD, so do just that.
    Step 3: System repair steps
  • A blue screen will appear and will begin loading XP setup from the CD.
    simply let the CD load without pressing F6.
    Once completed, you will be confronted with "Windows Setup". You will be asked to setup up Windows, or repair Windows with the recovery console. Choose the FIRST option, NOT recovery console.
Choose F8 to continue.
  • Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP.
    If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts
  • If this solution helped Never go to drive C: again. Vote for this solution and rate it
Apr 20, 2011 | Computers & Internet
My ksuser dll for windows xp profesional
Just boot from the xp professional cd and run the recovery console.
or
Apr 19, 2011 | Microsoft Windows XP Professional
Error message "load needed dlls for kernel"
1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue. 2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key. 3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console. 4. Select the operating system you wish to fix, and then enter the administrator password. 5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32 6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file. 7. Type exit to reboot the computer.
Mar 05, 2011 | Acer Computers & Internet
I turned on the PC, was asked to choose between WIN and WIN XP. When I choose WIN XP, the message comes up that "file nvrd32.sys could not be found" and so then I had to reboot the PC, choose WIN...
need the xp disc someone or thing has deleted a system-32, made the same mistake and had to reload the OS. System 32 is a main part of Your OS with just one little whoops of deletion you render the program useless. it should save your old stuff in a win.old file which it'll explain as you redo the whole thing over again good luck hope I can help
Jan 20, 2011 | Computers & Internet
How to reformat my windows xp computer
OK get into system BIOS, prees DEL. F2, or whatever your key is. Set in the BIOS to Boot the DVD FIRST, Then insert you DVD, Boot off your Windows DVD, & install from, the DVD, go through the setup to where it asks you if you wish to FORMAT, choose FULL NTFS Format and let it complete, then proceed with the install, done.
Feb 21, 2010 | Microsoft Windows XP Professional SP2
The system is getting restart continously,while booting
  • 1. Got to your Start menu and select “Run” option.
  • 2. Type in msconfig command and click OK. The System Configuration Utility program will then open.
  • 3. Select the BOOT.INI tab located at the top of the System Configuration Utility window.
  • 4. UNCheck the box labeled /SAFEBOOT and click OK.
  • 5. When asked if you prefer to restart the PC immediately, or Exit Without Restart, choose to restart the computer manually.
  • 6. Your computer will automatically boot into Windows XP Normal Mode when you will restart it.
Dec 16, 2008 | Microsoft Windows XP Home Edition
Plz help me ..regarding uninstallation
go to start then select run and type msconfig the hit enter key
when a window pop up click on the boot.ini then delete the boot partition where windows 98 located then restart your unit
Aug 14, 2008 | Microsoft Computers & Internet
When I boot up my computer before windows xp loads it asks which operating system I want to run,and it gives me 2 choices WINDOWS XP HOME, or, WINDOWS XP HOME. You use the up and down arrows to select...
simply you can remove the second option in the boot.ini.
go to the or right click the my computer at the desktop and the properties. and then click"advance TAb" in the start up and recovery, click "setting" and then "edit"
you will see this:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
Timeout=30 change to: 0
and then delete this:
after deleting you must save it.
and then restart the system
Please leave a comment b4 your rate, Thanks!
Jan 28, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
