Question about Whirlpool Dryers
Remove debris from around the outside of drum
I dried a feather pillow which burst open. Ever since then the dryer has been making a lot of noise. How do I open up the case to remove debris from around the drum
  • 979 Answers
Take the top off the dryer. You can access it from the back and remove the screws. You will probably find a lot of dust as well. You can also lay the dryer on its frontside to get to the bottom. There isn't going to be anything you can damage here. Vacuum it well especially around the motor.
Posted on Feb 07, 2009
We have an LG DLEX8377NM dryer and are having problems with the drying cycle. We've owned it for three years and bought it new. It was professionally installed. We frequently dry clothes on the...
if there's heat in the dryer and yours is electric the most likely cause for dryer taking to long to dry is a blocked vent line,start the dryer ,go outside and check the outside hood where it blows out,make sure there isn't anything blocking it or a cage on it that's filled with lint,also every dryer should be opened up and cleaned,the easiest way is to get a shop vac,remove the front of dryer,vac up as much lint as you can see and then set the vac up to blow and blow the lint forwards so you don't have to remove the drum,then if the vent line is a long run i use a leaf blower,remove the vent line from the back of the dryer ,stick the leaf blower into the opening of the vent line and blow it out to the outside,hit it with short bursts at first so you don't damage the vent line if it isn't hard pipe,you will see a huge difference in the drying time.
Oct 01, 2017 | LG SteamDryer 7.3 Cu. Ft. 9-Cycle...
My son's bean bag pillow with beans exploded in dryer
The easiest way is to remove the front. You can then see between the inner and outer drum without removing the rear bearings and heat elements.
Jun 07, 2010 | Magic Chef CYE2000 Electric Commercial...
GE dry is making a noise like loose change is rolling around
There may be change rolling around in it.
Remove the top. Take the screws out of the drum baffles and remove the coins from inside the dryer drum baffles.
When replacing them, tighten them well to help prevent coins from getting in there.
Mar 23, 2009 | GE Dryers
I need to remove the drum to clean the inside part of it
go in touch with BOSCH customer service and tell them ur problem....i don't think u have to remove the drum to fix ur problem.....so find out yourself from bosch......good luck
Mar 12, 2009 | Bosch Exxcel WFO 2864 Front Load Washer
Thumping noise in atlantis dryer after drying heavy mattress pad
Have you husband do a visual inspection of the drum and literally feel it to see if anything is caught or stuck on the drum. The motor also may have something caught in it as well. This would be the motor that turns the drum.
Dec 15, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Noisy dryer
tis possible that cons have gotten stuck within the veins( tub paddles) of the dryer drum, if thats the case youlll be able to rotate the drum around by hand and actually hear them tumble around as you turn them around.if thats the case tou will need to unscrew the tub baffles from the outside of the drum remove debris and resecure.DISCONNECT POWER SUPPLY
first remove 2 5/16 screws holding the lower access panel. and behind that panel 2 more 5/16 screws. lift that panel foward and it will release from under the main lid(2 clips holdin it in). mark the 3 wiresd and disconnect the door switch.2 final 5/16 screws in either corner is holding the main lid assy down, remove them and your able to flip the main top back. you now have access to the outside of the drum all you need to do is rotate around find the screws holding baffles and clean them out
Mar 29, 2008 | Dryers
I've had a model DLG330RAW gas dryer for 5 years. About 2 weeks ago it started making a sound as if coins were in the barrel. It wasn't the clothes buttons, zippers, etc as it will still make the noise...
Fridgedaire drying- It's screeching!
There are several things that will make a dryer noisy. Here's a list of a few items that I know of. Some may or may not apply to your dryer: FIRST OF ALL, BEFORE SERVICING THE INSIDE OF ANY DRYER UNPLUG THE UNIT OR TURN THE CIRCUIT BREAKER OFF. 1. Drum rollers worn out. Most dryers have some sort of drum roller that supports the dryer drum. There are two mounted under the drum in the rear of the dryer. Some models will have an additional set of drum rollers under the front of the drum as well. You may also here the drum thumping too. Lubricating them with a good quality turbine oil at the point of the spin shaft will get rid of any squeaks or squeals. DO NOT oil the roller wheel as it will slip on the drum. 2. Dryer drum seal. This is a felt gasket or seal that is glued to the rear ring of the drum. When they get old they become brittle and pieces start to break off leaving bare metal scraping against bare metal. They also can become folded and part of it will be seen poking through the back of the drum inside. This seal should ride evenly around the outside perimeter of the drum and should not be seen inside the drum. 3. Dryer drum support glides. Some dryer models have teflon plastic support glides mounting around the ring of the front of the tub, or will have teflon supports mounted under the front of the drum. In either case, if the plastic gets too worn down, the dryer will start to make a scraping noise. 4. Idler pulley. This is a little pulley that provides tension on the dryer drive belt. It is located near the drive motor and can start to make noise. Usually a little bit of lubrication at the point of the spin shaft will get rid of the problem. 5. Dryer drive motor. Sometimes when the drive motor gets a nice collection of dust build up around it, the motor will make noise as the impeller rubs against dust or any other debris caught. A stiff cleaning brush and a vacuum cleaner will help get rid of dust accumulation around the motor. Now, there is a possibility that the bearings in the motor could be going bad too. You would need to remove the drive belt and check to make sure the motor free spins with no power applied. Give the motor shaft a spin. It should glide free with no noise. 6. Dryer drive belt. When the belt gets old it will develop a "glaze" on it and start to slip around the drum. This can causing a squealing noise, especially under heavier loads. This is usually a prelude to the belt breaking. Start with the easy and simple options first. Try lubricating any drum rollers or pulley rollers. DO NOT get oil on the drive belt. Lubricate the rollers at the point of the spin shaft only. Inspect the front and rear of the drum. The seal will be in the rear. Make sure that it is intact and good condition, and make sure it has not folded inside the drum. Also, check for glide supports around the front of the drum and make sure there are not areas that are worn down. Another thing that COULD cause noise, but may not be associated to the problem you are having, are foreign objects getting lodged between the dryer drum and casing. Screws, paper clips, nails, etc., have been known to get caught in these areas and will make some awful noise. If you try everything and the unit still makes noise the drive motor bearings could be going bad. This is usually not likely and the motor can be very expensive to replace. Last of all, some heat on the top and rear of the dryer are normal. However, if it is excessive (you can't place your hand on it and hold it there), you probably need to give the inside casing a good cleaning. This could be a sign that your dryer ducting has become clogged and the unit is actually overheating trying to fight for air. Ask yourself, "Are my clothes taking a longer time to dry?" If the answer is "yes" then you need to clean the unit out and check the entire length of the ducting to ensure it is blowing air out of the vent. Remember also, the shorter and straighter the ducting run, the better. Any sharp bends or kinks (behind the dryer) will cause lint to back up. I hope you find this advice helpful. Good luck and let me know if I can help further.
Jul 01, 2007 | Frigidaire FDE336RE Dryer
Open Questions:
Dryers Logo
53 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
