Question about Canon PIXMA iP4200 InkJet Photo Printer
Canon ip4200 one cartridge/nozzle does not work
I have been having some problems with my yellow printer cartridge. It just doesn't work. So I bought a new one, thinking the old one might have been a bit dried up, installed it, and it still doesn't work. I've cleaned and deep cleaned many times, but still the nozzle check printout only shows a very very faint yellow line. All my printouts now are very red! I have come to the conclusion that the yellow printer nozzle is blocked, but what can I do about it? I don't want to have to buy a new printer for the sake of one cartridge problem.
Please help!
Many thanks in advance for your time.
  • 2,692 Answers
Put isoproply alcohol on the nozzel with a connon swab until it melts(desolves) the drived ink.
Posted on Feb 07, 2009
Old cartridge works, new one doesn't
If the cartridges are in date and the old cartridge works OK then they must be faulty.
Jul 19, 2012 | HP C1823D Ink Jet Printer
The yellow ink light keeps flashing on my HP5150 printer, I have just installed new cartridges and have tried cleaning the sensors but that hasn't worked
If the old cartridge also give that alarm so ignore it and keep's a sensor malfunction
but if the old one is not giving that alarm, i think its compatibility problem or the new cartridge is not original.
Aug 24, 2011 | HP DeskJet 5150 InkJet Printer
The yellow cartridge shows a "?" when needs to
According to your problem, first clear the cartridge head. Go to the Printer properties and clean the head. Check the nozzles and align the cartridges from same place. Clean the cartridge head 2-4 times. If it doesn't solve your problem then replace the cartridge.
May 04, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Mp830 5200 error how to fix
Hi, this error code 5200 indicates that one of the cartridges is having problem with it's print head. You need to replace it, but first you need to find which one. For best solution, we need a set of new cartridges so that there'd be no problem testing.
Let's begin like this;
Remove all the old cartridges, Turn off the printer, disconnect the all the cables including power cord and ethernet cable (if any), leave it Off for few minutes and again turn it on after connecting the power cord. Now install all the new cartridges and check if the error message is still there or not (Hope it's gone, but you need to find out the culprit from among the old ones so that you can use those that are functioning properly).
Now remove one for example yellow and install the old yellow and check the message, if it's ok, go on replacing with the corresponding old cartridges after removing the newly installed, and so and find out the cartridge which is the creating this problem. After that, you'll be able to use the other remaining old cartridges.
This might be a problem for you if you don't have a new set of cartridges, but this is the best way, you can also use old working cartridges [those with no more inks].
This will definitely fix. I would also suggest you to clean the contact points on the cartridges and on the printer properly using soft brush/cotton dipped in alcohol/acetone/spirit.
Take care
Jul 18, 2010 | Canon PIXMA MP830 All-In-One InkJet...
HP will not recognise new cartridge
The problem you are describing with the yellow cartridge sounds like ink starvation possibly due to a clogged print head or an air bubble in the print head. Since the machine is so new I would contact HP to get the print head replaced. As for the magenta cartridge, exchanging it for a new one at the store you bought it from should fix the problem. It sounds like the chip on the one you have is either damaged or wasn't set to read full ink levels.
May 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printer doesn't recognise new ink cartridge
Please don't be offended if I ask that you carefully check whether you have removed all packaging
of the cartridge, including the ink seals on the heads of the cartridges you have supplied. Believe me,
this is a VERY common problem, and given your elimination by purchase of two additional cartridges
is more likely your problem than defective cartridges, assuming that all such yellow cartridges are not
Apr 07, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Display says I am out of yellow,
Hi, since you've already replace the yellow ink cartridge for several times and its not recognize. Your printer might have a defective printhead. You may take your printer to the nearest HP service center in your area so that they can look on your printer further.
---->> Tirzo
Jun 04, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Not printing magenta
Try cleaning contacts with a lint-free cloth or pencil rubber , touch the nozzle area with a cloth dampened with WATER, see if magenta appears. If nothing works, change cartridge...
Nov 07, 2007 | HP Deskjet 5440 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
148 people viewed this question
old marine
old marine
