Question about Sta Rite STA-RITE SENSOR,FLUE TEMP - 42002-0024S
Value Stack Flue Sensor
What is the value of resistance? of stack Flue Sensor Part #42002-0024S of heater Sta Rite SR 400LP. Thanks
  • Anonymous Mar 17, 2009
    WHAT IS THE VALUE?
    10k, 5k, ntc ,ptc etc?
3.5 to 4K If you want to bypass the sensor just jump a 1 dollar resistor in between the two wires. If you want to put another sensor just use a standard gas heater flute sensor(2dollars) and put in line with the resistor
Posted on Nov 26, 2009
  • Clyde Hill
    Clyde Hill Jan 01, 2018
    Thanks. Unit working until sensor arrives next week
  • 3 Answers
Are you getting E05 error? I can't give you the value, but it is possible to bypass the switch.  Unhook the sensor connection wires and jump them together.  Hold off switch until a code comes up - press down arrow once to change last value from 1 to 0, press off again and do the same thing with the next value and change it from 1 to 0, press off again.  Unit should work now until you get a new sensor and then just change the settings back.
Posted on Mar 17, 2009
Can I jump across stack flue sensor
Are your legs really muscular? If yes, then yes.
Oct 13, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Heater won't stay lit
could be caused by many things. could be an flame sensor error, open saftey switch, stack flue error, etc look on back of circuit board and tell me what errors are lit up
Mar 08, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Can't get my sta rite spa heater to work
check gas pressure if too low overheating check safety circuit
Apr 03, 2013 | Sta Rite Pool & Spa
I have two error codes: 180/R9 anlong with 128/R8 HELP!
Error pertains to stack flue sensor setting.
There are two modes for low level programming and default is a (0) Zero but for outdoor spas this must be reset to a one ( 1 )
Just hold the off button down for 30 seconds let up, press down again, use arrow buttons on key pad to set from 0 to 1...press off again....play with it and see for yourself...I don't now why Sta-rite buries this information and makes us guess.
Again, on mine, this all pertains to the Stack Flue Sensor setting.... you can look at your heater and see what they look like...outside toward bottom the SF must be a 1 and not Zero or you get the quick flash 128-R8 notice...also, the Stack flue senor is finicky and connections must be good...use steal wool to re-seat but be careful as connector break off easily thus requiring a new stack flue sensor...
I accidentally discovered this when I turned the board upside down and spotted the LED red light on indicating a fault with the SFS**
I wish some one would tell us how to by-pass the stack flue sensor to make the heater work.
Good luck...hopefully the power button is close by and your board is working....
Jan 21, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Error AD0 SF0 180 r8
the stack flue sensor is bad make sure you order the identical part since is two model for thre same heater
Oct 09, 2009 | Sta Rite Maxi Therm 400k Btu Propane...
Sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Jun 14, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Testing
jump for test if bad check gas pressure
Oct 21, 2008 | Sta Rite STA-RITE SENSOR,FLUE TEMP -...
Sta Rite STA-RITE SENSOR,FLUE TEMP - 42002-0024S Logo
1,706 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
