Question about Canon PIXMA MP170 All-In-One InkJet Printer
PAPER WONT GO INTO FEEDER STRAIGHT-GOES WONKY
I PUT PAPER INTO FEEDER HAS PROBLEM GRABING PAPER WHEN IT DOES GOES IN AT ANGLE EIGHTER JAMS OR COMES OUT DISTORTED.EVERYTING WAS WORKING FINE UNTIL I HAD MY CARTRIDGES REFILLED
  • 628 Answers
One of the feed rollers may have ink or some debris on it. Get a lint free cloth and put some alcohol on it and clean the entire roller set, all the way around if possible.
Posted on Feb 07, 2009
Paper wont feed in anymore. Tries to feed in but goes in wonky and then jams
Check to see if there are any jams in the printer, use a flashlight to get a good look around.
If you don't see any jams, Shake the printer around to loosen up any debris so it falls out of the printer. Alot of times kids fool around and put things in the printer and sometimes they are in the area where the paper feeds thru. If you do this and the paper still jams up, then that means the gears are worn and you'll have to get another printer because parts wouldn't be available for it.
Apr 19, 2010 | Lexmark X3480 All-In-One Printer
Hp deskjet 5550 is grabing the paper but paper prints crooked
You may have a paper jam (small paper cut) in the feeder ytry to check it and see if you can clean it...or you may bent the feeder...open it and let me know
Sep 13, 2009 | Office Equipment & Supplies
When printing, the paper is grabbed by one side and prints wonky. It seems to print better when selecting Matte card, but then uses more ink. How can i get it to print straight on plain paper?
On the paper tray there is a move-able guide, when you place a number of sheets in the paper tray you need to adjust this guide so that the paper is held in place with no sideways movement.....
If this guide is not in the right place the paper can be pulled to one side by paper pick up...
If the guide is set right and it still happens, get a torch and take the paper out of the tray and look down in where the paper goes.
There may be an obstruction in the side of the feeder.
This could be a small piece of paper or another object...
Jul 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
keep me posted
May 04, 2009 | Computers & Internet
Document feeder jams
When you put your paper in, check the side clamps are set correct, if there is a gap at one edge, your feeding will be all over the place.
Tuck up the clamps to clamp the paper, not too tight where you bend the paper, but tight enough to hold it correctly.
Regards
Richard
Mar 13, 2009 | HP Officejet Pro L7680 All-In-One Printer
DOCUMENT FEEDER IS JAMMING
Try and clean the rubber rollers with Isopropyl alcohol. Do not use any solvents.
S. Mohan, Chennai, India
Dec 30, 2008 | HP Scanjet 5590 Flatbed Scanner
Jams but only w/sheet feeder
Theres is a spring clutch in the adf that goes out. Once that is fixed it should work just fine.
Aug 13, 2008 | Sharp AR-507 Copier
CANON P23-DH V
There is a small slot below the removable ribbon cover. Cut the end of the paper so that you have a 45 degree angle.
Example:
/ l
/ l
/ l
/ l
/ l
l l
l l
It does not have to be so sharp of an angle, but it helps to get the end through the maze.
Insert the paper into the slot, and wiggle it through until you can grab the end of it. Pull the paper through, and slide it through the cover, and reinstall the ribbon cover.
When putting the paper on the roller make sure that the paper is heading straight into the slot.
Example: _O, not like this: /O
Jul 09, 2008 | Canon P23-DHV Calculator
Canon mp780
Normally this can be caused by
1.) damaged gears
2.) damaged feeder motor
3.) damaged paper holder(the pins that grab the paper)
in any of the above cases you will need to take apart to see what the problem is.. if its the motor then you can change it..
if it with the feeder it self id suggest you consider buying a ney one,, even if you manage to change the gears or the feeder pins you may never be able to get it to pull correctly, eighter pulling twisted or constantly causing paper jams.. The choice is your but i'd say buy a new one
Jun 16, 2008 | Canon PIXMA MP780 All-In-One InkJet...
My epson cs7800
I had the same problem and found a small spring was loose and interfering with the paper. The Spring was on the right side as you look at the printer, near the bottom of the paper feeder. I took it out and it works fine, for now.
Jun 15, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Canon PIXMA MP170 All-In-One InkJet Printer Logo
310 people viewed this question
old marine
old marine
Corne Viljoen
