I wanted an answer to this too. It was hard to find, but here we go.
Get hold of a torch, and look closely at the decorative surround at the bottom of the fire. There are two screws hidden in there, on each side! See below:
Unscrew these, and you can take the front off, and get at the bulbs.
For information, the fire takes two screw in bulbs, described as 240V – 60W E14 SES Clear Candle Lamps.
Hope this helps.
Was this helpful?
Yes
No
11 people thought this was helpful
Popular Solutions for Dimplex DS5598 Mid-Size Heater
Hi I have a Dimplex model HTN20 electric fan heater, the fan heater has never worked properly, when...
(More)
Hi I have a Dimplex model HTN20 electric fan heater, the fan heater has never worked properly, when put on full power the thermostat cuts off preventing any heat from being generated. I think the thermostat needs replacing - can you tell me how to do this and where i can get a replacement thermostat.
We plugged in our Dimplex ds3311 fireplace and it is not working at all. Any suggestions would be a...
(More)
We plugged in our Dimplex ds3311 fireplace and it is not working at all. Any suggestions would be a big help. thank you
I have a Dimplex heater like pictured that needs an RH switch. It is the first one that needs to be...
(More)
I have a Dimplex heater like pictured that needs an RH switch. It is the first one that needs to be on to get the other two to activate the heater. Only number I can see is iE4 or 16A 125vac 1/4 Hp
