Question about Nintendo DS Lite Console
My L dont work
My L button doesnt work i cant even tell my brother to do it he try but he fixed it once now its wrecked again
To fix it try blowing on the L button and maybe it should work keep trying or get something that spites out air really fast and put that on the L button
Posted on Feb 07, 2009
The black ink won't work even though its new
check if the noozles are on the catridges or on the independent print head. if the print head is seperate from catridges, them try print head cleaning. if you it cant work. then dip the print head in hot water for 5 to 10 seconds. dont dry it just put it back into the printer and try again immedeately. let me know if your problem is fixed
Jun 24, 2012 | Brother MFC J6510DW - Multifunction fax /...
My mouse lock button is orange when i press it it doesnt turn blue.... i cant even type anything, the only buttons that work is my power button and the volume touch keys.... i have tried turning it off and...
Tiffany ,,something real handy if you have a netbook is an external dvd /cd drive,from there you can install the operating system again--your problem is a sign of corrupted install/bad site/code/etc.Only a reinstall will properly reset your system.
Good Luck
Davey Snake!!
Jul 20, 2011 | HP Computers & Internet
Bought a used 1995 Toyota Avalon for daughter. Battery unhooked now Stereo locked. Model 16186349. Display shows HELP. Dealership gave me paperwork with unlock code and instructions but cant get it to work...
just replace it with a aftermarket stereo and dont forget to get both harness for easy diy install.thats what i did and it works fine & the best thing about it is i dont ever need a code again.
Feb 23, 2011 | 1995 Toyota Avalon
All the light flashing
Try this procedure as mentioned.if any mistake in trying the procedure then retry from first step again.so read it carefully and try it. Brother ML-2040 Toner Light Reset
When replacing the toner cartridge in the Brother HL-2040 with a new cartridge (compatible or remanufactured) the user may experience a problem with the toner light staying on, even with the new toner installed. The procedure below has worked for many folks, so give it a shot.
Open the front cover of the Brother HL-2040 and leave open while completing the following steps:
1.) Turn the printer off.
2.) Hold the ‘go’ button while turning the printer on. All panel lights should be on.
3.) Release the ‘go’ button once all lights are off.
4. )Press the ‘go’ button 2 times.
5.) Pause.
6.) Press the ‘go’ button 5 times.
7.) The toner light should be off.
8.) The paper light should be on.
9.) Close cover. The ready light should be the only light on.
Once all steps are successfully completed your “low toner” light should be fixed.
------------- From Brother Service Bulletin
1. Open the Front cover
2. Press and hold the GO button
3. Power ON the printer while continuing to hold the GO button
4. Once the 3 LED’s are lit, release the GO button
5. Press the GO button 2 times. This will cause the LED’s to light solid
6. With the LED’s lit solid, press the GO button 5 times
7. Toner Life End will then reset
8. Close the front cover.
----------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 02, 2010 | Brother HL-2040 Laser Printer
CANT SEND JUST RECEIVED. WHEN WE TRY TO SEND NOTHING HAPPENS AND INTELLIFAX 4100 BROTHER SHEET COMES OUT.
The same thing just happend to me. Check all the buttons on the machine and make sure there isn't one that is stuck. My "Fax" button was jammed and I didn't even know it. As soon as I wiggled it loose everything started working again.
Mar 15, 2010 | Brother IntelliFAX 4100 Laser Fax
Xbox 360: disk drive
try reseting the system in the system settings this, is sometimes caused by an update not downloading and or installing correctly. once you reset to default, try updating  the system on xbox live. if this continues you might have a drive issue. good luck....
May 27, 2009 | Microsoft Xbox 360 Console
Home button and wifi software problem
Try holding down the power/home buttons until the unit reboots, the should fix things.
May 19, 2009 | Apple iPod touch
Pr600 shunts over on big designs
You can try to calibrate the hoops by having the machine turned off and the largest hoop and smallest hoop ready hold down the start/stop button and the needle theader button and turn the machine on while holding those in, you should get a different screen that say a/d test in the upper left corner, put the largest hoop on the machine being shure the screws are tight and hit the l button on the upper right side the numbers next to the button will change, then put the smallest hoop on and hit the ss button once the thats done turn off the machine and on again and it will start normally and try your designs again if that doesnt work take it to a brother service center/ dealer and tell them to check your x-axis position
Mar 18, 2009 | Sewing Machines
SOLID BLACK PAGES?
in laser printers, theres a charging corona wire that gives the paper a 600v positive charge which attracts the toner. once the paper hits the drum, a laser with a 600v negative charge is shot at the paper which discharges the paper and the toner isnt attracted to that area anymore.
either the laser is malfunctioning and not shooting a beam at the drum which would make all the toner go to the paper, or theres something wrong with the toner cartridge.
try going to the brother website and downloading the driver again (cheap and easy) and if that doesnt fix the problem, replace the cartridge, i know, not cheap. if neither fixes the problem, call the brother support line and see what they can do for you. maybe the warranty will cover the repair costs for you.
hope this helps.
Aug 24, 2008 | Brother HL 1230 Laser Printer
Nintendo DS Lite Console Logo
23 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
