Question about Lexmark X7170 All-In-One InkJet Printer
Mono color I use Lexmark X7170 All-In-One to print my documents. I have scanned a color document and tried to print it.When I wanted to print this color document, Lexmark X7170 All-In-One prints it mono color (green). I have tried to fix this problem by checking cable connections; everything was normal.I have turned it off and then turned on and tried again.It was the same mono color document (green). I have reset the settings of Lexmark X7170 All-In-One to default (factory) settings but it also could not fix the problem. Would you please help me how I will able to solve this problem
  • burakmatur Feb 07, 2009
    No that's not right. these printers do contain black ink cartridge.There are 2 cartridges at the printer
  • 129 Answers
These models use a "3 colour" printing process. In other words, these printers do not contain black ink when the BC-05 colour cartridge is installed. To produce black print, a 3 colour printer mixes an equal amount of the three primary colours. This process is known as "composite" black.
As the ink in the cartridge runs out, one of the three primary colours will run out first, depending on the material that has been printed. After one of the three colours has depleted, this colour will be missing from the mixture required to print black, and the print will change colour. This is the indication that the cartridge needs to be replaced. Usually the remaining colours in the cartridge will run out soon afterwards.
Rate the solution as appropriate !
Posted on Feb 07, 2009
  • Amardeep46
    Amardeep46 Feb 07, 2009
    Yes you are correct. But you can swap the black cartridge for a photo cartridge for six-color printing. Please check you have a black cartridge and it has sufficient ink to print the documents. If it exhausted, The the printer starts using the tricolour cartridge.
How can I scan and fax 84 page document from the PIXMA mg7120?
that is correct, use the automatic feeder tray, but i am not sure if that machine can scan and fax all the 84 page continuously
Feb 12, 2015 | Canon PIXMA MG7120 Inkjet Multifunction...
I have an x7170 and the color printing is streaked. I just put in a new cartridge and it is doing the same thing...
Try this approach instead:
  1. From the printer operator panel, press Setup button > and then press Ok.
  2. Press the up or down arrow button until Clean Cartridges is highlighted, and then press OK.
  3. Press OK again. A page prints, forcing ink through the print cartridge nozzles to clean them.
  4. Print the document again to verify that the print quality has improved.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X7170 All-In-One InkJet Printer
I have a Lexmark 7170. I want to print a document from my computer. Unfortunately, when print is selected, the printer will perform as though it is scanning or copying. How can I get it to perform a print?...
Even though the Mode is on Copy on the Printer it would still print if you send a Job from the Computer!
Since When are you facing this trouble?
Whats the Operating System on this Computer?
Aug 06, 2011 | Lexmark X7170 All-In-One InkJet Printer
I have a lexmark 464de mfp. How do i setup scan to e-mail on windows 7 on this network printer?
Multi-function printers cannot scan and then e-mail the scanned image. They can scan and then fax a document.
You need to scan the document, then save the scanned image, open your e-mail program and create the e-mail then attach the image file (file attachment) to the e-mail before you send the e-mail.
Jul 08, 2011 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
I was wondering how to scan more than one page at a time with the x7170. also is there any way to save the scanned document as a microsoft document?
The Lexmark X7170 printer can only scan one page at a time. However, it has the capability of scanning multiple pages using either the scanner glass or through the automatic document feeder. Refer to the Lexmark X7100 Series User's Guide for more information.
For your second question, Yes, you have an option to save your scanned file to a Microsoft document as long as the Lexmark OCR scan software is installed on your computer. The scan software is only available on the installation disc (not available as part of the downloadable driver on the Lexmark website).
May 12, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Pls, how could i scan (Lexmark X7170), an article of 20 pages in one pdf file? thanks!
Go to Adobe Acrobat. Click on FILE. Click on CREATE PDF. Click on FROM SCANNER. Click on SCAN. You should now be scanning your first page, after completing it you will be asked if you want to scan any more pages or close. Select to scan more pages till finished. You can also select to have Acrobat do an OCR after the scan which will allow you to search the document. To do this, click on DOCUMENT, click on RECOGNISE TEXT USING OCR and click on START.
May 09, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have lexmark x7170 and windows vista with microsoft 2007...If I try to print a range of pages out of word, it prints one page, then deletes the priting on the rest. I've tried to re-install the driver a...
Hi. Lexmark has a patch for
resolving problem like printing a
multipage document. Here's the
link to the patch.
http://bit.ly/aMwdWR . Click on
patchformultipageUACissue2.0.exe .
Run the software in your computer.
Try printing a multipage document
again. Hope this resolves your
problem. Good luck!
Mar 14, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Won't print
The printe will not scan or print. When I fax documents it is recieved witha balck shadow in teh background. I get error 2200 when I try to print or scan.
Apr 03, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I can receive faxes but when I send them they are illegible.
make sure glass is totally clean and pad is clean, also could be an issue with your scanner bulb
Feb 04, 2009 | Lexmark X7170 All-In-One InkJet Printer
Only prints last page or least few pages of a ulti page document
if your taskbar displays printer icon on system tray double click on that & delete all privious prints.
select the text or area which you want to print. & give print command, & Click on print selection button & then Print.
Jan 17, 2008 | Lexmark X7170 All-In-One InkJet Printer
Lexmark X7170 All-In-One InkJet Printer Logo
203 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
