Back to:
Tags:
Sony CDX-GT100 CD Player
CD-Player Problems
By Cato - usenet poster
Okey, what i have is a 1994 Chrysler LSH w/Infinity Sound. I had just
bought a Sony CDX-GT100. Well, When i play the Radio, i get sound like
normal, but when i play a CD frm the unit it doesnt work. Also i have a
CD-Changer that i use but that is played through the Radio Frequency.
That also works.
Since i cant play a CD through the Acual Unit, but i can listen to the
radio, would you think it would be the Unit that doesnt work? or is it
the fact that (I Think it has) this car has a factory Amp?
Plz Reply ASAP...
V/R,
Mike
::Edit::
Well i found out that the Stock Amplifier is running on the Power
Antenna as a remote switch (Figured this cause when i turn off the
radio, Power antenna goes down and the Stock Amp turns off). Is it
possible to wire the Power Antenna to the Amp Turn on switch in the
harness?
jimbo_limited
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Beresford
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Um, yeah. I was TOTALLY going to go there next :-)
~Mister.Lull
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on CD-Player Problems:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Bouncy
Rating: 0%, 0 votes
HA! I'm not the only one this has happened to in a Chrysler! See the wire
you hooded up that says "Ant" switch it to Amp Remote :) The head in only
turning on the factory amplifier whe the radio is on, or as the head thinks,
when the antenna is supposed to be up :)
Don't fret Jimbo, freaked me out too at first, pissed me off more that I was
dumb enough to put it all back together because I did not have a CD in the
car. Just tested it with the radio :)
Chad
Thank You!
Solution #3
Not Rated (0)
Reynolds
Rating: 0%, 0 votes
So the CD is actually playing, it's just that no sound is coming out?
Or is it possible that the CD just isn't playing, and everything else
is fine with the deck?
It seems to me that no matter what you play through your deck, the
sound is going to come out the same way... I've never heard of a deck
being able to (for example) play from a CD out of only my front
speakers, but when I turn on the radio it comes out of the back; you
know? It sounds to me like the problem is that the deck isn't actually
playing the CD.
~Mister.Lull
Thank You!
Can you Help with these In Dash Receivers problems?
In Dash Receivers
I replaced my car battery last night. After replacing it,...
In Dash Receivers
I just installed an Alpine CDA-D852 into my 92 toyota...
In Dash Receivers
I have a cd player that will power on play for a short...
i installed an xplod cdx-gt100 in my truck and switched...
Loading problems.
Repair Service
Find In Dash Receiver Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
