Question about Dishwashers
Hi I have a kleenmaid dw3 dishwasher that will not wash it will go through to the wash cycle in economy [no prewash] and then it just stops. in day the dishwasher just started, weeks later. I hadn't realized it was still on as we usuallydon't turn the power button off. i'v put in a new timer but that made no difference. Can you help me, please! Sonya
  • 3 more comments
  • Sonya Tyrrell Feb 07, 2009
    Hi
    I read a note posted from liamkid posted jan 1 2008 it sound like our problems are the same.
    Cheers
    Sonya
    hi
    i'm not so good will electronics but i can readily purchase replacement parts for the machine.
    When it starts it clicks through the cycle like nothing is wrong and makes all the correct noise till it gets to the wash cycle then it just sits there. If I turn it to cancel 0 on the dial it will flick through the cycle and back to the start ready to be restarted. The detergant door opens when it should as it is resetting.
    Cheers
    The dishwasher is filled with water ready for use from our solar hotwater it is set to the kleenmaid recomendations so it is not too hot for the unit. I think the problem is that water is not going in. I have put water in the bottom prior to a load and it does the prewash on an cycle[not an economy cycle] and the water will go through the spray arms but the of coure it is empty and stops at the wash.
  • Sonya Tyrrell Feb 08, 2009
    I will test these things and get back to you if necessary.
    THANK YOU, fantastically quick responces
    Can anyone tell me where exactly the float[appearently inside cabinet] in a dw3 is. I'v found the switch and tested it it is OK. There is a silver button inbetween the heating element although I would assume it is a thermostat as all wiring is joined to the heating element. The bottom picture shows the silver button between the elements.
    At the moment it is on a wash cycle and running fine as I manually filled the cabinet with water. It always drains well. I've also tested the the filling water-inlet valves on ohms x1 with readings not changing at all! Is this the problem.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, I am tempted to think that there is no major component that would require replacement. At most would be the door close sensor/switch. May I suggest a simple test, jump the two wires leading to the switch and try. In the event that there would be 3 wires leading to the door switch, what is required to be jumped/shorted would be those that are normally open when the door is open and engages when the door is closed. To determine which is which, a conitnuity tester (DVM/VOM) would be required.
Good luck and thank you for using FixYa.
Posted on Feb 07, 2009
    President:
  • 2,559 Answers
A resistor on the control board(labeled R11) loosing contact at soldier joint, can disable some or all the options
  • Randy Hough
    Randy Hough Feb 07, 2009
    Also check the fill / float switch
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason for the problem could be
element.One of the element could have
got damaged.Replacing the element will
solve your problem.
try this out..
thank u..
  • 679 Answers
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
for more information go to below link>>
http://www.repairclinic.com/0088_9_1.asp#Level1_2
Thanks
  • rockfixya
    rockfixya Feb 08, 2009
    Happy to help you any time.
    Thanks for using FixYa.
  • Dishwashers Master
  • 13,433 Answers
If the cycle doesn't complete, check these:
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
  • Posted on Feb 07, 2009
    • 19,396 Answers
    Check that the water inside the machine it is heating up, if it is not heating, then that is the reason why cycle does not complete.
    • 1 more comment
    • Ginko
      Ginko Feb 07, 2009
      If the cicle gets stuck in the middle, that is often because the heating element is defective.
      The machine thermostate does not detect the right temperature had been reached and the cicle does not progress.
      In this case there is need to access to the heating element and test it for continuity, and eventually replace it.
      If you think that this had been helpful, then please rate the solution.
      Many thanks.
    • Ginko
      Ginko Feb 07, 2009
      To fix the problem you need to access to the heating element that is inside the machine.
      There you remove the element and test its resistance using a multimeter : Multimeter.
      If resistance is infinite, the element is bad.
      If element is good you need to test water inlet valve and impeller pump/water level switch.
      See also help from links below:
      How
      Dishwashers work
      Welcome to Stokes Appliance
      Stareast International Spare Parts List
    • Ginko
      Ginko Feb 07, 2009
      If water is not going in that may be more complicate to test and fix.
      Water comes from the faucet at the back through the inlet valve, that opens up when there no voltage .
      There is need to test the inlet valve by energizing it, and this must be done with live AC power in the appliance, therefore is risky, and should not be done by home user.
      You can alternatively check if there is water from the supply at the back, also check the floating switch, and eventually replace the inlet valve without testing it.
      This wont give you 100% chance to fix the problem, but it is the most likely cause when no water is getting into the machine.
      Check also that the floating sensor for the water level switch is not stuck in up position, that will cause same problem.
      Master:
    • 848 Answers
    Hi
    it sounds like a control or sensor problem.
    • gopinath pasupathy Feb 07, 2009
      your comment indicates wash impeller is stripped out or broken off. The wash impeller is
      attached to the motor & is what distributes the water through the
      pump & out the spray arms. I would recommend checking the wash
      impeller & wash motor assembly.
      Brigadier General:
    • 3,614 Answers
    better to clean all contact on the panel board. check all connections.
    • micromaster
      micromaster Feb 07, 2009
      try resetting it by turn off the power breaker for half an hour.
      check the door switch also.
    Kleenmaid DW3 dishwasher not running.
    HI,
    If there's no water entering your dishwasher, check these:
    Water-inlet valve
    Float switch
    Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
    Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
    Sep 12, 2008 | Dishwashers
    I have a Bosch Exxcel washing machine which is great but it bleeps for ever and a day when the wash is finished. How do I silence the beeps without having to get up?
    Switch machine on but do not program.
    Press and hold PREWASH button.
    After a few seconds it begins beeping.
    Keep holding PREWASH button in until beep gets quiet
    then eventually stops.
    Hope this helps - Colin, Billericay Essex
    Apr 11, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
    Whirlpool dishwasher stuck on prewash cycle
    the eprom memory is brocken,the main board must be changed.
    Feb 14, 2010 | Whirlpool 24 in. ADG7952 Built-in...
    How to replace a kleenmaid brandt dishwasher door handle
    Go to www.espares.co.uk
    Look for "Dishwasher Door Handle Opening Pedal" - Genuine spare part for select Blomberg and Hygena dishwashers.
    This is the part you need for a Kleenmaid/Brandt DW3 dishwasher.
    Jan 22, 2010 | Dishwashers
    User Manual of Asea Cylinda 1200 Dishwasher
    One of these was in my house when I moved in, still have the manual. Very efficient dishwasher.
    A is a prewash (machine will stop after it). Manual says it's meant to rinse stuff while you wait until you've filled the machine to run a full wash.
    D is economy wash. Water is heated according to the switch you select on the front.
    C is a prewash that will continue on to D (normal cycle). Water is at incoming temp.
    B is another prewash that will continue on the C etc (heavy cycle). Like C, water is at incoming temp.
    E is dry cycle. Heating element is on/off depending on switch on the front (dunno why you'd turn it off..)
    While turning the dial, push it in and it will stop exactly at the start of theach cycle.
    Mine has stopped emptying, think the pump has died, looking for a replacement..
    Apr 25, 2008 | Dishwashers
    Hello, this isn't a fix, but if you can't get the dishwasher fixed, I am interested in purchasing the cutlery baskets off you, if they are still in reasonable condition. Mine has plenty of breaks in the base and the handles poke through, which affects the lower spray arm rotation. Please reply through another post if you're selling. Thanks.
    Jan 01, 2008 | Dishwashers
    Dishwashers Logo
    71 people viewed this question
    Top Dishwashers Experts
    Mike Cairns
    Mike Cairns
