Question about 2wire Wireless-G 802.11g ADSL Gateway
Wireless set up problem - no gateway ip or limited connectivity
Have usb ADSL modem with orange broadband. Bought 2wire 1701 ADSL wireless router. Followed set up instructions up to the step where it says to go to explorer and type in the wireless router configuration address. My explorer doesnt find it? ALso windows is set to auto find ip and dns etc but it cant find the gateway and comes up with limited or no connectivity?
Heres the steps i took:
- Reset wireles router on back as per manufacturers instructions. Un installed previous modem form windows ( had to reinstall to contnect to internet today)
-Connected phone line from previous modem to wireless router, so only wire between router and filter on phone line box
- Checked computer was set to auto get ip address
-Checked available wireless networks, it picks up the 2wire238 router, connect and entered the network key.
- Computer then spends ages trying to find ip address, sometimes does but cannot get gateway? Then error bubble comes up about limited or no connectivty. It is at this point on instructions that came with router that it says to go to modem internal configuration page through explorer. BUt the address supplied the computer cant find?
Im stuck please can someone help me that knows?
  • 1 more comment
  • tania_tween Feb 07, 2009
    Explorer won't even let me go to that address http://192.168.1.1 so i cant check the DHCP?
  • Anonymous Feb 23, 2009
    i don t have the code
  • James Louie Puro
    James Louie Puro May 11, 2010
    the DHCP configurtion of the router must have been disabled.
    try http://192.168.1.1 on your browser address window...or check the user manual that comes with the router on how to access it via browser (IE , firefox.) this will diplay your router configuration page...and check for the DHCP if its enabled (it should be enabled) ....let us know.
    Sergeant:
  • 366 Answers
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Posted on Feb 09, 2009
I have my computers and laptop networked through my 2wire Home Portal 1000SW modem and am trying to connect my Coby Kyros MID8024 Tablet through wifi. The tablet finds my 2wire network but seems not to...
1st make sure that your using the proper WEP key (Wireless Password) 2nd make sure that their wirelessly compatible SW is a wireless b compatible to eliminate this issue you may also disable your WEP
majority of new technology uses wireless G and N
this wireless modem is a little bit outdated:
Data Link ProtocolEthernet , IEEE 802.11b , HomePNA 2.0 , HomePNA 1.0 , USB
see for your tablets protocol if this would match:
Aug 28, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Can I set this up this wireless router if I have cable internet and not DSL?
You CAN do this if you have access to the firmware of the ADSL gateway.
Connect cat5 cable from ethernet port on cable modem to ethernet port 1 on ADSL Gateway. (Must be port 1)
-Connect cat5 cable from computer NIC to other port on ADSL Gateway.
-(You may need to) Start->Run->cmd
ipconfig -release all
ipconfig -renew
Here's the trick...
-Open web browser, go to ADSL Gateway homepage (likely 192.168.0.1)
-Configuration tab, Advanced WAN->WAN
-Change WAN PORT drop down from DSL ATM PORT to ETHERNET PORT 1
-Click Edit button. Change Protocol from PPPoE to ROUTED.
-Radio button for DHCP Client to Enable.
-Click Set button.
-(You may need to) Power cycle both Cable Modem and ADSL Gateway device
Now this was done on a Westell ADSL gateway from verizon, yours may differ and you may need to look up the instructions for your specific gateway.
Aug 08, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
I have a 2-wire modem but the net will not work while plugged into a phone jack in another room. It does work when I move my desk top and connect to the jack, which is a PAIN. What do I need to do?
Not quite sure I understand this. Your modem (do you mean modem as in dial-up or do you mean ADSL router as in broadband?) works in one room but not in another. But your desktop works when plugged into the same jack!
please confirm that you are using broadband and not dial-up as the above makes no sense. Broadband is tied to a specific phone line & number. Dial-up works on any phone line.
Feb 12, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
ADSL ISP provides same address for IP and Gateway
Can you manually change the WAN IP on the router?  If so, give it an IP like 123.12.167.5 and set the gateway address to 123.12.167.1.  If it asks for a subnet mask, give it 255.255.255.0.
If she has a Linksys router, you may need to change the operating "MODE" on it.  A lot of Linksys routers have 2 modes of operation---Router mode and Gateway mode.  For her configuration, make sure the Linksys is in Gateway mode.  This will fix the NAT problem.
Cheers!
Mar 26, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Connecting 2wire modem./router to extra linksys router
to get this right you must make sure that the 2wire will be configured to be your gateway which means that the 2wire itself will be connected to the internet then set the linksys to DHCP mode because if you dont it will give you a router behind router error , make sure that the 2wire is properly authenticated and connected to the internet to make sure access the gui by typing gateway.2wire.net on your browser and run system set up wizard
Dec 11, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Can i connect a 2wire 2701hg-b with roadrunner cable internet ? I had the 2wire dsl with at&t but recently disconnected the service
It is possible but it may not work as a router (2 wire 270). The 2wired router only has a phone port and ethernet/usb for computer connection. So if you will connect the roadrunner modem to the 2wired, you can connect it to the ethernet port of the 2wire, but the 2 wire will not function as a router any more. It will work just like a wireless bridge. This one setup that you can.
May 02, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Wireless router
What is the make and model of your router?
What type of internet access do you have (DSL or cable)?
Are you connecting the computer with a cable or via wireless?
If you have verified that the cable connections are correct then I would try to power cycle next.
1. Unplug the modem, router and turn off the computer.
2. Plug the modem in and wait 5 minutes.
3. Plug the router back in.
4. Turn the computer back on.
Let me know the details for the above questions if we need to go further.
Dec 27, 2007 | 2wire Wireless-G 802.11g ADSL Gateway
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
1,294 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
noti13
Level 1 Expert
William Dehn
William Dehn
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
