Question about Compaq Creative Sound Blaster PCI 128 Sound Card
Build in sound driver not function
My cpu unit with motherboard spacewalkerMV421.3 cannot play sound,i want to install the driver but i do not have the motherboard installer cd anymore so how can i download the i get the soundriver on ethernet...can i download it?please...wish u can solve my problem..thank u.
  • raosgmysore Feb 07, 2009
    The audio system is slowed down and does not prouce the original sound track sounds and music. Consequently the Vido performance is also slowed down in tune with the speed of the audio. I want this problem to be rectfied. I need your guidance and help.
How i can install sound driver for compac presario a6613tu
Posted on Feb 07, 2009
Intel pentium 4 2.40ghz drivers
what drivers are you looking for? as the CPU driver would be installed on installation of the OS along with other generic drivers by Microsoft.
or have you switched out your CPU and not bothered to check if the CPU is compatible with the chipset? if so you have two options. by a new motherboard and chipset or buy a new CPU or build a new machine all together
Jan 08, 2014 | Computers & Internet
Can not install the hd audio driver for GIGABYTE EP43-UD3L The driver that came with the CD was installed but I got "new hardware" pop up and speackers were not functioning. I removed the...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
if you need more help with this post a reply
Aug 25, 2011 | Gigabyte GA-EP43-UD3L Motherboard
Seem to have lost the sound from my computer,it was there before but I think the kids have been playing again! Gigabyte GA73PVMS2H.Control panel says there seems to be a problem with the sound card and...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 07, 2011 | Intel Motherboard
Hi, I have Commell LV-672 MB and I have weird sound problems, its buzzing and making weird sounds when I dont do anything (listen music or whatnot). same is when I use the mic, that weird sound is like...
Open up your computer the speakers plug/outlet is usually at the back of the computer as is the microphone input
to check the lead attached to the rear of the input plugs make sure the connections are good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
Mar 21, 2011 | Intel Computers & Internet
Not play music in windows media plyer but vlc plyer is play music but sound not comming. what problem ?
also
hope this helps
don
Feb 26, 2011 | Intel IWILL P4S 845 Chipset Ultra ATA100...
No sound device
What is your motherboard type and model? If you purchased your computer a brand new unit,a CD installerforit device drivers shouldcome with it. If you have that Device driver installer CD,try installing from the CD device installer that came with your new PC.
Apr 18, 2008 | Computers & Internet
No sound device
I need to know the brand of the motherboard and its model/code number or model... then i'll know what sound driver is appropriate to your computer...
I'll wait.
Feb 02, 2008 | Intel Pentium 4 3GHz 512/800 CPU processor...
ASUS M2N-E SLI sound no longer works?????
Hi Mike,
It is possible when you reinstalled did you install the same version of windows? ie. x86 or 64bit it is possible during the installation process new drivers are updated.
Also, b/c of this fact your motherboard may have spdif out and if it does the drivers installed will be HD audio drivers so check the device manager.
If it is HD audio drivers and using spdif passthrough the only way to hear it is if you send it to a receiver or manual go into the sound module in control pannel and select a different sound source rather than spdif out.
good luck
smeags.
Jan 07, 2008 | ASUS K8V-MX Motherboard
Powering up but nothing happens ?
did you install the motherboard drivers using the CD which came with it?
Sep 28, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Compaq Creative Sound Blaster PCI 128 Sound Card Logo
69 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
