Question about Microsoft Wireless Laser Mouse 6000 v2.0
When I press the tab key it comes up with this ... asdqwe
Thats it really every time i press tab it writes asdqwe
  • 70 Answers
It could be that you have something in the keyboard, or more likely that the keyboard is broken. If it's a wireless keyboard, you could try changing the batteries.
Posted on Feb 07, 2009
Akash blocked my asus pc 2014 how do I unblock it
Couple of ways
1) ope computer in SafeMode with Networking by pressing F8 before windows screen.
then do a search with malware software
2) go into Safe Mode with Command Prompt
then enter c:\windows\system32\restore\retrui.exe
then press enter system utility comes up for a restart you set at earlier time. When system comes up do a malware scan an remve.
3) pressing F8 start this time in msconfig at command prompt. Open startup tab an uncheck the malware programes. Restart comp an do a malware scan to remove. Write down location in startup tab an remove your self
Jan 28, 2015 | ASUS Computers & Internet
Tip
How to save time on a PC
Time can be saved when repetitive tasks are performed by shortcuts instead of using the mouse.
In this tip I will be sharing a number of shortcut. I will not be sharing the most common ones.
*The windows key looks like a flag.
1. To see the desktop (minimize all the windows); Press and hold the windows key and then press D and release both of them.
2. To switch between windows; Press and hold Alt key and then press Tab key.
3. To Switch between tabs in a window; Press and hold Ctrl key then press the Tab key.
4. To close a window; Press and hold Alt key and then press F4 key.
5. To close a tab in a window; Press and hold Ctrl key and then press F4 key.
6. To open up Run; Press and hold Windows key and then press R key.
7. To select all text; Press and hold Ctrl key and then press A key.
8. To Undo; Press and hold Ctrl key and then press Z key.
9. To Redo; Press and hold Ctrl key and then press Y key.
10. To switch Users without completely logging off. Press and hold Windows key and then press L key.
11. To zoom in or out; Press and hold Ctrl key and press + or - key respectively.
+ being for Zoom in - being for Zoom out
12. To add www. and .com in the address automatically; First write the name of the site and then press Ctrl and Enter/Return together for an instant. For example to open fixya, you'll type fixya and then press Ctrl and enter together to bring in www. before and .com after the name.
13. To make a text go as a subscript or superscript. (MS OFFICE) Press and hold Ctrl and Shift key together and then press the + or = button to make a text go as a superscript. Press and hold Ctrl and then press + or = button to make the text go as a subscript.
14. To Save As; (MS OFFICE) Press F12.
15. To Save or overwrite save; Press and hold Ctrl and then press S key.
16. To make a hyperlink; (MS OFFICE) Press and hold Ctrl key and then press K key.
The following shortcuts can be used on other softwares as well, such as internet browsers, wherever there is a text in short.
17. To copy a text; Press and hold Ctrl and press C key.
18. To cut a text; Press and hold Ctrl and press X key.
19. To paste a text; Press and hold Ctrl and press V key.
These are the shortcuts of the tasks which are performed almost daily.
on Apr 06, 2010 | Computers & Internet
Changed VGA settings. When computed boots up I get a black screen. A small box displays the MSG - MODE NOT SUPPORTED. Is there a way to change the mode from the TV?
1. Let's power the computer off in order to boot it into "safe mode."
2. Restart your computer and start pressing the F8 key on your keyboard.
3. You will be presented with the Windows Advanced Options Menu that contains several options to choose from. In this case you will scroll down using the down arrow on your keyboard to the option, "Safe Mode" then press the "Enter" key on your keyboard.
4. The next screen should display "Please select the operating system to start:" typically the name of your version of windows will be displayed and highlighted in white, I recommend you just press "Enter" on your keyboard at this screen.
5. Now you will see a bunch of white writing scrolling about your screen and after a few moments you should be able to login to Windows.
6. You may receive a prompt asking if you really want to boot into Safe Mode. Choose Yes.
7. Once Windows is fully booted, you will be in safe mode.
8. Now right-click on the desktop
9. Choose "PROPERTIES"
10. The "DISPLAY PROPERTIES" menu will come up, then press on the "SETTINGS" tab
11. In this tab you will see a slider bar that can be slid from left: (Less) to right: (More). Slide the tab to the left toward the "Less" option. After positioning the slider to a lower screen resolution be sure to press "APPLY" then "OK" on the bottom of this menu
  • Usually a 1024×768 screen resolution will be sufficient for most monitors.
12. Now reboot your computer as you would normally and that lovely "VGA not supported" message should be long gone.
May 09, 2011 | Insignia NS-LCD19 19 in. LCD TV
I forget my unlock security code nokia 1280
i forgot my nokia 1280 security code how to unlock it
Jan 29, 2011 | Nokia 1280 Cell Phone
I would like to disapear from facebook. How do I do that? Thanks Adelino
enter your account then on your upper right enter account and press help center.on the search tab write"how do i permenantly delete my account.and it will ask you are u sure press yes and u r ready.thats it
Nov 28, 2010 | Facebook Social Network
How do you clear Tab's
Tab to the position press tab clear. Perhaps the tab you can't clear is really the right margin, to move that tab to it press and release the margin release key, space to the location you like, press R. mar.
DickyO
Apr 20, 2010 | Nakajima AE-830 Typewriter
How do i hook up wireless internet to a playstation 3
go to the settings tab on ps3 go to network connections then look on the back of your modem and #'s in [ ] write it down cuz thats your wep key u need that 4 everything and put that number in the wep key space on ps3
Oct 22, 2009 | Sony Playstation 3 (PS3) Console
Predictive text comes onto phone automatically every time I write a message-how can this facility be cancelled?
menu >> messages >> write message >> options >> writing language >> Dictionary off
or
Press and hold the # key
May 23, 2009 | Nokia 3310 Cellular Phone
Right side of keyboard letters prob.
you've got the number lock on.....find the key thats says num lock and press it once when you have this problem
Dec 09, 2008 | Compaq Presario 700 470024-192 Notebook
Margins will not reset
Return to the stopping point, press and release the mar. rel. key backspace to the left then press L. mar. key.
To clear tabs tab all the way yo the rt. press & hold tab clear touch ret all tabs should clear.
Hope this is helpful
DickyO
Jul 11, 2008 | Nakajima AE-740 Typewriter
Microsoft Wireless Laser Mouse 6000 v2.0  Logo
220 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
