Question about ASUS Computers & Internet
My laptop lcd is dim
How will i brighten the lcd of my laptop i still can see it but it quite to dim...the keyboard is not functioning (bright positive) so i wonder is there any other way to brighten it aside from pressing the keys?
    Scholar:
  • 127 Answers
When you press the keys did you press also the Fn key (usually sets beside the window key.)
it should be Fn + bright positive key. you need to press both...hold fn then tap the bright positve key.
or right click on desktop
go to properties (if you have an intel chipset or other VGA chipset) you will see a Tab with the title of your VGA (like Intel Graphic Media ....) click on the tab, from there look for a button in which you can change the graphics settings...it will give a a new window which you can change color, brightnes, gamma etc..
hopes this helps, please rate.
Posted on Feb 07, 2009
  • 2 more comments
  • James Louie Puro
    James Louie Puro Feb 07, 2009
    also note that running the laptop on battery mode will make the LCD darken.
  • James Louie Puro
    oops i mess up....it should be display properties >> advance button...then the instructions above...sorry about that.
  • James Louie Puro
    Right click on desktop >> properties >> settings tab >> advance button.
  • Kate McBride Sep 07, 2013
    I went through every solution offered and YOURS was the only one that was truly helpful. You explained about the fn button which nobody else did and that made the difference. thank you. You also offered alternatives. YoBrideur explanation was wonderful. Very helpful. Thank you Kate Mc
The monitor screen is not bright enough to read information can I brighten or enhance? Is there a function key on the keyboard that will allow this?
Try holding the function key & tapping the Home button on keyboard:
Fn + Home - The computer display becomes brighter.
If this doesn't get it bright enough then perhaps the LCD backlight is dying. Easier to replace the whole screen than just the light.
Good luck.
Feb 20, 2013 | IBM ThinkPad Computers & Internet
How do I turn up the brightness on a HP Probook 6550b?
PLEASE RATE ME!
go to the search icon under start. search brightness. it will tell you step by step what to do.
Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function key (abbreviated as "Fn") and pressing the up or down arrow keys as shown in the picture below, increases and decreases the brightness.
May 09, 2011 | HEWLETT-PACKARD HP ProBook 6550b Notebook
Why is the disply dim
you can brighten your display by using right click and go to graphics properties....u can change your brightness.....also u can find brightness keys on you keyboard...search for symbol loks like a sun on your keyboard.....n press Fn and the same...hope your laptop brightness increases..
Mar 08, 2010 | HP Compaq Presario V2000 Notebook
My screen is dim. What causes this?
Most likely your settings.
In most cases, the LCD is dim when not plugged into an outlet to save energy. (It can make the laptop stay on an hour longer in some cases)
If you want to brighten the screen, and kill your battery time in the process, hold down the FN (function key) and press the button with a picture of a sun and a arrow pointing up. (both pictures should be light blue on your keys)
If you don't mind the dimness of your LCD, leave it alone. The brightness will return when you plug your laptop into an outlet.
Jan 08, 2010 | Dell Inspiron 9400 Notebook
How do you make the lighting on the screen brighter without the charger in ?
The screen will automatically dim slightly when it is on battery power, this is to conserve battery power. For maximum brightness connect the power adapter into the laptop.
On the Thinkpad laptops you can adjust the brightness by pressing and holding down the blue Fn key plus the Home key to brighten or the End key to dim the screen.
Nov 26, 2009 | Lenovo ThinkPad T61 Notebook
My laptop screen is very dim, cannot read or see looks faded
Try using the brightness controls on your keyboard to brighten the screen. If that doesn't work then that means either the lcd or the inverter has gone bad.
Apr 14, 2009 | Computers & Internet
MY A100 LCD SCREEN IS VERY DIMM WHEN VIEWING DVD howto brighten
You can brighten or dim the LCD screen by pressing the Fn key plus another key with the a sun symbol eg the UP & DOWN arrow keys or one of the F3 to F12 keys - it varies depends upon the model of the laptop.
If you cannot vary the brightness of the LCD screen the you have a faulty backlight.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Display brightness
Ok on your keyboard there should be some way to adjust the brightness just plug in the laptop and adjust it to what you want then unplug the laptop and adjust it to what you want and it should keep that setting. if that does not work you can check the bios settings some laptop bios' have a brightness option.
Dec 06, 2008 | HP Compaq Presario R4000 Notebook
Brightness
You have a blue key that says FN (stands for function) on the bottom left side of your keyboard, next to control and shift. The brightness and dimming hotkey is usually on the arrow keys or up on your f row, f1-f12 and you'll see like a sun and half sun in blue, same as the function key. While holding that function key tap keys you found and it'll brighten and darken. If it doesn't, you may need hotkey software installed, a new LCD (backlight may have failed) or inverter which powers the LCD.
Oct 26, 2008 | Toshiba Satellite A25-S207 Notebook
Computers & Internet Logo
395 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
