The text on my pc keeps going blue, how can I stop it?
Windows allows you to change the themes of your computer. This includes the wallpaper, the screensaver when your computer is idle, any noises it makes, and even the color of the toolbars and windows. Sometimes, however, when you restart your computer, the theme will revert back to the Windows default theme, which is called Aero. This can be because you have not disabled Aero, because your performance settings are using too much energy, or because your screen resolution is too high or low for the theme you are using.
Screen Resolution b> The higher your screen resolution, the sharper the images and text will appear. Sometimes, however, the of the wallpaper for the theme is not the same as the screen resolution. This can cause your theme to revert back to the default. To fix this, click the "Start" button. Then click "Control Panel." In the "Control Panel" window click "Adjust Screen Resolution" under "Appearance and Personalization." Select the resolution that is the same as your wallpaper. b> Performance Settings b> If your computer is running on high performance settings, your computer's energy will be used quickly and Windows may automatically change the screen saver to keep the energy from running to low. To change your performance settings, open the "Control Panel" and click "System and Security." Then click "Change Battery Settings" under "Power Options" and select "Power Saver" or "Balance." b> Disable Aero b> Aero is the default theme setting for Windows Vista and Windows 7. If you try to change your theme and it reverts back to Aero, it is because Aero is still not disabled. To disable Aero, right-click on your desktop and click "Personalize." A window of all the themes on your computer will open. You will see "My Themes," which are any themes you have created, and "Aero Themes" under it. To disable Aero, click "Save Theme" under "My Themes" to make your current settings default, or select one of the themes under "My Themes." This will make that theme the default. b> Troubleshooter b> If you still cannot figure out why Windows changes the theme back to the default after restarting, you can use Windows's built-in troubleshooter. The troubleshooter will find the source of the problem and automatically fix it for you. To use the troubleshooter for your theme, open the "Control Panel" and click "System and Security." Then click "Troubleshoot Common Problems." Under "Action Center," select "Appearance and Personalization." The troubleshooter will run. When you restart after it completes its action, your theme should stay the same. Hope this helps.
b>
