Question about Maxtor DiamondMax® 6800 10 GB ATA-66 Hard Drive
It possible to run 2 differant os on 2 differant hd on 1 compute
Wondering if possible to have 2 drives with differant operating systems to be installed and run on one computer,if so how do i do it.have windows me on one hd and windows xp on other hd. computer is a compaq presario with windows me installed on it.windows xp is on d2046 emachine that is dead but want to save whats on drive.
    Scholar:
  • 127 Answers
To be honest, im not sure if its possible....you can only do it using dual boot but it only uses a single hardisk with 2 separate operating system.
how to make a dual boot can be found here
supported dual boot configurations here
if you need more information, please let us know
Posted on Feb 07, 2009
  • James Louie Puro
    James Louie Puro Feb 07, 2009
    the only possible thing with this is to set the bios to boot on the first hardisk to load ME first...and change again the bios to boot XP first...
    you can try also tapping F12 while the system is rebooting then choose your boot device.
When turning on it starts acting like it is gong to windwow start screen then nothing but a blue screen
Possible Reasons
1.Faulty Hardisk drive
2.Faulty Ram
3.A corrupt Operating System
Solution
1.format your computer and or run a windows restore under windows recovery options,if it doesn't work
2.Change ur ram
3.the last option changeb ur hard drive if all solutions stated above does not your computer glicth
Happy Repairs! Cheers!
Sep 15, 2013 | Dell Inspiron 1318 Notebook
Hi. Im changing my internal hd in my netbook. Im wondering if it can support a 1tb hd.. I have a gateway lt21 series and it was running under a 250gb.. Thanks
well the size of drive has a few issues that need clarification can you provide actual model number from under the netbook and operating system. Also what 1 tb drive are you considering. There is a subtle difference among them and not universally exchangable(no matter what they say)
let me know this information and then we'll find a quick answer
May 23, 2012 | Gateway Computers & Internet
My sony vaio pcg-551l won't go past "no operating system"
If this is the first time your trying to start up this computer try to restart it. Sometimes brand new laptops can fail to find the operating system on first startup. If this isn't the case it sounds like your Hard Drive is either disconnected or has had a critical failure.
Mar 15, 2011 | Computers & Internet
I have a Maxtor 3100 100gb external HD and tried to backup my computer and it would only backup 4gb. I got a message that if the HD is formatted in FAT32 it would only backup 4gb. I need to backup about...
1. Please connect you external HD to your computer
2. Fat32 can only handle a limited amount of data
3.Go to the Control Panel
4. Open up Administrative Management
5. Open Computer Management
6. Open Disk Management
7. In the denter panel you will see your Maxtor expressed
8. Right click on the drive
9. Click format
10. Choose NTFS
if not given the coice, it will usually format to NTFS anyway, but get smart, explore Disk Management and make sure
11. I'm giving a general scenario across 3 different Windows OS Sytems
12. When you tell us your exact Operating System, we can be more helpful
TheSelkie
Oct 04, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
When trying to start my computer emachinesE627, i have a black screen that says error loading operating system
The computer can not see the Operating System. This can be caused by several things, so I will just list a few possiblities for you here:
If you have a USB flash drive or external HD plugged into the PC. Remove it while the computer boots. Some machines are set to boot from a flash drive and will search for an operating system on it and display NO OS if the bios can not find one.
If the Hard drive has been removed or replaced recently then the Jumper settings may not be correct on the new drive.
If the computer was having trouble booting periodically, freezing or experiencing blue screens before this message, then you may have HD corruption or possible disk failure. With HD corruption you only need to run chkdisk /p within recovery console in XP or run the Vista recovery center with vista. HD failure is a dead disk, no option but to replace.
Bad RAM or a dead CMOS battery can also cause this type of failure. So check these also.
This can also be caused by a damaged master boot record or primary boot partition. Run fixboot or fixmbr from the recovery console on XP or just run the Vista Boot Repair Console in Vista
Worm Viruses and Rootkits that damage the primary boot sector or the Master Boot Record can also cause the OS to mysteriously disappear. So if none of the above sound like they are for you, then you can try looking for one of these on the affected drive.
Hope this helps,
Gill
Aug 28, 2010 | E-Machines eMachines Monitor E15T4
Need instructions on setup & config for an external hard drive
the space is being used for virtual memory, there is nothing u can do realy to claim it back
unless u delete the partition and format it using another pc with disk managment.
Aug 17, 2009 | Western Digital Passport® WDXMS3200TN...
Does not show up in my computer but does in bios
Can you boot the computer from a boot floppy?
If so, try and partition and format the drive with fdisk and format.
May 20, 2009 | Maxtor DiamondMax D540X (4D060H3) 60 GB...
Insataling windows xp problms
i believ ur using 32 bit operating system.change the boot sequence by pressing F12 at restart and select cd/dvd rom option while the windows cd still inside the drive,,format the c drive completely{if possible format the whole hdd} and then reinstall the windows os xp..i hope it will work fine,,just follow the screen prompts very very carefully and u will find everything mentioned,,best of luck
May 14, 2009 | HP Compaq Presario CQ60Z Notebook
I have an HP Netserver LH3 with 2 processors, 512MB memory, and RAID 5 array. Someone took the drives out of the machine, and the sides off of the box, and tried to blow the dust out using canned air....
if you removed the drives in a RAID 5 array and did not get them reinstalled in the proper order and your OS was on your array .. your toast ... well leastwise a modest amount of testing will be required ... how many drives ?
if you have 3 .. there is 6 possible combinations; 4 - 15; 5 - 31 ..
If it were me and important data was on the system w/o a backup .. I'd go though the task of trying all possible combinations.
easyiest way .. put a masking tape tag on each drive each with a different number .. create a chart based on the number of drives .. like
3 - 2 - 1
3 - 1 - 2
1 - 2 - 3
2 - 1 - 3
1 - 3 - 2
2 - 3 - 1
go through all possible combinations and attempt to boot ..
if you have a backup and or the data is not important .. recreate the array and reinstall the OS ..
Jan 06, 2009 | HP NetServer LH3
Can't find OS
Even if you set it to slave, what has happened is the drive motor is burned out. Lets face it, your HDD is dead and there is no hope of recovery unless you take it to a data recovery shop, and that is $$$$.
The No OS message is the worst message you could possibly see and that is a direct indication that your HDD is dead in the water.
Just go get another HDD or go buy XP to replace ME on that other HDD you have.
Realistically there is nothing you did or didn't do to cause a harddrive failure. It is just the way of the world nothing lasts forever...
Sep 04, 2008 | Maxtor DiamondMax Plus 6800 (91366U4) 13.6...
Maxtor DiamondMax® 6800 10 GB ATA-66 Hard Drive Logo
85 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
