Question about Baumatic B720 Electric Double Oven
Baumatic 720 Double Oven - Door has come off hinge.
One of the hinges has come out of the oven. I am unable to replace it or remove the other hinge. Any assistance would be appreciated.
  • Baumatic Master
  • 3,463 Answers
If you got to:
Then click on youtube videos, and in the search box type in: fitting oven door hinge, you should be able to get all the info you need to help solve your problem.
Please leave a fixya rating for my suggested solution.
Posted on Feb 08, 2009
Inner glass has fallen out
Have an appliance repairman check if the oven is still under warranty and if any recalls on the door are in force.
Dec 17, 2017 | Baumatic B180SS And B60SS (Bundle)...
Front door as come away
Do yu mean the front door has pulled off it's hinges on one side or both ? if you hold the door on a angle about 12" open then press down towards the floor it will go back into place , if not you may have bent the hinges and the will have to be replaced
Dec 17, 2011 | Baumatic B904SS Stainless Steel Electric...
The oven door doesn't quite close properly. Thought it may have something to do wit the hinges but upon inspection I was unable to unscrew the the hinges to get a good look. Possibly could be the seal. I...
It sounds like the hinges may be going bad on you. You can inspect them if you want to.
  1. First pull out the broiler oven.
  2. Now you can lift up on the oven door and remove it.
  3. The springs in these hinges have a lot of tension in them. Please be very careful when doing testing the hinges.
  4. Now take a pair of pliers and carefully grab the hinge and pull it towards the the oven.
  5. The hinge should be able to set itself up against the frame of the oven itself. If it does not then that hinge will need replaced.
  6. Check the other hinge.
  7. I am willing to bet that at least one of the hinges needs replaced.
Mar 23, 2011 | Ovens
Door to oven does not close completely - how do I access the door hinge to check or replace it?
Open oven door. Flip metal holder down at hinge to lock hinge. Lift door with hinge attached up slightly and off oven. Reverse to re-install door, making sure notch at bottom of hinge is hooked in frame of oven properly.
Jan 02, 2011 | GE JTP45 Electric Double Oven
GE Oven door lock 'engaged' while door was open and door will not close - how do I release the lock?
If your oven door has gotten bent or warped (maybe you rested something heavy on it...), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up. If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Dec 06, 2010 | GE JTP27 Electric Double Oven
How do I remove the oven door
Welcome to FixYa.
Most if not all Thermador owners manuals have this outlined in them, however, here you go.
Removing the Oven Door
  • Fully open the oven door.
  • Raise the U-clip over the hook on each of the hinges to the "locked" position (see illustration below). This will prevent the hinge from snapping closed when the door is removed.
  • Grasp the door by the sides toward the back. Raise the front of the door several inches (there will be some spring resistance to overcome because of the hinge being locked). When the front of the door is high enough, you will be able to lift the hinges to clear the indents.
  • Pull the hinges out of the slots in the oven front frame.
To Replace the Oven Door
  • Grasp the sides of the door at the center and insert the ends of the hinges into the slots in the oven front frame as far as they will go (see illustration below).
  • With the door open all the way, lower the two locking clips.
  • Raise the oven door and make sure that it fits evenly with the front sides.
**CAUTION** With the door off, never release the levers and try to close the hinges. Without the weight of the door, the powerful springs will snap the hinges closed with great force.
Let me know how you make out or if anything is unclear. Thanks for choosing FixYa.
Good Luck,
Macmarkus :)
Sep 01, 2010 | Thermador SMW272 Electric Double Oven
Doors don't shut all the way and light stays on
It sounds like your door hinges are worn, usually on older ovens due to weight of door. Most oven doors can be removed by simply raising the tabs/ fitting small screwdriver on both hinges(refer to user manual) etc. Once door is removed you can place a medium size screwdriver or similar in the hinge slot, pushing the hinge plate on the bottom in an outward direction, thereby bending this plate(very slightly) forward. This will make the door close fully, activating the door switch, and turning off the oven light. This is only a short term solution, as this hot air escaping can lead to further problems. Hinge pair will need replacing. Door hinges are spring loaded ALWAYS KEEP FINGERS AND HANDS CLEAR OF LOADED HINGES.
Sep 18, 2009 | Jenn-Air JJW8230D Electric Double Oven
Hinge broken on baumatic double oven door can it be replaced
Yes it can, no ptob, but you will need to replace the pair, otherwise it will not close properly.
POlerase rate my solution.,
Jul 16, 2009 | Baumatic Ovens
Replaced hinge on smeg double oven but now oven doesn't heat
I have the SMEG F170-5 and had this problem after cleaning and replacing the door. It wouldn't heat unless I banged it shut. This action made the internal switch trigger, so I had to remove the oven (4 screws, slide out) and remove the right side panel (4 screws). The switch is actuated by the right hinge strut and it must have become bent slightly. I bent it a bit towards the door so that it would just a little bit more likely to make the switch trigger with the door closed and it now works fine.
Jun 12, 2009 | Smeg S351X/5 Electric Single Oven
I need to remove oven door, cant figure out how
drop the door down as low as it will go look carefully at the hinges as they pass through into the oven chassis you will see a clip on each one that you lift up to lock the hinge you usually lift them up as far as they will go then this will lock the hinges as you close the door the hinges will come away from the oven complete with door.... reverse to refit.
May 06, 2009 | Bosch HBL 755 Stainless Steel Electric...
Baumatic B720 Electric Double Oven Logo
1,079 people viewed this question
Top Baumatic Ovens Experts
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
