Question about Pinnacle Dazzle DVD Recorder
Capture how do i set up studio 11 to capture on my second hard drive? thanks
  • Anonymous Mar 17, 2009
    how do u do this though
  • 27 Answers
We do recommend to capture in your Internal Hard driver first then transfer it later to your external hard drive. To avoid any eperience like video and audio is not sync or dropping frames.
Posted on Mar 05, 2009
I have the Moviebox USB (the Porche design) I'm running Studio 14 on windows 7, but it wont detect my moviebox? The pc tels me it works fine, but the Studio wont detect it. I have tryed the hardwaredrivers...
I have the same problem. If you have an earlier version of Studio (i.e.; Studio 12) with which Moviebox USB works, then retain that version for capture. For all else, use Studio 14 by retrieving your captured footage from your hard drive.
Aug 20, 2010 | Pinnacle Studio MovieBox USB Video Capture
How do i hook my pinnacle to my ps3
To capture in Studio you need to know what type of device you will be capturing with.
There are 3 types
  • USB devices (like the 710&510 USB, and the Dazzle DVC 150 etc)
  • PCI cards (like the Movie Board, Movie Board Plus, 700&500 PCI)
  • 1394 cards
All these devices are setup in the same place in Studio but you will need to know what you have so you can make the right selections in the Capture source settings window.
To get to the settings window, hit the capture tab at the top of the screen from anywhere in Studio.
Note: When you go to the capture tab, if you have not changed the settings you may get a message saying it does not detect a DV camcorder.
When you hit the Settings button it will bring up this screen. Hit the capture Source tab. This is the capture source screen. This screen allows you to change what device Studio will use to capture. Notice the default is DV camcorder.
You can read the next step to hook your pinnacle up to youe PC reading the link below:
http://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=219835&Hilite=hook+piinacle
Hope it helps.
Mar 21, 2010 | Pinnacle Studio Version 11 for PC...
No sinchronization between video and audio
Please check this link if this could help to you.
http://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=239257&Hilite=video+and+audio+out+of+sync
By the way where your video clips coming from? Importing or captured? If captured how did you connect your camcorder to your computer? How about the settings you used for capturing? In the capture mode>settings>capture format> did you choose mpeg1\2 or AVi? IF AVI kindly change it to MPEG. Let me know what did you make by replaying here.
Sep 27, 2009 | Pinnacle Studio Plus Version 11
Cant capture audio anymore from studio 10
Holly wood effects are locked. I want hollywood effects keys.
Plese Send
arundixith@yahoo.co.
Thank You.
Jan 07, 2009 | Pinnacle Studio Version 9 for PC
Recording stops within 10 minutes
Hi G-DyBiec
If the video capture automatically stops capturing at approximately 18 minutes (17 minutes and 55 seconds), then most likely the drive that is being capture to, is formated using Microsoft's FAT32 file system. Microsoft's FAT32 file system has a maxium file size of 4 GigaBytes (4 GB), which equates to a DV video clip of nearly 18 minutes. (18 minutes = 1080 seconds, @ a data rate of 3.6 MB/sec is approximately 4GB). So for hard drives that are formatted using FAT32, this behavior is normal. This is not a limitation of Studio..
To see what file system your hard drive uses do the following:
1. Right click on the Start button and choose Explore
2. Under My Computer, locate and highlight the drive you are capturing to
3. Right click and select Properites
4. On the General tab, towards the top, it will say "File System". It will be listed as either FAT32 or NTFS.
There are a few solutions if your drives are formatted using FAT32:
  1. Convert your FAT32 hard drive to NTFS *
  2. If you can copy any important data from this drive to other drives, it may be faster to re-format the FAT32 drive using the NTFS file system. **
  3. You can do multiple 18 minute captures and string them together in the Edit mode of Studio.
    • Since the first 18 minutes is already captured, rewind the camcorder or VCR to 5 - 10 seconds before the initial capture stopped (which can be edited out later in Studio).
    • Start a new capture to a new file name.
    • Repeat this process until all the desired video is captured from the tape.
    • After all the files have been captured, go to Edit and assemble the captured files from the Album to the timeline in the order you desire.
This is a manual method to workaround Microsoft's FAT32 file system and if this is too time intensive for your needs, then steps 1 and 2 above may be more suitable and should be considered.
* Note: If you need assistance with step 1 above, go to the Microsoft web site at http://www.microsoft.com/ and search on "convert FAT32 to NTFS".
** Note: If you need assistance with step 2 above, go to the Microsoft web site at http://www.microsoft.com/ and search on "how to format a drive in XP".
NOTE: Microsoft's NTFS file system is only supported on Windows 2000, Windows XP and Windows Vista. NTFS support a file size of 4 TB (terra bytes), which is larger than any current consumer hard drive capacity, so if NTFS is used, the capture file size will only be limited by the size of the hard drive.
Aug 13, 2008 | Pinnacle Dazzle DVD Recorder
Product Serial Number for Pinnacle Studio Version 10?
i lost my serial number for pinnacle 500 usb version 10 please can you help me get another one
Jan 12, 2008 | Pinnacle Studio 500 (613570217053) Video...
Unable to Capture Video
i think you need to adjust the settings of the firewire capabilities..try adjusting things in the camera, then in control panel, then finally in the programs themselves.
Jan 11, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Pinnacle
Try deleting your Auxillary temp files.
Oct 29, 2007 | Pinnacle (210100320) Video Capture
My harddrive will not save files larger then 4 GB
What is the filesystem format on your external hard drive? there are limits on certain file systems, like maximum size of a single file in fat32 is 4gb. let me know the filesystem on your external hard drive and i will try to consult a few friends for you. regards
Apr 18, 2007 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Pinnacle Dazzle DVD Recorder Logo
309 people viewed this question
Top Pinnacle Computers & Internet Experts
Alun Cox
 Ian Kayhan
Ian Kayhan
Josh Levin
Josh Levin
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
