Question about Waring Blenders
Need to replace "Post and Coupling" on Waring 32BL39
Anyone know how to replace the "Post and Coupling" on an old Waring 32BL39. I can't seem to detach the Motor when I unbolt it from the housing. Any hints or help would be appreciated.
Easier than I thought. Simply unscrew it. Never thought it would be that easy
Posted on Feb 08, 2009
How to replace waring blender 028538 drive coupling
Check and see if your blender was made in China.
If so, the chances are really slim for a finding parts for a fix.
If it was made in the USA, try "e-bay" for parts.
If you need a parts list, you will need to find one first.
Also, type Waring Blender into your search engine on your computer, to see if a dealer or repair place has a web-site.
God bless your efforts.
Sep 16, 2016 | Waring Blenders
The coupling spins on my Waring Pro SDM50 2-Speed Blender, but it can be stopped by hand and does not spin under load. What is wrong and how do I fix it?
The most likely cause here is the motor brushes are going bad. That is dependent on how old it is and how many times it has been used. If this is new it should be replaced under warranty.
Apr 27, 2016 | Waring Blenders
Replacement end coupling
Possibly an appliance parts supplier can help.
Nov 27, 2013 | Waring WSB40 Blender
Replacing washer underneath glass jug Waring pro blender PB20CXU
The bottom of the container should unscrew to expose the washer
Jun 27, 2013 | Waring Blenders
How to disassemble krups gma1 blender
Myron's tip about the need to unscrew the grey rubber coupling is correct, but I was unable to grab the post and hold it still, even though I was using narrow needle-nose pliers. I just could not get underneath the rubber coupling. I ended up cutting the rubber piece off the steel cord inside the coupling, which exposed the threaded post. I could hold the post stationary from above while I unscrewed the steel cord. My old coupling was stripped and worn out, so it did not matter. A new coupling can be ordered cheaply.
I found that it was not necessary to open the housing of the whole appliance as long as you can hold the post stationery. And even if you can't grab the post from above, opening the housing won't help because it won't come off until the coupling is removed at the top.
If you need to open the appliance for anything else, Myron is right, you need to remove the 4 rubber boots on the bottom to expose the screws. The screws are so-called temper-proof screws for which you need a special screwdriver. The screws are called "pin-in-head-star". But removing the 4 scows is not enough. You also need to unscrew the coupling at the top.
Jan 06, 2013 | Krups GMA1-42 Power Xtreme VI Work Top...
Hi I've got an old Waring 38BL31 which is leaking underneath - looks like it might be a washer problem, but I can't unscrew the blade - anyone know what the trick is - or anywhere that repairs these?...
Hi!! It sounds like the rubber seal is busted, there is not real trick to removing the blade assembly. It will be easier if you have a belt wrench, it looks like the oil filter wrench but with a wide rubber belt instead. Available at most auto parts stores. If not available, just have to apply enough force to unscrew it. Having a friend will help, one holds, one twists. It unscrews counterclockwise.
Good Luck!! Don't forget to rate this post!!
Sep 20, 2010 | Waring 700G Work Top Blender
The gear at the base of my waring bb 180s blender is stripped
You can try the sears online parts store for help they may be able to get the parts you need as they are pretty much the same. iF YOUdon't find it let me know and I will resurch it for you and find the part it is eather the druve nut has come loose or the teeth on the plastic shaft has worn off, it is possible to super glue it to hold if you cant find the part.
Nov 12, 2009 | Waring BB180 Work Top Blender
Waring P320CX blender parts required
Hi - there is a website called nisbets.co.uk that has all the spare parts for this Waring blender, plus a great diagram which is much better than anything in the blender instructions.
Jun 05, 2009 | Waring MX1000R Blender
I have a Waring Pro Speciality Blender. After only a few times in use, the jar began leaking and I noticed glass shards around the outer rim of the jar. The blades are fixed on this model. I wrote to the...
If you don't see a physical crack or stress line on the jar, the issue could be either the gasket or blade assembly - Waring doesn't list any parts for sale for this model, but you may be able to call them and get these parts. There are not very many reviews on this particular Waring, so I am working with very limited information (and this is just my opinion), but the few that I have seen suggest that this might be the worst blender Waring ever made (in general, though, their blenders are usually top-notch).
Consumer Guide generally rates it high, but issues this:
"Cons: Strong churning motion requires you to hold the lid in place to prevent leakage through the top and limits the ingredients capacity, especially for hot mixtures"
The sites that invite the most user input into the rating generally give it a 2-star rating.
Waring seems to have escaped somewhat from their usual blender shape - and I have even heard that the shaft is made out of rubber, which is frightening.
Mar 31, 2009 | Waring RB75 Specialty Blender Stainless...
Replace clutch assembly Waring BB150 Blender
Remove the little rubber feed on the bottom of the base (they might be glued a bit so be careful not to rip them). This will reveal 4 phillips head screws...remove them...this will open the base and reveal the back site of the rotor. In the middle you will see a turban blade like wheel with a large flat tip screw. Wedge a large screwdriver between the teeth of the old clutch so that when you turn the flat tip screw it will stop rotating the other end. Turn the screw with some force to the right to losen the clutch...then do the reverse to get the new one on tight...put everything back together and there you have it.
Keep in mind that this might void your warrenty if you still have some on it.
Apr 13, 2007 | Waring BB150 Work Top Blender
Blenders Logo
675 people viewed this question
Top Waring Blenders Experts
AZBen
AZBen
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
