Question about Philips DVP5140 DVD Player
Loud mechanical noises from my dvd player during loading,advcing,
My dvd player is making loud and noticeable grinding type noises, kind of mechanical type sounds, esp. when disc is loading or when player re-sets timer in begining of movie in between the coming attractions type ads. Also seems to make a humming or faint buzzing type noise when disc is spinning. Are theese problems normal to all dvd players?
  • zhammer398 Feb 07, 2009
    Would this also be the same for the Philips MCD 702 DVD Micro Theatre System? Thanks.
  • Anonymous Mar 13, 2014
    Huming noise by dvd use, how it solved?
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason for the problem is u have
to clean ur dvd lense.u can clean the lense
using the lense cleaner cd.This will be available
outside.once u clean it will work properly without
any noises.
check it out.
thank u..
Posted on Feb 07, 2009
  • Hariharanath V Feb 07, 2009
    ya it will be the same.
    thanks..
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
RCA TV DVD Combo DVD makes loud grinding noise when playing DVD
does not sound correct. Perhaps the laser is hitting the DVD, or a gear is dirty. Anyway, if you keep playing with a strange noise in the player, it won't take long before it stops complete, or till you destroyed all your DVD's When you don't see scratches on the silver side of the DVD's, you should check (or let a technician check) what can be wrong with the player.
Sep 30, 2014 | Televison & Video
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
Hi, may I know crankshaft pulley having a bush intact?mine was 98' accord sv4, it was a noise appear when air cond. compressor engaged, i thought it was compressor noise, but aircond mechanic told me it...
you do not mention the type of noise rattle , squeal , rumble , grinding so any answer is a guess
the only noise from a crankshaft pulley would be a squeal/scream from a failed harmonic balance rubber insert
when the ac compressor is engaged the extra load on the pulley would make it slip on the rubber
however as the ac compressor would not be driving long before the crank pulley came apart I suspect that the mechanic was not experienced enough to advise correctly
suggest that you get a second opinion from an accredited professional ac specialist
Dec 03, 2017 | 1998 Honda Accord
Maytag Neptune front load washer model MAH3000AW, load during spin cycle
YOU MEAN LOUD DURING SPIN CYCLE? IF THAT SO, WHAT KIND OF NOISE? BANGING NOISE MEANS YOU HAVE UNBALANCED LOAD OR ONE OF THE SUSPENSION IS BAD OR FELL OFF. GRINDING NOISE MEANS YOU HAVE A BAD TUB BEARING, TO REPLACE THAT, YOU HAVE TO REPLACE THE WHOLE REAR TUB ASSEMBLY, VERY COSTLY. MEANS YOU PROBABLY BE BUYING A NEW WASHER.
BOYNISMO@YAHOO.COM OR 714-334-1998
Jan 14, 2010 | Maytag Washing Machines
My kenmore HE 2 Plus washing machine makes a loud grinding noise when it enters the pre-wash/wash cycle (worse on this cycle) then continues on through the rest of the cycles. Washer fills, rinses, spins...
Unfortunately, I don't think you will be able to fix this issue, some mechanical parts are breaking. If your appliance still under warranty, you may need to contact the appliance manufacturer for assistance. This kind of repair can be expensive and is difficult enough so a service technician may need to fix it.
Aug 31, 2009 | Kenmore HE2 Plus Front Load Washer
Washer has started making a heck of racket during the drain/spin cycle. It's not consistant. Two loads may go thru ok no noise. A third load and it will make a very loud grinding chain like noise.
Grinding noises are most often the result of a failing water pump. The noise can increase during the spin\drain cycle due to the added load on the pump. Although less likely it could also be the drive belt rubbing on something or a pulley bearing failing. If you are able to locate and remove the drive belt, you should be able to turn the water pump pulley by hand. If the pump does not turn smoothly it is bad.
Aug 06, 2009 | Maytag Washing Machines
DvD player wont load
The grinding could be the laser trying to read, so you could try a CD/DVD cleaner product> It also could be the laser is off track or damaged and you would need to have it repaired or buy a new player.
Mar 18, 2008 | Televison & Video
Loud noise
If your also encounter prints that have a roller/crease at the right and slight crinkling at the left then your fuser should be replaced.
Nov 19, 2007 | HP Color LaserJet 2600n Printer
Spindle makes sounds and seems to grind and unable to read discs
i did notice inthese models there is a ribbon and for some reason the ribbon will hit the dvd making a noise..push it down it will scrach your dvd
Oct 19, 2007 | Coby DVD-206
Philips DVP5140 DVD Player Logo
1,480 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
