Do a total power drain in your printer.
Turn it off. Unplug it from the wall outlet and from your computer. Make sure that you remember where those plugs to put back.
While turned off and unplugged, press and hold the power button of your printer to 8-10 seconds to drain the power.
After doing that, plug it in to the wall-outlet. Turn it on. Connect it to the printer. Turn off then turn it back on. Try printing. IT should work.
Let me know if you have any questions.
I hope this helps!
David
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
?· Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
?· When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
?· When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
?· Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Clearing paper jam in a printer is simple almost seven step
procedure depending on the printer. Paper jam is the term used to refer to the
scenario where your paper fails to come out of the printer during the print
process. When you send a document to the printer, normally the printer prints
out the document on a paper; then you can pick up your printed copy. When the
paper gets stuck in the printer, it is said that paper has jammed in the
printer "paper jam".
Even if you are not a technical person, you can conveniently
clear paper jams. All you need is to follow the set of procedures outlined
below.
Good luck & God bless!
Note
Be careful to not force the print head to move.
If the print head
is positioned at the far right hand side, you cannot move it. Please
contact Brother Customer Service from "Contact Us".
Note
Use a flashlight if necessary to check thoroughly.
