Question about HP Compaq nx6110 PC Laptop
Unknown power-on password.
Is it possible to reset my bios password for hp compaq nx6110 by parallel loopback method?
Forgot bios password on my compaq nx9600
I know some methods to reset bios password.
1. The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box, take out the cmos battery from the mainboard. Then the bios password will be reset to blank. Put it back after a few minutes.
2. Follow some tutorials. For example the tutorials:
Reset HP / Dell BIOS Password.
Top 3 methods to crack bios password!
So I would suggest you the 1st method. Hope it helps.
May 24, 2011 | HP Compaq nx9600 Notebook
Do u know the Power on Password? if yes, Go into the bios tapping the f10 key and Go to advance aoptions. There you woul find the options to Enable and Disable Power on passwords.
Oct 10, 2009 | HP Compaq nx6110 Notebook
How do you remove the power-on password for windows Hp compaq 6710b?
Sadly, you must pull the laptop apart and reset the BIOS...well unless you know the password, then just remove it through BIOS.
Jul 16, 2009 | HP Compaq nx6110 Notebook
Unknown hp power-on password
Did you do all these steps in order?
1) Remove the computer power pack battery. Remove the keyboard.
2) Remove the RTC battery. Wait 5 minutes. (I would wait longer, maybe 15 minutes.)
3) Reinstall the RTC battery. Reinstall the keyboard.
4) Plug the AC power into the computer. (DO NOT INSTALL THE POWER PACK BATTERY AT THIS POINT)
5) Turn on the computer.
This should reset the password and also all CMOS settings.
Jan 26, 2009 | HP Compaq nx6110 Notebook
Resetting the "Power On" password
Power off laptop. Disconnect mains pack. Remove battery pack. Wait 30 sec. Connect just mains adaptor. Press power on button. press f10 for bios settings. Your passwords are now cleared
Nov 03, 2008 | HP Compaq nx6110 Notebook
Power On password bypass
Different names, but it is the same thing. I'm not sure if it is possible to flash the bios without that password. I'll look into it. Have you tried contacting Compaq? The guys at the US online support helped me with a discontinued 8 year old model... and I live in Europe
Oct 28, 2008 | HP Compaq nx6110 PC Laptop
Bios password
Try toshiba first!
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot.
To reset the password of a Toshiba, you can use KeyDisk.
If this doesn't work, you can try to build the Toshiba Parallell loopback.
To make a device that you connect to your parallell port, a lot of Toshiba computers remove the password when you boot it up. The device, named "loopback" ,could be made out of any parallell wire with 25pins connectors (db25). Connect these pins: 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15, 18-25
Oct 12, 2008 | Toshiba Satellite A135-S2276 Notebook
How to break Toshiba SP4600 Laptop CMOS PASSWORD
reset the bios by unpluging to battery.
Apr 19, 2008 | Computers & Internet
HP Compaq nx6110 PC Laptop Logo
332 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
