Question about Goodmans 257NS 20" TV
Tv keep going on standby when you turn it on
Goodmans 32 inch lcd tv
    Sergeant:
    Champion:
  • 318 Answers
Tv goes into standby all the time if a power supply is not fine, what happens is that a power supply produces two voltages, one small one powers a standby components and bigger voltage powers a line transformer which later produces more small voltages,
then later cancels the first small voltage.
chec your power supply semi conductors like, transistors, diodes and small value resistors, on your power supply. some power supply uses a IC to oscillate a ht. so check a supply at a w/shop.
Posted on Apr 29, 2009
  • 33 Answers
Check power supply board Power inverter IC
Posted on Apr 21, 2014
32 inch, hannspree tv.1080P I need code to get my sky remote to work.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV (try 0206)
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Mar 15, 2011 | Hannspree XV32 32 in. LCD Television
Switch TV on then a blank red screen appear then a green and then a blue which then just repeats that sequence of colours every second. The remote control packed up working some month before. - 2 year old...
turn TV on, let the Tv cycle through the three colours, then using the remote press the menu button followed by the standby button. press standby button again and it all comes up working.
andy
Sep 20, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
I have a 32 in,goodmans lcd tv.after about 30 mins the picture and the sound start to crackle,then it turns off.it has to be left for a while,then it can be turned back on,but only for a few minutes,and...
I'm afraid I don't have the solution but a very similar problem, although I just get the speaker crackle, rather than any problems with the picture/the TV turning off.
Did you manage to resolve it?
Aug 05, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Goodmans glcd32wdvbt turns itself into standby mode how do i stop it doing this?
maybe theres a defect in in the board of your tv, theres a defective parts inside. maybe it is shorted. causing not to osolate. just look a qualified technician to fix your problem.
Jun 25, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
My standby light flashes red/blue? and no pic,its only weeks old
I would take it back and get a replacement, it is a lemon, it will void warranty if you open it up. It can be defctive power supply module.
Dec 09, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
I have had a 32" sony LCD Digital TV with built in free view tuner. I am experiencing a problem where on certain channels the TV keeps switching itself off to standby. Is this a TV fault or a signal one,...
if it says no signal or video not available then signal if its just turning itself off then tv i would go to the shop and get it checked out or replaced.
Dec 04, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
Tv not turning on from standby goodmans lcd 32"
problem is with power board, it seems a problem that is endemic to these sets, you can sometimes manage to reset by unplugging set for 30 mins repowering and sometimes it will come back on otherwise look at replacing board
Jul 23, 2008 | Televison & Video
Wharfedale TV power problems
got a 32 inch wharfedale tv from argos also and it seems to boot up and then shut down and just loops, if i keep unplugging it i can sometimes get it on but with a high pitch wailing, only 15 months old, gutted!
Jun 16, 2008 | Televison & Video
Goodmans 257NS 20" TV Logo
650 people viewed this question
Top Goodmans Televison & Video Experts
Kolbrun...
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
