Question about Epson Stylus C46 InkJet Printer
Epson Stylus C45 not printing
I just now bought a black ink cartridge and put it in. The red light had stopped blinking which means ink filled successfully. Now when i am printing a page...Its printing blank...what should i do?
  • James Louie Puro
    James Louie Puro May 11, 2010
    have you pulled the strip in the cartridge? try installing the old cartridge and print if that works then you have a problem with your new ink cartridge.
  • Epson Master
  • 1,879 Answers
Common issue, the printer will still shoot blanks even if you try another ink or do several head cleanings.
i got a lot of them with that problem, but since epson prints beautiful photos, i don't mind exchanges or getting a new one.
Posted on Feb 08, 2009
Will my epson stylus nx415 printer print if there is only one out of 4 ink cartridges installed?
That seems to be what it means. I am unable to even use the scan function on my epson 500 without all of the inks installed and with ink.
Nov 30, 2012 | Epson Stylus Nx415 Color Inkjet Printer...
My Epsom Stylus C45 was running low on black ink. The second button on top was blinking red because I tried to print. So, I opened the cover and pressed the second button to get the cartridge out, and...
Yes you can still move the inks first put the power off on and then you go to look very close to where the cartridges are and at the bottom of the inks you see a little leaver you can pull this up and at same time slide the ink cartridges to the middle so you then can change them but do the careful.
All the best: Pineworks
Feb 04, 2010 | Epson Stylus C86 InkJet Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
How can i use epson stylus c45 without black ink its urgent plz
If this is a color printer, then you cannot use it without the "Black" cartridge.
Most printer manufacturers will pull from the "Black" ink to print black on color images. They do this to save on creating a "processed black" from the color inks.
Just curious, are you using a "CMYK" system? (Cyan, Magenta,Yellow and Black inks)
Don
Nov 02, 2009 | Epson Stylus C46 InkJet Printer
My Epson is printing pages in code and will not stop and the green light is blinking and the red is staying on. We put in new ink cartridges today.
zark4, The green light flashing means you have print jobs waiting to be printed. Don't Turn Off The Printer When The Green Light Is Flashing ! If you have paper in the printer, the red light means you have an empty ink cartridge. Because both things are happening at the same time, here's what you need to do. First click start. Click printers and faxes. Double left click the Epson C-60 Icon. Left click Printer and click Cancel all documents and click yes, then exit. Remove and reinsert your new ink cartridges to make sure they are seated correctly. After you have done this and the printer finishes the automatic charging of the ink cartridges, the lights should be back to normal. Green light on.
Oct 22, 2009 | Epson Stylus C60 InkJet Printer
Trouble with my epson stylus c45 printer. PLEASE HELP!?
this is usually caused by clogged print heads, unfortunately epson is still one of few brands that still manufactures most of their printers with the heads built into the machine and thus upon print head clogging the printer must be taken in to be serviced or buy a new printer that does not have the print heads built in but rather built into the ink cartridges. hope this helps.
Sep 30, 2009 | Office Equipment & Supplies
Printer will not print
You must have both cartridges installed and neither must be empty. Note the red light on - this means an ink problem. See the handbook (download from Epson website if you don't have one) to see what the various light combinations mean.
Jan 30, 2009 | Epson Stylus C60 InkJet Printer
Epson stylus c45
epson.com, actually you can print using black ink only, but you have to reset the color ink for it to register as full. :) or you can freeze the ink counter using the ssc service utility before the other ink rans out. :)
Jul 17, 2008 | Epson Stylus C46 InkJet Printer
Epson stylus c45 (Problem)
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C45 Service Manual". You will often find them
for sale very cheaply on E-Bay.
Jun 14, 2008 | Epson Stylus C46 InkJet Printer
C45
Epson has an interactive troubleshooting guide on their support site. http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp From the link above, choose your model printer. You will then be brought to the main page of your printer. Then, click on the "interactive help program" link under the Troubleshooting Guide section. Through this, you will be able to find an article describing what all the indicator lights mean and how to possibly resolve the issues.
Sep 15, 2006 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
933 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
