Question about Apple iPod nano
Nothing but the volume control works and the screen is frozen
The only thing that happens when i turn the ipod on is the screen automatically freezes. the only thing that works is the volume control!
how can i unlock it?
    Problem Solver:
  • 10 Answers
I know that this is probably not the solution that you want, but its the only solution that works on errors like that.
This error can only be fixed manually inside the iPod.
My best advice to you is to get to the shop were you bought it and show them you're problem, you'll probably get a new one back, or in the worst case they'll send it to fixing and you have to wait like 2-3 weeks before you get it back, fine as a new one.
Hope it helps :)
Posted on Feb 17, 2009
IPOD 2GB Nano display doesn't work
try pressing the reset button on the ipod. if it still freezes, the ipod has problems
Jul 31, 2010 | Apple iPod nano
IPod freezes during use
The best thing to do wuld be to first, back up all of the stuff on your ipod, and the restore it back to factory setting through itunes. After that, you can put all of your files back on the ipod and it should function normally.
Dec 30, 2009 | Apple iPod MA446LL/A MP3 Player
Samsung Pixon touch screen frozen
The issue of touc screen freezing in he M880 is mostly due to fault in the contact. The screen contact is just below the volumen control buttons on the right. I inserted a fingre nain where the volume control is and pulled up the screena wee bit. near the volume up botton, I then inserted the tip of a tooth pick. It worked and the touch sensitivity is just as new :)
Sep 09, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
IPod stopped and won't recharge.
By pressing Menu and the centre button together the iPod was reset. I got this solution on Google.
Jan 06, 2009 | Apple iPod nano
IPod click wheel frozen
how do i unlock my ipod
Jun 05, 2008 | Apple iPod nano
Ipod screen frozen
Hold the center and menu buttons together for about 7 seconds. It should work
May 25, 2008 | Apple iPod nano 3rd Generation
Hanged apple ipod classic
Stuck or frozen
you have to hold the the menu and middle ong for 10-20-30 secs
hold the menu +center button and it will turn off and reset
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Feb 24, 2008 | Apple iPod MA446LL/A MP3 Player
Try to restart the Ipod.
Hold the select button and the menu at the same time until you see the screen go off.
If still does not work then try to enter disk mode and see if it works.
Disk Mode:
Reboot the ipod via Select and menu, right away hold the select and play button and hold until disk mode comes on. Does the wheel work?
If still does not work then reboot the ipod again and let it reboot normal to go back in apple firmware. If all buttons are working and none of the above works, I would assume it is not software related.
Nov 12, 2007 | Apple 20gb Ipod Mp3 Player With Click...
8gb mp3/mp4 player
If your iPod is frozen or won't turn on, your iPod may be paused or on "hold." Slide the Hold switch and check the screen.
If your iPod is frozen or won't turn on, connect your iPod to your computer, then press and hold the "Menu" and "Select" buttons simultaneously for 10 seconds to reset the iPod. Resetting an iPod will not affect your files or preferences.
If your iPod fails to hold a charge and it's more than a year old, you may need a new battery.
If all else fails, file a complaint with ebay stating you were sold something that was not properly described - unless the seller made it clear there were issues with the unit.
Hope this helps some!
TWEAK A/V LAB
Oct 26, 2007 | Apple iPod nano
Random things happening
How much old ur set and change all belts clean the mel. parts and check. Change the vol. control.
May 28, 2007 | JVC MX-D602T Shelf System
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
