Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune 80 GB - Won't Charge
I have an 80 GB Zune (black) 2 days ago the Zune play/pause button was not working and then the Zune was only charging to half power, instead of full power. Then the charging was on and off. When it charges (when ther's no power left) you should see a black screen with a large lit battery and a lightning bolt symbol in the middle of it to let you know it's charging. But it kept going from that to a large battery with a red line at the bottom of it (that means it's not charging) and now the screen is just balck. I alternated between my ac adapter and the usb ports and nothing works the screen is still balck with no sign of charging. I went on Zune.net for help but not of their insructions helped at all. Can you please help me. My 30G Brown Zune won't charge at all. Any Ideas?
I lost my drivers microsoft lifecam vx-1000
Posted on Feb 08, 2009
Have a 80 GB Zune. It froze one day and was showing the message 'Connect the player to your PC'. I did that but then some error message started appearing in the Zune PC software. I tried formatting the...
Try the reset procedure...
hold the back button and the up button until you see the Zune logo then release. if this doesnt work then you are going to have to reset your Zune....however this will loose all the data on the zune so your music/movies will be completely gone. you are going to need to press and hold the back and up button until the zune logo appears then hold the back,play/pause, and the center button until you see "please wait"
Jan 02, 2011 | Microsoft Zune JS8-00001 Digital Media...
My zune dont charge i that be fix
Hello
Yes, it is a common problem for some of the Zune players. The charging unit in the player self might be broken.
Have you checked the charging cable?
Something else you can try is to hold down the play/pause button for a while, this will restart the unit.
If this does not work, click on the following link, where you will be directed to Microsoft's zune support page. They will be able to let you know where the nearest repair centre is located.
http://www.zune.net/en-GB/
Hope this can steer you in the right direction.
Kind regards
Andrea
Dec 23, 2009 | Microsoft Zune JS8-00001 Digital Media...
My Zune player 8gb not charaged.
Just press the play/pause and the back button at same time for a while.. The player will then restart, and the problem is solved (hopefully)
Jul 23, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My 30 gb zune is frozen
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
goto step 4 only remove clip for battery wait ten seconds. It worked for me!
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune player charge does not last.
Hold the left (back) button and down on the circle at the same time to turn zune completely off.
Dec 23, 2008 | Microsoft Zune JS8-00001 Digital Media...
my 30gig was doing same thing i opened it up and one of cables just slipped out of port very simple to fix open you zune where the charger goes in there is a black cover remove this carefully then remove the 2 very small screws next use a very thin flat surface be very careful and you can see the edge where it seals just put you thin applient into the side and gently pull it up go all the way around once at top be gentle dont use the knife or whatever you used just slide it appart the back will come off then just reconnect cables good luck
Sep 30, 2008 | Altec Lansing M604 Computer Speakers
Zune won't charge
now what you do is if the zune just has a black screen with a battery symbol and it stays that way forever when on the charger. you, take the zune off the charger and press the play/pause button and if it turns on for a second with the low battery symbol then turns off, your in luck, just hold the play/pause button for 10 - 20 minutes. the zune will have turned on and off alot agitating the battery. once you hold it for 10 - 20 minutes put it on the charger, then presto it works. let charge fully then die completly for every time you use it for a bout a month to let the battery get back into it's normal cycle. ~Dan herzberg~ Thank you*
Feb 18, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune is Not responding
after much research on this matter in the past few hours. To resolve this situation don't shut the zune down by holding play/pause button it does not shut down properly that way.
Hold down the down & back button down until shuts off....zune recommends as the best way to turn off your zune. Also if you are having problems holding charge, a lot of people replaced the original charge plug and found that it worked again. these cables usually become faulty from previous models and 30gigs. So buy a new cable & shut it down correctly.
Still no worky??? Call zune, within 1 year they will accept it for repairs. They may even send you a new refurbished zune...since they no longer are making the 30 gig...probably for those reasons.
I hope this advice not only helps you but myself. Who wants an expensive paperweight...not I!
Dec 11, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
241 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
