Question about Linksys (WMP54GS) 802.11g/b Wireless Adapter
Passphrase I need a default passphrase is there one that can help me connect with my wmp54g.
  • kathypinkyda Feb 07, 2009
    No I don't have my own router I brought a wireless-g pci adapter wmp54g. I have a strong signal and I'm connecting to the access point but I still cannot get the internet to connect. When I click on available connection a screen pop's up that require's Passphrase.
  • Ved Pradhan May 11, 2010
    hi........
    the default passphare that you are talking about we need to find it from the router,do you have your own router,if u ave your own router then we can find the passphrase but if you are trying to connect to someone elses network then we wil not be able to get the passphrase...let me know about it...
    vedhick
  • 326 Answers
Resetting the router will allow you to set it up to your preferences.
Simply locate the Reset button found on the back of the device and hold it in for a period of 5-10 seconds until you see all the lights on the device light up.
This resets all the settings to default, upon which your wireless will be open, and you can set it up from there. I highly suggest that you configure your security settings after this reset.
Open routers are open cells for their owners, and innocent people don't belong in jail.
Let us know.
Good luck.
Posted on Apr 15, 2009
    Scholar:
  • 54 Answers
Ok....
it seems that you are tring to connect to someone elses secured network which means you will not be able to connect to this wireless network as it has security enabled in it and the passphrase is know to the person who has setup this network....what i can suggest is that you can try connecting to unsecured networks if it is available...if there is no networks unsecured networks available then you will not be able to connect to the internet wirelessly..
vedhick...
Posted on Feb 07, 2009
I need to change the network name and password
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings. From the center screen, select your encryption type from under the Security Options heading If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router: Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Hope this helps don
Feb 21, 2011 | NetGear Computers & Internet
We cannot log on with the assigned password
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin)and password by default the password is 1234 unless it has already been changed
from the left-hand navigation menu of the router manager,select wireles set up>wireless settings
from the center screen,select your encrytion type from under the Security Options heading
if the wireless network passphrase is visible,review it and use it to log on devices onto your network.
If it is not visible you can change your wireless passphrase but changing your passphrase will cause you to lose your wireless connection
Connect your computer to the router using an Ethernet Cable before entering a new passphrase into the text box and clicking apply.
If you cannot log into your router:Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
From the center screen, select your encryption type from under the Security Options heading.
hope this helps
Dec 30, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
Netgear will not reset to factory
sir a hidden button on the back of the router used to reset to the factory default settings (use paperclip)
thanks
Nov 25, 2010 | NetGear WGR614 54Mbps Wireless Router...
I have forgotten my security key for connecting to the internet with my netgear wireless router
hope this helps
Nov 11, 2010 | NetGear Wireless router EN Fast EN
Can't connect to internet- suddenly after working for years, my router won't connect to web. I can connect with a direct connection from modem to computer
Nov 07, 2010 | NetGear WGR614 Router
Cannot connect a router
Note: restoring factory defaults on a device will erase any settings you have made
hope this helps
Oct 29, 2010 | NetGear WGR614 Router
How do I connect Netgear router (WGR614v5) to Belkin modem (voip 4 port wired gateway)
  1. im not sure if this will help it worked with my thomsom modem &netgear router
  2. hope this helps good luck
  3. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  4. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Oct 22, 2010 | Computers & Internet
Need to reset my password
  1. This worked for me on my netgear router not sure if it will work on a linsky hope this helps anyway
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
See the following articles for more information:
Sep 26, 2010 | Linksys WRT54G2 Wireless Router
Cant connect laptop to router
The passphrase can be seen on the router's Admin page or its usually called router's Setup Page. You can open the router's setup page using your Internet Explorer. First you must your default gateway address. Connect your computer wired to the router or you can use a computer that is hardwired to the router to check the Default Gateway by going to Command Prompt then type IPCONFIG. If you see the Default Gateway, that's the address that you need to type on your Internet Explorer like http://192.168.1.1. If you have the router's setup page opened, you can see the passphrase on Wireless tab or Wireles Security Mode
Oct 22, 2009 | Computers & Internet
Security key/ passphrase
The easiest workaround for this is to connect your laptop to the D-Link
with an ethernet cable.
Make sure your laptop IP address is configured for the same subnet
(example: 192.168.0.9)
Open your browser and go to http://192.168.0.1
Default username: user
Default password: (blank)
(This is of course assuming that you did not change your
default username/password)
Once you're in, change the passphrase to anything you want.
Jul 01, 2009 | D-Link DI 514 Wireless Router (DI-514)
Open Questions:
See all Linksys (WMP54GS) 802.11g/b Wireless Adapter Questions
Linksys (WMP54GS) 802.11g/b Wireless Adapter Logo
135 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
