Question about HP Office Equipment & Supplies
Remove and check cartridge on right
I have put a new HP Black Cartridge 130
  • HP Expert
  • 1,326 Answers
How old is the printer? If it is over 2 years, buy a new one. It is not really worth have a service rep. come out and charge you $95 - $150.00 to look at. When you can buy a new one for $60.00. Unless, you have a special bond with the printer. It's up to you
Posted on Feb 08, 2009
Need to find out how to put ink cartrdiges back into hp 5610 all in one printer.
First, turn the printer on. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right Pull the print cartridge toward you out of its slot.
Now we're ready to install the new cartridge. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket. Close the print-carriage access door.
Mar 21, 2011 | HP Officejet 5610 All-In-One InkJet...
I bought a new ink cartridge, but cannot find my manual. How do you change the cartridge???
Changing an HP Ink Cartridge
  • 1
    Open the lid of the printer. Depending on the model, there will be two cartridges on the right, one for black and one for color.
  • 2
    Find the cartridge that is running low on ink. The black cartridge will be in black, the color cartridge will have a patch of color (usually green) on it.
  • 3
    Pull down on the black clamp that is holding the cartridge in place and slide out the used cartridge.
  • 4
    Open the package of the new ink cartridge. Remove the protective tape and slide the new cartridge into the printer.
  • 5
    Snap the black protective case back into place and close the lid.
  • techbelkin
    Nov 11, 2010 | HP Officejet 5610 All-In-One InkJet...
    How do I remove and replace the ink catridge ?
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01429130&cc=us&lc=en&dlc=en&product=3645100&tmp_track_link=ot_search
    Please follow this link and well you would have your ink cartridges replaced without a problem.
    Otherwise this is what you do
    Step one: Remove the old cartridge
    1. Press the Power button ( c01983533.gif ) to turn on the HP product.
    2. Open the front access door. The carriage moves to the far right side of the HP product. CAUTION: If the HP product is off when the front access door is opened, the HP product will not release the cartridges. Figure 1: Open the front access doorc01429211.gif
    3. Wait until the carriage is idle and silent, and then lightly press down on a cartridge to release it.
      • To replace the tri-color cartridge, remove the cartridge from the slot on the left.
      • To replace the black cartridge, remove the cartridge from the slot on the right. Figure 2: Remove the black cartridgec01429212.gif
    4. Pull the cartridge toward you and out of its slot.
    Step two: Prepare the new cartridge Use the following steps to prepare the new cartridge for use in the HP product. Which cartridges you use depends on your country or region. To check the cartridge compatibility for your product, right-click this link, HP SureSupply , and then click Open in New Window . If your language or country does not display next to the globe icon (c01906983.gif ) select your language and location.
    1. Remove the new cartridge from its packaging. Be careful to touch only the black plastic.
    2. Use the pink pull tab to remove the plastic tape gently. Figure 3: Remove the tapec01367670.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or the ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the contacts or ink nozzlesc00442147.gif
    Step three: Replace the old cartridge Use the following steps to replace the old cartridge.
    1. Hold the new cartridge with the HP logo on top, and then slide the cartridge at a slight upward angle into the empty cartridge slot. Push the cartridge in firmly until it snaps into place.
      • To install a tri-color cartridge, insert it into the left slot.
      • To install a black cartridge, insert it into the right slot. Figure 5: Insert the black cartridgec01429213.gif
    2. Close the front access door.
    3. An alignment page prints. You do not need to do anything with this page yet. Continue to the next step.
    Step four: Place the unused cartridge in a cartridge protector If you are temporarily removing a working cartridge (for instance, removing a black cartridge in order to install a photo cartridge), put the cartridge that you are not using in a cartridge protector. NOTE: Cartridge protectors come only with photo cartridges. If a cartridge protector is unavailable, store the unused cartridge in a rigid, airtight container (not a plastic bag). If unprotected, the cartridge can dry out and become unsuitable for use. Step five: Align the new cartridge The HP product prints a cartridge alignment sheet when you install new cartridges.
    1. When prompted, load unused, plain white, U.S. letter or A4 sized paper into the input tray, and then press OK on the HP product control panel.
    2. Lift the scanner lid.
    3. Place the alignment sheet on the scanner glass so that the top of the sheet is on the right side with the text facing down. Make sure that the sheet is aligned with the right front corner of the scanner glass. Figure 6: Place the alignment sheet on the scanner glass
    4. Close the scanner lid, and then press OK on the HP product control panel. The HP product aligns the cartridges.
    Oct 22, 2010 | HP OfficeJet J4580 All-In-One Laser...
    Hp officejet 7310 black cartridge error message
    the clip on the side came out i put it back and i saw puncture in that pins plate in the printer maybe is a scratch when that spring clip come out itry turn on and off and put back the black cartridge but i receve same message to remove and check black cartridge?
    Apr 26, 2010 | HP OfficeJet 7310 All-In-One InkJet...
    Printer does not recognize ink cartridge.
    Remove the black cartridge and gently wipe the contacts on it with a dry cloth. Put the cartridge back in. If the error message is still there, I think you should buy a new black cartridge.
    Apr 01, 2010 | HP Officejet 5610 All-In-One InkJet...
    I keep getting the message "remove and check cartridge on right. I do this, but it doesn't solve the problem. The printer worked fine until I installed a new black ink cartridge. After so many times of...
    The cartridge on the right is the black ink cartridge. The one on the left is the color.
    Make sure you have pushed the cartridge in all of the way and that you have removed the tape cover from the cartridge before you insert it.
    If you bought aftermarker or third party cartridges, you have a cartridge that is not filled properly. If you purchased it from a local retailer, return it and try another cartridge.
    The Hp reads the levels from the gold connectors on the cartridge. If they are blocked, or damaged or the cartridge is not full, you will get this message.
    Jan 14, 2010 | HP Photosmart 4180 All-in-One Printer
    HP 7410 printer displays error ''remove and check colour cartridge
    I think that spring must have gotten loose that holds the cartridge in place, right hand side, put it back where it belongs, might want to compare with the other, black cartridge side.  Good Luck!
    May 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
    HP 3310 says "Black Cartridge Empty" when new one is installed.
    remove the black cartridge/ place a piece of scotch tape on the left side of the gold top gold contact on the back of the cartridge, put back in the printer, remove the cartridge again and put tape on the right top gold contact on the right side of the cartridge, put back in the printer, remove cartridge and take off the two pieces of tape, should work good for you now/ It no doubt will print out an alignment page now.
    Mar 08, 2009 | HP Photosmart 3310 Printer
    How do i change an ink cartridge on a HP PSC 1510 printer
    To replace the print cartridges
    1. Make sure the HP All-in-One is on.
    Caution If the HP All-in-One is off when you lift the print-carriage access
    door to access the print cartridges, the HP All-in-One will not release the
    cartridges for changing. You might damage the HP All-in-One if the print
    cartridges are not docked safely on the right side when you try to remove
    them.
    2. Make sure the paper tray is down and there is letter or A4 unused plain white
    paper loaded in the paper tray.
    3. Open the print-carriage access door by lowering the door.
    4. Wait until the print carriage is idle and silent, and then, using your thumb, lightly press down on a print cartridge to release it.
    5. Pull the print cartridge toward you out of its slot.in-One
    6. If you are removing the black print cartridge in order to install the photo print
    cartridge, store the black print cartridge in the print cartridge protector.
    7. Remove the new print cartridge from its packaging and, being careful to touch
    8. Slide the new print cartridge forward at a slight upward angle into the empty slot.
    Using your index finger, push the print cartridge forward until it clicks into place.
    If the print cartridge you are installing has a white triangle on its label, slide the
    print cartridge into the slot on the left. The label for the slot is green with a solid
    white triangle.
    If the print cartridge you are installing has a white square or a white pentagon on
    its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon.your HP All-in-One
    9. Close the print-carriage access door.
    If you are installing a new print cartridge, the HP All-in-One begins to print a print cartridge alignment sheet.
    10. Load the print cartridge alignment sheet on the right front corner of the glass with the top of the page to the right.
    11. Press the Start Scan button.
    The HP All-in-One aligns the print cartridges.
    Good Luck.
    Apr 10, 2008 | Office Equipment & Supplies
    81 people viewed this question
    Ben Johnson
