Question about Omron Automatic Blood Pressure Monitor Options Large Adult Cuff Fits Arms 13 To 17
WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
AFTER PUTTING THE CUFF ON RIGHT HAND ABOVE THE ELBOW ALWAYS GETTING ERROR BY SHOWING E ON THE MONITOR AND READING IS UNABLE TO COME.
PLEASE ADVISE THE CAUSE AND ITS REMEDY
  • 2 more comments
  • xaverian Feb 23, 2009
    batteries replaced and E reading. I cannot feel where the sensor is located. Is it on the end of the tubing?
  • Anonymous Mar 12, 2014
    cannot connect cuff to monitor
  • Anonymous Mar 13, 2014
    My Marshall 91 shows an error each time I use it. The cuff blows up but I still get an error.
  • Anonymous Mar 14, 2014
    blood pressure cuff relief valve leak
  • 50 Answers
Try different locations. The sensor must be over a vain to pick up the pulse. Locate the point on the cuff where the sensor is, and place this over the elbow. That should work. Good luck.
Posted on Feb 09, 2009
My monitor pressure life source UA 767 show in display error cuf , what mean thats error
The Err CUF probably means that the blood pressure cuff isn't properly arranged on the arm. Check that the cuff is around the upper arm 1-2 cm above the elbow. The hose should be near the center of the elbow. Make sure that a rolled up shirt sleeve is not too tight. Next check that the indicator arrow is in the correct range when the cuff is firmly fastened.
Make sure that you are using the correct cuff for the user. There are different blood pressure cuffs (medium, large, wide-range) available for some blood pressure monitors. If the arrow doesn't line up in the indexed range, use a different blood pressure cuff for the unit.
I hope this helps. I used the information about the A&D Medical UA-767 for some of the trouble-shooting details. See https://medical.andonline.com/product/premium-blood-pressure-monitor/ua-767f and click on the Downloads tab to see the manual for this model. (I suspect the Life Source and A&D Medical products are extremely similar.)
Nov 21, 2017 | Health & Beauty
Why does the cuff on my digital blood pressure monitor pinch
Cuff size, i believe you have to loosen the cuff for your arm size above the elbow
Aug 16, 2014 | Mabis Health & Beauty
The blood pressure monitor reads error 1
make sure you are getting the reader part on the artery just above the bend in the elbow. you may need a new cuff.also make sure it is snuggly plugged into the machine.
Apr 07, 2012 | Mabis ® Automatic Premium Blood Pressure...
Showing ee in the diastolic section, therefore its not taking the b/p
There are 3 things can cause the EE error code.
1. Cuff was placed incorrectly. Wrap cuff snugly around your wrist 1" above the heel of your left hand.
2. Moving or talking during measurement. Measure again keeping your wrist steady during measurement.
3. Shaking of the wrist with the cuff on. Solution is the same as # 2.
If you continue to have a problem with the cuff, contact HoMedics Customer Support 1-800-466-3342.
I hope this info was helpful and thanks for choosing FixYa.
Sep 15, 2011 | Walgreens By HoMedics Automatic Wrist...
When the blood pressure monitor reads E- error. What is the reason? Not keeping the wrist still?
It depends on which E-error you're getting.
EE - indicates several things:
  • Cuff has been placed incorrectly. Always place cuff on wrist 1" above heal of hand.
  • Did you talk or move during measurement?
  • Shaking of the wrist with the cuff ON.
E1 - Air circuit abnormality. Measure again.
E2 - Inflation pressure exceeding 300 mmHg. Switch the unit OFF.Wait 1 minute, then measure again.
E3 - Error determining measurement data. Measure again.
Hope this helped you to determine which Error you're receiving. Please let me know.
Apr 30, 2011 | Walgreens By HoMedics Automatic Wrist...
I have a blood pressure sphygmomanometer, how do you take a blood pressure reading and what is normal?
Much easier to go to a store, like Walgreens and get an inexpensive ( like 15 dollars) automatic wrist cuff blood pressure monitor, that will give you accurate and quick readings of your heart rate, and blood pressure, systolic and diastolic, automatically.
Apr 03, 2011 | Walgreens Health & Beauty
When my wife takes her blood pressure she gets error 3 every time. When I do it, it works. What could we be doing wrong.
2 things could be causing the problem, when your wife is doing it.
1. Improper placement of the cuff. If should be at least 1" above the heal of the hand and the cuff snugly applied.
2. Movement when the monitor is in operation. Hold hand and arm very still.
Also, for the most accurate reading, the hand/wrist should be at heart level.
Hope this helps clear up the problem for you.
Mar 07, 2011 | Walgreens By Homedics Automatic Blood...
I have a cuff like this and get an error saying EE
According to the Owners Manual, the EE Message shown on the display or the blood pressure value is displayed when an excessively low (or high) reading is detected OR as a result of one of the following:
1. Cuff has been placed incorrectly. Solution: Wrap cuff properly so that it's positioned correct.
2. Did you talk or move during measurement? Solution: Measure again. Keep wrist steady at heart level during measurement.
3. Shaking or moving of the wrist with the cuff on. Solution: Same as # 2.
NOTE: Be sure the cuff is placed exactly as pictured on the face of the box, 1/2" above the heel of the hand.
Jan 27, 2011 | Walgreens By HoMedics Automatic Wrist...
Blood pressure cure keep reading error and it is never charge even keep the machine charging overnite
Make sure that the cuf is over your artery, there will be a little plastic point in the cuff to show you where it goes, which is right in the fold of the upper arm from the elbow..... Take care.... Guy
Sep 06, 2010 | Walgreens By Homedics Automatic Blood...
Starts to inflate then get "E"
When you wrap it around your arm, make sure the cuff is just above the elbow and the air tube lines up with the middle finger of your hand. Try various locations -- the 'E' just means it is not sensing your heartbeat.
Jan 12, 2010 | Omron HEM-629N Portable Wrist Blood...
Omron Automatic Blood Pressure Monitor Options Large Adult Cuff Fits Arms 13 To 17 Logo
684 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
jay kaye
jay kaye
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
