Question about Philips DVDR3380/05 DVD Recorder
Not playing When I try to play any dvd in my recorder it will play until it gets to a certain time usually around an hour into the movie and then it starts skipping and freezes up all together.
  • 27 Answers
Very annoying problem there.
First, make sure your disks are completely clean. Some lasers are just weaker by nature and won't read well through scratches, smudges and peanut butter finger prints.
Second, make sure you have your DVD Player well ventilated. If the vents are only on the bottom, try elevating the four corners with small blocks to give it some extra breathing room. Run a vacuum or use compressed air to clean the vents. Also, if you feel you're up to it, you can usually remove the top cover of a player to clean inside without voiding the warranty.
Posted on Feb 07, 2009
    President:
  • 1,179 Answers
Try using a good quality dvd cleaner. After running the cleaning cycle try a known good dvd. This should fix the problem. Thanks for using fixya & please take a moment to rate this solution. Thanks.
My emerson ewr20v4 plays cds with music but not dvd with movies. It keeps displaying disk error
check and see if the dvd player needs to be cleaned. you can pick up contaminates from other dvd's or cd's get yourself a dvd disk cleaner and run it thru seveveral times . and try to play your money then.
May 09, 2014 | Emerson EWR20V4 DVD Recorder/VCR
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I have wasted 4 hours with 1 of your so called (experts) i want answers not excuses
Don't know if I can help or not, but this what I do.
I've downloaded the DIVx player and converter software (free) to my computer. I can download mpeg, avi movies, etc, and convert them to DIVx format if I need to. The DIVx player has a 'burn' feature that is fast and burns them in a DIVx format. My old DVD Recorder will not play DIVx format but my 'cheap' Phillips will. I just keep it hooked up to my old DVD recorder through the front RCA input jacks. When I want to play a DIVx movie and watch it on the TV, I use the cheap Phillips player. I have to change the input on my old DVD Recorder to 'Front Input. I usually record the movie on a DVD R in my DVD Recorder while I'm watching it if I want to keep a copy to play later on the DVD Recorder. Most of the time, I burn the movies to RW DVD and erase them later.
I don't remember the web site for the DIVx players and converters, but you should be able to find it with a search.
Hope this helps.
Jan 16, 2009 | Televison & Video
Playing DIVX on an LG LH-RH3690 DVD recorder
You can not view from the USB, since the USB port on the DVD player is ver 1.1. The transfer speed is to slow to watch a movie. Alternatively you can copy your movie from your flashdrive to the harddrive and watch from there. You will see what I mean with slow speed when you copy the movie. It takes ages.
Sep 11, 2008 | Yahoo YDP305 DVD Player
Dmr ez25eb
clean the lense and try otherwise you have to replace the lense..
Aug 03, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Won't play certain DVD
fIRST OF ALL U CHECK UR LENS SINCE IT DIDN'T DO THE WORK PROPELY SO AFTER THAT U WASH IT PROPERLY FROM THE ACETONE AND THEN CHECK THE CIRCUIT OR IC
Oct 08, 2007 | Panasonic DMR-ES40VS DVD Recorder/VCR
No Audio when playing back certain DVD's???? HELP!!!!
Install AC3Filter ,This has solved many problems relating to sound http://prdownloads.sourceforge.net/ac3filter/ac3filter_0_70b.exe?download - binary http://prdownloads.sourceforge.net/ac3filter/ac3filter_0_70b_src.zip?download -
Jul 08, 2007 | LG XBR446 DVD Recorder/VCR
System Error
FYI...the best suggestion I've seen is to hold the channel up and play buttons simutaneously....thereby causing the machine to return to the "factory initialized" state. So far so good for me. We'll see. photog1
Apr 22, 2007 | Toshiba D-VR4 DVD Recorder/VCR
Movies on my recorded discs freeze after a few minutes of play
Sometimes this unit gets "confused" - not sure why -- but try first using a CD cleaning disk and let it start and stop a couple times (sometimes lens gets dirty and does this) - if that doesn't help then try unplugging unit and leave unplugged (from wall socket) for about 30min then plug in, set local time and then see if the disks play okay - sometimes this "resets system"
Jan 20, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Philips DVDR3380/05 DVD Recorder Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
