Question about Quantum Fireball Lct20 (QML20000LD-A) 20 GB Hard Drive
External Hard power is on but does not show up on my pc and does not seem to be running
Hi, My external hard drive powers up but does not show up on my pc, I don't think it's running either...is it possible to retrieve the data on the hard drive? What do I need to do? I don't think the hard drive is under warranty anymore. Can I diassemble it and try to connect is an internal hard drive and try to copy the files that way? Please help! my ide sata to usb wire works fine on my old harddrive .After i put lots of games in my harddrive
and played them for 5 hours then suddenly an error accours about the game and need to be shut down...
when i try to play it again i cant see the harddrive anywhere in
My Computer
i try to connect it again but it wont showed up and the usb wire wont connect
i dunno what to do.Maybe its my ide to usb wire that is broken..
help me...
  • 27 Answers
Does it happen to be a Maxtor II? I had a very similar issue with my external and it devastated my backup program.
If the power light is coming on but not being recognized by the OS, your first step is (as you said) trying a different USB/Firewire cable. If that does not work and you don't care about voiding an expired warranty, you can open the case and remove the HDD. It will have several screws in the back; just undo them and slide it out. Try hooking the HDD up through IDE (or SATA if equipped) and after powering up, go into BIOS and see if it shows up on the IDE(SATA) list. If it doesn't, then as far as I know, your only other option is to try a pricey data recovery service.
Posted on Feb 07, 2009
Why does it give me corrupted files?
MAY BE SECTOR ERROR.use data recovery software to recover the items
Jun 29, 2014 | Oyen Digital U32 Shadow 500GB External USB...
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
Maxtor external hard drive stopped working
How is it connected ? USB?
If you start w/o Maxtor connection is your PC starting correctly?
Is issue showing when you connect USB cable on working PC?
Jan 04, 2009 | Acer Extensa 4620 Notebook
My two front usb ports cant read usb hard drives
Some external USB drives require external power sources. Typically this is done either with an external power supply that connects to the drive or a second USB cable that connects to the drive and a second usb port on the pc. I have even seen one drive that comes with a Y cable. one end goes to the drive and the 2 usb plugs go to the pc.
Dec 12, 2008 | Linksys Wireless-G WRT54G Router
what do using to connect the external hard drive.
if you are using usb, try a differnt machine first.
yes. you can disassemble the hard drive and connect it as second hard drive on your machine. provided they are the same configuration IDE to IDE SATA to SATA.
Oct 15, 2008 | Western Digital 250GB MyBook External USB...
Does simple tech 250 drive need an external power source?
Yes, you need a power supply. I have several USB peripherals that, in a similar way, APPEAR to be on when you plug them into USB. But that interface cannot supply enough power to actually run the machine. The maximum is 0.5 A * 5 V = 2.5 W. The wee portable drives can run on that power, but a normal desktop drive, such as is inside a full-size desktop external enclosure, use ~ 8 W.
So you need a DC power supply! I bet SimpleTech can tell you what the correct current, voltage, and polarity is. Good luck.
Sep 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Why wont it work?
doesn't seem that "Simple" if you ask me. I don't think PC hard disks are compatible with Mac's. you might have to get a Mac compatible External HD.
Apr 25, 2008 | SimpleTech SimpleDrive 160 GB External USB...
Quantum Fireball Lct20 (QML20000LD-A) 20 GB Hard Drive Logo
468 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
