Question about ASUS P5B Deluxe/WiFi-AP Motherboard
Want to run both Raid 5 (4 drives) and a single SATA boot drive
I have an ASUS P5B Deluxe/WiFi motherboard which used a single SATA drive. I recently added 4 more hard drives and was able to set them as a RAID 5 array. My system will not boot with the IDE Configrutation set to RAID. When I change the IDE Configuration back to IDE, my system will boot but will not see the RAID Array. (And yes, I did set the hard drive order to look at the single drive first!)
  • Rivet414 Feb 10, 2009
    Tried using 1238 BIOS (vs original 1233) to no effect.
    Reading of ASUS forums leads me to the conclusion that I must re-install my operating system with "SATA configured as RAID" to allow both my single HDD and 4 disk RAID 5 array to run simultaneously.
    Please let me know if I'm mistaken in that assessment.
  • 295 Answers
Download the latest beta BIOS 1238. I had the same problem when adding a Samsung 1TB HDD to my RAID config. Updating to BIOS v1238 solved the Intel RAID Matrix "hanging" instantly.
You can't download it through the official Asus support page yet, but there's a topic in the Asus support forum with a link. You could also call Asus support and request the file, or just download it here: http://rapidshare.com/files/186891601/P5B-Deluxe_1238.rar :)
Posted on Feb 07, 2009
  • ElDopa
    ElDopa Feb 11, 2009
    Yes, that's reinstall part is correct, but you could also try installing the Intel Matrix Storage Driver (http://downloadcenter.intel.com/Product_...) on your current Windows setup first.
    Then reboot and configure the SATA drives as RAID and go to the Intel Matrix configuration afterwards ([CTRL] + [I]). You should configure your 4 new drives as RAID 5 - like you did - and leave the old drive as "Non-member".
    With a little luck you should be able to boot into Windows afterwards. If not, you'll probably get a Windows Blue Screen (BSOD) with an errorcode (probably 0x0000007B Inaccessible boot device), if so please post the errorcode (the first sequence of numbers only).
    When your boot is succesful go to Computer Management | Disk Management and you should see your new RAID 5 set, which you can partition, format and assign drive-letters there.
ASUS P5LD2 Raid 5 locks windows at MUP.SYS
A stab in the dark. Sound like the MB BIOS expects and is written to have the OS on the  IDE  slot. After that I would add one SATA drive at a time to see if it matters and to see if one of the drives are causing the problem.
Jan 05, 2009 | ASUS P5LD2-VM Motherboard
Software raid/ide
it won't touch them, it should ask you which partition you want to boot from, or which version of windows if your boot.ini files are on the same drive.
Dec 18, 2008 | Computers & Internet
AHCI
choose RAID mode.. that should enable AHCI. (as per wikipedia) on your motherboard so that means.. that if you're installing the os on this hdd you may want to use the raid driver for it which is likely what's in the ASUS cd you got so your os get to use the hdd as it's meant to be used.
you may also want to make sure you're using the right sata connector on your motherboard: check page 33
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5B-VM/e2642p5b-vm.pdf
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5B-VM
the problem could laso lay in your cables.. it's know the average may be affected by faulty SATA cable or faulty SATA power cable (powersupply issue)
you may also want to run a backup of your data and then run a defrag and a checkdisk on the drive, and it's probably also worth it to rung Seatools (download from this page: http://www.seagate.com/www/en-us/support/downloads/ ) to check the health of your hd.
Also try to update the SATA controller drivers or the motherboard chipset
lastly, post the results of your tests here on fixya or better yet: in here: http://forums.seagate.com for further follow up.
try each recommendation one at a time and then test the speed of your hd to see if there's improvement.. make sure you back up before you do anything drastic.
good luck (it took me 2 hours to pos
Dec 14, 2008 | Computers & Internet
2 Sata HDD not working at a time
In the bios be sure that all the parameters for the SATA drives/devices are AUTO
Dec 11, 2008 | ASUS Motherboard P5B-SE P965 LGA775 Core2...
2 Sata Hdd not supported
Hi rafiqbrush, let me go over a few things for the P5B MB.
There is a total of 5 serial ATA SATA drive ports on the board & one ATA IDE/PATA port.
The 4 main SATA ports are numbered, 1 - 4. Your primary SATA drive must be connected to SATA port 1. Your second SATA drive must be connected to SATA port 3. See page 2-26 in your manual.
All SATA drives are seen as master drives. Once the two SATA drives are connected (As per manual), boot to the bios main menu.
At the main bios menu make sure your bios shows both SATA drives. Than go to the bios title "Boot". Make sure your primary SATA drive 1 is listed in the boot order. Save & exit the bios. (SATA drive 1 must have windows installed on it).
Link to Asus P5B web site;
http://support.asus.com/download/download.aspx?modelname=P5B&SLanguage=en-us
Good luck rafiqbrush!
Thank you for using fixya.
Mike
Dec 10, 2008 | ASUS P5RD1-VM Motherboard
Raid sys on p5k/epu
You are correct. The Asus P5K does support SATA RAID configuration. Page 4-14 in the user manual.
Congifuration [Enhanced]. Only real option is IDE. That does not mean the SATA drives will run like an IDE. The SATA's will function faster. In order to get RAID function you would need to have bought the Asus P5K Deluxe. http://support.asus.com/download/download.aspx?modelname=P5K%20Deluxe/WiFi-AP&SLanguage=en-us
Mike
Jun 06, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Help!
Have you installed RAM? If not the machine will not boot. You may also need to enter the BIOS setup to set the CPU and DRAM voltages and multiplyers etc. Follow the instructions in the manual for setting up the CPU info in the BIOS. Are you sure your PSU has enough guts to run the setup? Many times have i seen setups fail because a cheap power supply has been overstretched.
Jun 14, 2007 | ASUS P5B Deluxe/WiFi-AP (P5B DELUXE /WIFI...
ASUS P5B Deluxe/WiFi-AP Motherboard Logo
298 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
