Question about Abit KN8 SLi Motherboard
No boot i have this motherboard abit kn8 sli in my computer i replaced the msi 6600 vga with an xfx 9800 gt worked fine for a while then quit so i rma ed the card and got a new one "same card" and i still get nothing its like the board will not boot nothing but black screen and the screen stays in standby. i have checked every connection but dont know what else to do please help me.
  • eddie king Feb 07, 2009
    just got done trying this but still no boot, the monitor still stays in standby when you turn the computer, on also changed out the ram "pc3200"1 gig xms with a stick of Adata from my other computer "Also pc3200"1 gig and no luck. Also changed the monitors out with the one off my other computer , no luck and the last thing i tryed was putting my old card back in but no luck there. i feel it all started when my old monitor would stay in standby and the led on it would just blink. i thought it was just time for a new card, but when i first replaced the card and the drivers it ran for about 2 months on the the first xfx 9800 gt then went back to this problem of the blinking led ,then i bought a new monitor , before it got here i hooked the computer up to my other lcd monitor and it worked fine, the next day i pushed the power button the monitor would not come out of standby. i have tryed everything that i know but nothing works even rechecked all connections.
  • eddie king Feb 08, 2009
    fixed it it was the 4 pin molex that connects to the mother board at the bottom the yellow wires pin had backed out just enough where it looked like it was plugged in snugly, was going to check the psu out with my tester and it showed up not lighting up on my tester lol but thank you for your help and ill tell my clan about this site
    THANKS
    #GST#GHOST
  • 64 Answers
If you had received a cd with the card that contains drivers i would replace the old vga card and, assuming it boot s okay, load the CD. after this shut down, swap cards, then reboot.
Posted on Feb 07, 2009
Red light on motherboard , power comes on but computer dont boot up
Sounds like you connected your front panel wrong. check to make sure all of the connectors on your board on where they need to be.
May 14, 2010 | Abit KN8 SLi Motherboard
What is the fastest CPU I can run on an Abit KN8 SLI socket 939?
Your mobo rans in Athlon 64 socket 939 compatable processor. The fastest processor there is that you can install in this mobo is AMD Athlon64 4000+ Socket 939 Processor. =)
Apr 30, 2010 | Abit KN8 SLi Motherboard
No signal problem with xfx 9400gt fatal1ty
Check for bios jumper set for normal operation, check for onboard vga jumper set for pci or external video.
Jul 14, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Abit kn8 sli motherboard won t boot up
PULL OUT THE WIRE FOR A POWER SWITCH ON THE BOARD AND TRY TO SHORT BOTH PINS WITH A SCREWDRIVER
Oct 17, 2008 | Abit KN8 SLi Motherboard
Blank screen at boot up
Sounds like you need a new motherboard how old is his computer but, before you start looking for a new board try resetting the main board jumpers maybe that will get it to work and if there are no jumpers remove the battery from the motherboard this does the same thing.
Jun 02, 2008 | Abit Fatal1ty FP-IN9 SLI Motherboard
No signal to monitor when booting.
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Apr 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
No keyboard function
if you do it so i can provide u some smd level tips
1.remove near by keyboard 8 leg serial pf module and check
2.if problem not solve so check black small smd fuse near by keyboard connector
3.if problem can't solve replace I/O controller ic
problem will be solve 100 %
Feb 29, 2008 | Abit KN8 SLi Motherboard
Motherboard ABIT KN8
i dont know about the red light, but all main boards these days have a built in protection if the cpu fan quits. check the cpu fan connection, ensure that it and the heat sink are dust free. if still no go. update  your question with exact info..e.g. does absolutely nothing.. how many beeps you hear..how long b 4 it dies.. final note: be careful what you touch.. static can harm more that most think and the oil from touching can retain heat.
Oct 29, 2007 | Abit KN8 Ultra Motherboard
Abit KN8 SLi Motherboard Logo
302 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
