Question about Linspire Five-0 for Linux
APM-BIOs not found , mor issues cant afford ur premium service
Have linspire 5.0.59 downloaded undutu per a recommendation here at your site , but linspire said it cannot open it , it was a .ISO format
ran a redect command upon booting and saw some lines and here is what they say
IDE-DISK not found
Problem Inserting IBM-ACPI
APM BIOS not found
Error could not start Jack Server
XML Parsing: no element found
is there a way to restore my PC to over come all this
thank you
2 Suggested Answers
SOURCE: apm bios not found and other issues with linspire
i ran driver detective to update my gateway notebook drivers to have sound,but no luck doing that.It say that i should i should put in the registry key for driver detective.Where is the registry key located or how do i obtain it?
Posted on Feb 06, 2009
Any website that offers Affordable & Eye-catching
Hello and Welcome to FixYa!
I've been using this site. The got a good collection of Free as well as paid CSS templates.
I'll recommend you to switch to Joomla. Its much more advance and you can find extremely cool and steady templates for joomla.
If you need any more help regarding this do tell me.
Concerned, Nooh
Aug 03, 2011 | Computers & Internet
How to update my bios?? when installing vista/7 it says that ur bios is not fully acpi compitant
  1. try to load BIOS defaults and disable the APM
  2. if that doesn't work, you mihgt want to try removing the RAM module and then placing it back again.
Oct 02, 2010 | Gateway 200 ARC Notebook
Nec versapro nx series
there are BIOS flash available for the laptop, (www.nec-driver.com) download the required Bios Update for your Laptop (based on the model number). this should fix the password problem. second option is to remove the Bios battery but since it is a notebook, not recommended. :)
Mar 31, 2010 | NEC Versa Premium Notebook
Ell 360 optiplex is not shuting down what is the problem
If you are under MS Windows XP, and after you shut down the machine it hangs at the screen stating "It is now safe to turn off your computer" than this may fix your problem:
This issue arrises when you have a computer that supports Advanced Power Management (APM). By default APM is not enabled in Windows. If the BIOS on yoursystem is set for APM, and you upgrade to Windows XP, you will receive the "It is now safe to turn off your computer" message when you shutdown at which point the computer stops responding.
To fix this issue:
  1. Click Start, and then click Control Panel.
  2. In Control Panel, click Performance and Maintenance, and then click Power Options.
  3. Click the APM tab.
  4. Check to select the Enable Advanced Power Management Support check box, and then click OK.
Jan 04, 2010 | Dell OptiPlex GX260 PC Desktop
Windows will not turn computer off. I have unpluged every thing and all fans but the hard drive. I get 0.01 dcv when the computer is running and the same when I try to have windows turn the computer off....
This usually happens if Windows is having trouble closing a program. The easiest way to avoid the problem is to close all programs before you close Windows.
If that does not help, you need to track down which program is causing the problem.
If you are running Windows 95, remove all shortcuts from your StartUp folder.
If you are working with 98/ME/XP, uncheck all the programs listed in StartUp in the System Configuration Utility (you get to the utility by opening Start/Run and typing "msconfig" without the quotes in the Run box and then clicking on OK).
Shut down the PC. Reboot. Shut down again.
Then add one program back, shut down, reboot and shut down again.
If Windows shuts down as it should, add a program back to StartUp and repeat the shutdown, reboot, shutdown routine. Do that until you have pinpointed the errant program and reinstall it. If you are running a screen saver, consider it also to be a prime suspect.
Your Advanced Power Management, or APM, utility has decided to take leave of its senses.
Disable it, both in your BIOS file and in Windows.
That little sound riff that accompanies the shutdown is hitting a sour note.
Go to Control Panel and click on the Sounds icon to open the Property dialog box.
Scroll down in the Events box until you see Exit Windows. Change the sound settings to None.
Your TEMP folders are bulging at the seams.
If the C:\Windows\TEMP folder gets overloaded, all sorts of bizarre events can ensue. Clean it out. While you are at it, clean out your Temporary Internet Files folder as well.
Updating XP with the latest Service Pack may also cure the shutdown failure.
However, it is also possible that Advanced Power Management, or APM, is getting in the way of the shutdown routine.
APM may not be enabled in your XP configurations, but it may be turned on in your BIOS, a memory-resident program that controls how your PC sets itself up.
Microsoft recommends that you go to the Control Panel, click on “Performance and Maintenance,” and choose Power Options.
Click on the APM tab and click on Enable Advanced Power Management Support.
Personally, I don’t like automatic power management on desktops because it can cause all sorts of bizarre behavior. I would leave Advanced Power Management disabled in Windows and turn it off in the BIOS.
Consult your PCs manual to determine how to enter BIOS’ Setup file. Sometimes, as the PC boots, you can see a message on the screen that tells you which key to press to enter Setup. Press it before the screen welcoming you to Windows appears.
Once in Setup, look through the various sections until you find the option for controlling power management. Choose to turn it off.
For guidance on other XP shutdown problems, consult article 308029 in the Microsoft Knowledge Base. Use the article number as a search term at the support site below. Good information is also available at the aumha.org site.
Regards.
Aug 27, 2009 | Computers & Internet
I have Dell inspiron 1525 laptop with windows Vista home premium
go to bios setup n change sata driver to ATA from AHCI n  also disable da flash play module
Mar 18, 2009 | Microsoft Windows XP Professional for PC
Apm bios not found and other issues with linspire
Feb 05, 2009 | Linspire Five-0 for Linux
Optiplex 560 Power Intermittent
Try updating the BIOS. Seems there were some advanced power management improvements.
Dell Downloads
The following changes were made to the A04 BIOS for the A06 BIOS: 1) APM issues device commands in SMM. 2) Fixed APM to issue power up/down commands to peripherals in SMM. 3) Turbo/Deturbo switching done in SMM. 4) Implemented <\> Turbo/Deturbo hot key. 5) Password checked after exiting Setup and before OS booting. 6) Fixed the problem with #9 GXE64 Video card losing its video at the end of POST. 7) Fixed the problem with WINICU having General Protection Failures. 8) Fixed the problem with Real Time Clock not being updated correctly when in Power Managed mode.
May 15, 2008 | Dell OptiPlex GX260 PC Desktop
Linspire Five-0 for Linux Logo
175 people viewed this question
Top Linspire Computers & Internet Experts
David Payne
David Payne
Are you a Linspire Computer and Internet Expert? Answer questions, earn points and help others
