Question about Logitech WingMan Formula Force GP (9632210914) Wheel
Can't use steering wheel on F1 2002,it's been awhile since I've p
Trying to use steering wheel on F1 2002, bwn awhile since I used the wheel and it's worked before, but now won't.
    Problem Solver:
  • 5 Answers
Specify pleaaase !
Posted on Feb 08, 2009
2007 ford taurus w/ locked steering wheel and car won't start
try pulling the steering wheel slightly to one side and turning the key to unlock the steering wheel
Jul 28, 2013 | Cars & Trucks
Tip
Chevrolet Truck Steering Wheel Removal Instruction
1 Turn the steering wheel from side to side until it locks into place. This will make the process a bit easier, as the wheel won't be turning as you work.<br /><br />2 Remove the horn button in the center of the steering wheel by pulling it off towards you. This will expose the steering wheel nut at the center.<br /><br />3 Unbolt the center bolt from the steering wheel, using the 1/2-inch ratchet, extension and socket. This might free the steering wheel right away, but most likely you'll have to proceed to the next step.<br /><br />4 Position the steering wheel puller on the steering wheel such that the center bolt on the puller is on the center shaft of the wheel. Then thread in the bolts supplied with the puller into the two threaded holes on either side of the center shaft on the wheel.<br /><br />5 Tighten down the center bolt on the steering wheel puller using the 1/2-inch ratchet and socket until the steering wheel pops free. Then remove the steering wheel puller from the steering wheel.
on May 28, 2011 | Chevrolet 1500 Cars & Trucks
Ignition key won't turn
Try turning the key while jerking the wheel left and right and depressing the brake pedal. If that won't work try another key.
Oct 17, 2017 | 2002 GMC Sierra 1500
Remove steering wheel from Sportcraft center console boat
Is your steering using the cable / pulley and springs, or has it the through the tube steering? If it's the later, undo the nut that holds the cable to the transom bracket, Then try and turn the motor, If the motor won't budge, the pivot is seized, If the motor moves, your cable is seized or the steering box needs help! How to remove your steering wheel, There will be a cover hiding the nut in the centre of the wheel!
Feb 15, 2012 | Boating
Steering wheel is locked on my 95 ford f150 xl..it starts and goes into gear but the steering wheel won't move..it is locked
you can break the lock by pulling down on the steering whell very hard. or if your ignitons swith is bad you have to get a new one
Nov 13, 2011 | 1995 Ford F150 Styleside Regular Cab
Key won't turn in ignition
On many vehicles, the key locks the steering wheel. If the wheel is turned, it can keep the key from turning. While trying to turn the key, push the steering wheel hard to the right and if that doesn't work, push the steering wheel hard to the left.
Gary
Sep 30, 2011 | Cars & Trucks
Have a 1997 buick skylark and my ignition key will not turn and the steering wheel is lock. what can I do?
if the wheels are turned you can try to remove the pressure on the steering wheel by turning the steering wheel just a little and then try turning the the key.sometimes when there is too much pressure against the steering the key won`t turn,if this is the problem.you also can try to use another key as if the one your using is worn enough it may not turn and another one will.if neither of these suggestions will work then you may have to replace the ignition key switch and keys.
Jul 04, 2011 | 1997 Buick Skylark
My steering wheel locks up when I put it in park, and when I try to restart it, it won't crank. The key won't turn. What do I need to do?
grab the steering wheel and turn it left or to the right and sometimes you might have to put a little effort in it but one way the steering wheel will move about 1-2" and as you are moving it with one hand take the other hand and turn the key and it should turn a lot easier.this is a common thing and if you can try to have the wheels straight and try not to use the steering wheel to get in or out of the vehicle and the wheel should not lock and make it so hard on you.you have to use both hands at the same time one moving the wheel and the other one turning the key but start moving the wheel in the in direction that it moves the most then turn the key.
Jun 17, 2011 | 1999 Toyota Sienna
How do you take the steering wheel off of a 1986 chevrolet c10
1. Turn the steering wheel from side to side until it locks into place. This will make the process a bit easier, as the wheel won't be turning as you work.
  • 2 Remove the horn button in the center of the steering wheel by pulling it off towards you. This will expose the steering wheel nut at the center.
  • 3 Unbolt the center bolt from the steering wheel, using the 1/2-inch ratchet, extension and socket. This might free the steering wheel right away, but most likely you'll have to proceed to the next step.
  • 4 Position the steering wheel puller on the steering wheel such that the center bolt on the puller is on the center shaft of the wheel. Then thread in the bolts supplied with the puller into the two threaded holes on either side of the center shaft on the wheel.
  • 5 Tighten down the center bolt on the steering wheel puller using the 1/2-inch ratchet and socket until the steering wheel pops free. Then remove the steering wheel puller from the steering wheel.
  • May 28, 2011 | 1986 Chevrolet C1500
    Logitech WingMan Formula Force GP (9632210914) Wheel Logo
    332 people viewed this question
    Top Logitech Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    Alun Cox
    Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
