Question about Pico Macom Ecamm Network iMage USB Webcam for Mac and Windows
BLACK IMAGE ON SIGMA VIMICRO WEBCAM
I have downloaded software numerous times but the image is still black and there is no light on the webcam like it is not on....the microphone works though. I have tried to download software from Vimicro website but wont work...am I doing something wrong?
If you have zista i have the same problom it is because it is not capabital with any higher than xp
Posted on Aug 15, 2009
How to turn on my built in ebcam
Many Toshiba laptops, including Satellite, Portege and Qosmio models, feature built-in Chicony-brand webcams. The Chicony webcam can be problematic, especially when running a 32-bit version of Windows Vista. Microsoft has released an update that will correct problems with starting the webcam after terminating "Sleep" mode. Users may also have to install the appropriate driver or webcam software to correct webcam problems.
Dark or Black Webcam Image Problems b> Toshiba laptop owners may have problems with the webcam displaying as dark or completely black a few seconds after the initial image appears or immediately after engaging the webcam. Users should ensure that the webcam indicator light is engaged. If not, users should run the "Camera Assistant Software" to turn on the webcam. Low light can cause the webcam to power off and to display a dark image. Users can tweak the light and contrast by manually increasing the lighting in the room or by turning on "Night Mode." If these steps do not correct the dark image problem, users may have to reset the webcam itself, reinstall the "Camera Assistant" software. b> Webcam Problems After Terminating Sleep Mode b> Toshiba laptop owners with Windows Vista (any 32-bit edition) installed and the Chicony webcam may have problems starting the webcam after restoring the laptop from "Sleep" mode. "Sleep" mode powers down a number of hardware components in the laptop. The webcam is capable of entering a non-operating system-induced sleep mode when it is not used for an extended period of time. After the user engages Windows "Sleep" mode and wakes the laptop, the webcam may give error messages such as "Locked by another application." This webcam problem can be corrected by installing a Windows Hotfix, which is also included in Vista Service Pack 1 (SP1). Webcam Problems After Upgrading Windows Vista
Toshiba Satellite laptop owners may opt to use the Microsoft Anytime Upgrade to upgrade to Vista Ultimate. After doing so, the Chicony webcam may stop working and report a "Please turn on the camera" error message. Users can correct this problem by reinstalling the Chicony driver. b> Webcam Problems on Linux b> Linux users who own Toshiba laptops with the Chicony webcam should install the Linux UVC Driver to make the webcam functional. The webcam may not work without this driver. b> Grainy or Blurry Webcam Image b> The Chicony webcam can produce grainy or blurry images if the user does not remove the protective film that covers the external webcam interface.
http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions this will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps
b>
Jan 20, 2013 | Toshiba Satellite Computers & Internet
I have a Toshiba Satellite P205-S6237 with a built-in Chicony USB 2.0 camera, I cant get it to work, need help
Hope this helps
Nov 15, 2012 | Toshiba Computers & Internet
Web camera not working
Hope this helps
Nov 15, 2012 | Toshiba Satellite L505-S6955 (4400 mAh)
Its just black no image
heres an app that will work to solve your problem.. go here http://splitcamera.com/download.html , download the software, run it, choosse video then choose your webcam ... try to use skype with split camera opened it will surely work and now you can change your cam view f you wantwith images, video or desktop view
www.ziggy-links.com
Dec 14, 2009 | Microsoft LifeCam VX-1000 Webcam
If i use my webcam it only shows black image
make sure in the webcam setting you have choose the right webcam. all depend what messenger you using. do a webcam test in the messenger you using
Jul 14, 2009 | A4tech PK-635 Webcam
Loaded software for my Vimicro webcam and I get a black screen
Normal 0 Double Click on this site
http://www.free-codecs.com/AMCap_download.htm
to download the Free AMCAP Video Capture Program.
AMCap v9.20 AMCap is a small yet fully functional video capture application compatible with Microsoft DirectShow. It is based on the sample AMCap from the Microsoft DirectX 9 SDK. AMCap supports still captures to BMP, JPEG and PNG formats and it remembers your Video Input, Video Standard and Video size settings from previous session. It has some nice features like multimonitoring support, zooming, aspect ratio and deinterlacing features.
AMCap is a small and effictive piece of software and definitely worth trying. Hope this will help. Bud
Jan 15, 2009 | Computers & Internet
Logitech QuickCam Communicate MP - black screen
  1. Either one of these image sizes:
    • Small image size: 160 x 120
    • Large image size: 320 x 240
  2. RGB, I420, or IYUV formats. (Each is fine; we recommend RGB 24.)
  3. Microsoft DirectX version 9.0
To get this information, click here to download a Microsoft application that checks to see if your webcam device meets these requirements.
To make it easy, when you’re asked where to Save the program, just save it on your Desktop.
Once it’s downloaded, here’s what to do:
  1. Double-click the amcap.exe file on your desktop.
    • If you have more than one webcam installed, click the Devices menu and select the one you want to use.
  2. Click the Options menu, then click “Video capture Pin.”
  3. Under “Color Space/Compression:”, choose one of the following formats:
    • RGB 24 (our recommendation)
    • I420
    • IYUV
    Note: If one of the options above isn’t in the list, then your webcam is not compatible with Yahoo!7 Messenger.
  4. Under “Output Size”, choose one of the following:
    • 160 x 120
    • 320 x 240
  5. Click OK
  6. Close the ampcap application.
  7. From your desktop, click ‘Start’ and select ‘Run’.
  8. In the run box, type: dxdiag
  9. In the confirmation dialog box, click OK.
  10. On the System Tab under ‘System Information’, look for DirectXversion. Verify that your version is DirectX 9.0. If it is, just click Exit. If your version is older than 9.0 (any lower number), click here to download the latest version of DirectX.
  11. Start the webcam from Messenger by clicking My Webcam in the Messenger menu.
Attention Logitech webcam users:
Some Logitech webcam drivers may cause one of the following problems:
  • Windows freezes when accessing the webcam
  • A black screen appears when using the webcam in Messenger
  • A ‘Webcam not found’ error message appears.
  • After 3 seconds, the sound drops out of calls made via Messenger
If you already verified that your device is compatible through the above steps and you’re a Logitech webcam user, please click here to update your Logitech webcam driver.
Dec 16, 2008 | Computers & Internet
Can't see me during night time even there's is light
Several factors determine onscreen size of a video image produced by a Webcam. The actual Webcam hardware may be limited to a maximum resolution. The percentage of your screen filled by a Webcam image will be a factor based on your desktop resolution and the maximum resolution of the Webcam image. A third factor impacting image size is available bandwidth Webcam software may also play a role in determining image size, but in most cases the software is only limited by the Webcam output. There are several ways to optimize your results to make sure you send a Webcam image viewable at the highest resolution acceptable to relatives on the other end, while also optimizing your system to maximize available screen real estate with inbound images from relatives.
Webcam hardware is often a big limiting factor in determining maximum image size. Most Webcams on the market today output a maximum 640x480 image, which easily fills a television screen. Any of the Webcams currently available from Logitech, Creative, Apple, D-Link or the numerous niche companies marketing Webcams will support 640x480, although some produce better results than others. If you have a Digital Video camera capable of doubling as a Webcam, you may get a 720x480 maximum image size. Apple's iSight camera and some of the higher end Logitech cameras using CCD instead of CMOS image sensors produce excellent images at 640x480 in well-lit rooms.
Knowing 640x480 is the maximum image size, don't expect incoming video to fill your screen if you have your resolution at 1024x768. The graphic below is shows the relative portion of a 1024x768 screen filled by a 640x480 image at 50% of actual size. If you want the incoming video to fill your screen, reset the resolution of your monitor to 640x480 to properly accommodate the incoming video feed. This assumes your relatives are capable of sending 640x480 video from their end. If their sending limitation is 320x240, the best you can hope for is a video filling 50% of your 640x480 screen.
Nov 23, 2008 | Logitech QuickCam Express Web Camera
Webcam driver
i got aproblem with my webcam cause windows vista is aproblem to get it its black the image.... and i dont know to get it fix its new the cam a genius...
May 04, 2008 | Creative Labs WebCam Live!
Pico Macom Ecamm Network iMage USB Webcam for Mac and Windows Logo
220 people viewed this question
Top Pico Macom Computers & Internet Experts
David Payne
David Payne
Are you a Pico Macom Computer and Internet Expert? Answer questions, earn points and help others
