Question about Biostar P4/DDR/FSB 533/A&V&L/ATA133/MATX (U8668D) Motherboard
Bios place sent me the biostar mother board bios model u8668p
  • 70 Answers
It looks like there are several versions of the board you are asking about, but the link below will let you select the right one and get the files you need:
http://www.biostar.com.tw/app/en-us/support/download.php
Posted on Feb 07, 2009
Bios password is lost need to reset bios on fujitsu
hai plz check mother board bios jamper on board remove pin ok on pc 1 min after add pin same place setting are restored..
Oct 25, 2013 | Computers & Internet
Bios password fujitsu T4210 don't know password so I need arc e prong on bios
Hai plz check mother board bios jamper on board remove pin ok on pc 1 min after add pin same place setting are restored..
or down load
http://www.hiren.info/pages/bootcd insert cd restart pc min xp open remove bios password.......
I want to break my bios password.
if you are using a desktop computer you can reset *********** board settings by removing the battery or by connecting the jumper setting but to do this you need the manual of the mother board. you need to find the exact place where to connect the jumper. if you are using the laptop there is no way you can reset the motherboard of the laptop. some people use a program just to reset the bios settings but for it is quite dangerous. because it might damage the bios program in the mother board.
May 02, 2011 | Computers & Internet
Usb ports not working
buy a new mother board or use recovery media after saving files and clean out usb ports
Jun 13, 2009 | HP Pavilion dv9000z Notebook
Cd for BIOSTAR BI8600GV Intel 865 chipset mother board lost
http://www.motherboard.cz/mb/biostar/P4TSV.htm
I think you will find all you need there ...look carefully to be the exact same model if you want to flash the bios...otherwise its safe
Apr 08, 2009 | Biostar P4TSV INTEL 865G Motherboard
I lost my mother board driver disk. mother board model D915GAV
If this board was manufatured by intel then you can go to www.intel.com. Click on the support link and lookup your board model #. All drivers/bios files that are available will be listed there and available for free download. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 08, 2009 | Intel Motherboard
Bios flash
firstly i want to tell you that every motherbord bios has a unique program to control the devices.
it this bios is fit on another board casing then you try to firstly run the mother board with old bios. then copy the bios code by any flashing tool and then remove this bios and fit the dead mother board bios in the casing then flash it and then update it which file you copy the old one.
then your motherboard perhaps go on with the dead motherboard bios.
thanks
ramesh
Oct 16, 2008 | Intel D865GBF Motherboard
Lost mother board drivers
When you first load the PC get ready to press the Pause key. As soon as you get display press the pause key. You should be able to see the Name & model number of your board. Write that down & post that information here. Or is the name "Mercury" & the model " PVCLE266"? This is listed on you're post above the statement " Lost mother board drivers"? If you are able to get into you're bios's main menu. Some bios's list the model number under system information.
May 17, 2008 | Mercury PVCLE266 Motherboard
No display when i turn on pc
so..let me see..you have 2 mainboards,two video cards.one preocessor and rammsso you have quite some possibilities.
fisrt of all I have to say that just clearing the bios is not a solution..would be better to update it,by downlaoding it from the manuufacturers site and after you made a bootable cd than under dos mode re write the bios..
however you cant see anything without a propper signal with new motherboard.
take the new mother board..
so..chech the rams.if you have more ramm dimms let only one in the board but be sure is the one near the proccesor slot and check it to be well inserted.
-put the video cards first the 8500 one,see what it happends.like an observation:if the hdd is damaged the computer runs showing you the dos mode/you are able to reach the bios
processor damaged-computer can run/blue screen with some infos/it is note  a rule that you can reach the bios
ramms distroyed or put wrong..computer starts/dos mode/able to work in bios
video card damaged -NO SIGNAL AT ALL
moather card damaged-No signal at all.
so think and pay attebtion to the details of the errors.
You can make different tipes if combinations and by elimination youll discover the faulty component.
from now I can only presume is the new mother board
good luck .its a booring work but is nothing you can do more
bye bye
Feb 06, 2008 | Abit IN9 32X-MAX Motherboard
Asus mother board bios
what model is your motherboard? try searching for it on the internet. What is the symptom on the motherboard now? Is it accessible ang operating? Let me know so that I can help you further. Goodluck!
Sep 17, 2007 | Intel Motherboard
Biostar P4/DDR/FSB 533/A&V&L/ATA133/MATX (U8668D) Motherboard Logo
82 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
