Question about Samsung SW62ASP Top Load Washer
Error "dE" on Samsung toploader SW52ASP/SW62ASP
Worked fine for first load, then gave this error everytime I tried doing a cycle. all filters are clean...is there a fuse blown somewhere?
Wolfman304
  • 720 Answers
SOURCE: I have a Samsung SW62ASP top load washing machine.
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution
Posted on Dec 03, 2009
  • 327 Answers
SOURCE: Error on screen if load bigger - DE
Hello,De error refers to "Door Error".
You do not need to buy a new machine. You can fix this.
Look at the below mentioned link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
Thanks
Posted on May 24, 2010
  • 327 Answers
SOURCE: de1 error message on Samsung front load washer
No doubt the above page is for "LG", However it's the basic and would remain the same for all models and machines whether that's GE, LG, Samsung etc....
Thanks
Posted on May 31, 2010
I have the same problem with my Samsung. Did you solve it?
Posted on Dec 22, 2010
ginko
  • 19396 Answers
SOURCE: samsung vrt steam Brand new first load
Hi.
You need to check the drain filter located in front of the machine at the bottom, behind a trim panel or a service door. If the problem occurs again the machine is faulty and must be repaired. Parts such as drain system, drain pump, pressure switch and control panel may be responsible for drain problems.
Check the position of the drain hose. Ensure that the height is as specified by the manual or you get siphoning and drain does not end.
Access the drain filter. With most front loaders this located in front at the bottom in a corner, there should be a trim or an access panel.Top loaders have an access panel at the back, or more commonly the pump is accessed from underneath, bending the appliance on one side and securing it.
The machine has a pressure switch. It is a sensor connected to a long thin rubber hose. The pressure switch is often in control assembly. Clean the hose and the switch. One way to test the pressure switch is by blowing into the switch, but manufacturers say this must not be done as you can damage a good switch.The pressure switch is difficult to test in full. Testing is done either reading voltages while machine is working or reading Ohms at the switch with tub empty and full. For safety reasons I suggest users to avoid performing tests or maintenance that must be done with power on.
Here a page about drain/spin problem.
Start checking drain hose and drain filter. If machine is a front loader the drain filter access is located behind the door at the front bottom side of the machine.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Posted on Sep 09, 2011
My 8kg toploader is only agitating one way how do i check the agitator gear box is there something causing this ?
its called a brake arm white thing under neth the machine with an arm hooked on to some thing its not the gear box
Jan 17, 2013 | Samsung SW62ASP Top Load Washer
Iasked hpw to fix my Samsung SW52ASP washer with error code dE and was supplied this link to the fix. The link doesn't work and I cannot find a place to contact anyone. Can you assist please? This is...
Here is the solution direct ;-0)
'dE' stands for 'door Error' indicating that there is a problem either with the lid lock or the lid locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 15, 2011 | Samsung SW62ASP Top Load Washer
My washing machine stops working, it shows 'dE' everytime i try to start a cycle, and i dont seem to be able to find out what it is... please help
DE MEAN'S DOOR ERROR,There is a little magnet that detects if the lid is open or closed & this magnet always falls off into the machine then pumped away. (If it gets past the pump with out jamming it).you can't just buy the magnet you have to buy a whole new top & most of the time this cause's the computer to fail as well,So it could end up costing a fortune even up to the amount you could have bought a new one my advice get rid of the samsung & buy a new lg the sooner you do that the sooner you start saving money in washing machine repairs.
Feb 25, 2011 | Samsung SW62ASP Top Load Washer
Doesnt dry shows dE when you put it on make anoise as if it to drain water plz help
dE = drainage error,
empty the filter, check pipe outlets are clear , check the pump
Thank You
Sep 10, 2010 | Samsung SW62ASP Top Load Washer
My Samsung WA75b9 toploader stops when the rinse cycle starts -makes noise but won't rinse or spin!
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 14, 2010 | Samsung SW62ASP Top Load Washer
Thanks
May 24, 2010 | Samsung SW62ASP Top Load Washer
De error code on samsung topo loader stops working
0E - OVER-FLOW ERROR
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 28, 2010 | Samsung SW62ASP Top Load Washer
My washing machine won't work.I keep gettting 'DE'.What does that mean?
Temperature sensor problem. Restart the load. Change settings on washer and test.
Aug 12, 2009 | Samsung SW62ASP Top Load Washer
Machine stops with SE code
That code (5E, not SE) means the drainage is clogged. The code appears after 15 minutes of trying to drain the tube (not sure that´s the word, may be turbine, barrel...). check the lateral filter (a big plastic twist-off cap) for any solid that may be clogging the drainage
Jan 16, 2009 | Samsung SW62ASP Top Load Washer
Samsung SW62ASP Top Load Washer Logo
395 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
