Question about E-Machines D2046 PC Desktop
Replaced dead power supply computer still dead
D2046 emachine,put in new 360w power supply with 20 pins.when try to turn on, the power button and fan on cpu flash and move a split second then nothing.noticed that the 20 pin connector only has 19 wires to it,is it suppose to have the full 20? could my motherboard be bad?
  • larrynels02 Feb 07, 2009
    I disconnected everything from psu except motherboard and pc still wont boot up.Is my new psu missing a wire? it only has 19 wires for 20 pin connector.on my old psu has 20 wires for the 20 pin connector and its showing a white wire where new psu has no wire connected.my old psu was bestec atx 250-12e.new psu is a 360w Works v365cn4.if its motherboard can any mb work for D2046 emachine windows xp pro?
    Problem Solver:
  • 11 Answers
Hi
most power supplys are protected against faults when they are connected to damaged equipment
so it possibly just protecting its self
disconnect everything from the PSU except your MB
try to turn on
if your pc boots ok
re connect everythng else one thing at a time attempting to boot each time
when it wont boot you have found your fault
Posted on Feb 07, 2009
  • Robert Lee Feb 07, 2009
    Hi
    if you follow this link
    http://www.helpwithpcs.com/courses/power...
    and scroll down a page or two
    you can see that the white wire is a -5vdc supply and should be there!!
    cannot find any information for the "360w Works v365cn4" PSU
    do you have any more details?
    as for replacing the MB the emachine site shows that the D2046 has a Celeron Processor 2GHz so a MB that will take this processor should be OK
My emachine desktop tower will not power on
the sound you are hearing or heard could have been power surging through a powersupply unit that just blew.. hopfully it did not effect any of the other hardware..to trouble shoot this you can do one of two things..1 disconnect the 20/24 pin powerconnector from the motherboard 2 disconnect the cpu power connector 3 disconnect the 6pin power connector from the graphics card if there is one some machines have onboard video chipsets if thats the case then no worries 4 disconnect the Harddrive power 5 jump the power supply to see if you get any power from it any questions on that go to youtube and type in how to jump a power supply... or option 2 is buy a new power supply make sure its 80plus certified and replace it...i know its a lot of work but i hope this has helped you
Aug 26, 2012 | E-Machines eMachines Desktop PC
I have a emachines t2984 i press the power button and doesnt turn on i replaced the power supply with different ones and nothing and the light turns on (power button) but the when i press the button the...
Ok, test the power button pins. First disconnect any power source to the computer. Then, find the power pins on your motherboard (the one that your case's power button connects to. Usually two wires, one red and the other black). Grab a jumper a connect it to those two pins, they usually have the letters "pwr" or "power" printed next to them. Then, once you've done this, with the jumper connected, connect the power cord to your power supply. It should turn on by it self. If it does, then the problem is the power button. If it does not do it, then the problem is the motherboard. Good luck.
Jan 22, 2010 | E-Machines eMachines Refurbished EMA...
Nothing on my Emachines computer will turn on.
I would recommend rechecking your connection to the motherboard. All wires from the power supply to board and making sure the front panel switch connection are correct. Also, make sure the power supply is compatible to the motherboare. even though a 20-Pin ps will connect to a 24-Pin board, it still does not work. Good Luck
Franklin
C2Solutions
Aug 02, 2009 | eMachines D3415 PC Desktop
Wont power up
Helo,
If the power supply from your friends old computer may not fave all of the correct plugs to power up your computer. You system needs 2 plugs going to the motherboard one with 20 pins and one with 4 pins. Besure you have the correct plugs. The second thing to check is recheck the friendss power supply in another machine. Last option is that when your power supply overheated and died that it damaged your motherboard and you may have to replace it too.
Buddy
Corporate Computer
Over 21 years of PC and printer support/service
Jun 18, 2009 | E-Machines eMachines Desktop PC
Powerbutton connection wires were disconnected from motherboard
Look in the manual there is a diagram and pin connections for each wire.
Feb 06, 2009 | E-Machines D2046 PC Desktop
The cpu not on
You wil have to give me more details please
Oct 17, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Emachine flashing yellow lights, fans power up when P8 is unplugged
Did some research and found this site which will tell you which pins to test. It is possible also that its not powerful enough for the devices you have. I would try again only giving power to the motherboard pins, of coarse and the hard drive. If works then plug one device at a time.
Good luck
http://articles.techrepublic.com.com/5100-10878_11-1046822.html
Jul 05, 2008 | E-Machines eMachines Desktop PC
Computer
I would get the ezack one that came out of it and put that one back in. try it, the if it does not work I would replace the mother board
Mar 15, 2008 | E-Machines eMachines Desktop PC
W2646 crapped out
Some eMachines computers (like many from Dell) use a non-standard pin out for their power supplies, so if you try a standard ATX power supply it may not function.
However, in my experience it IS likely to be the motherboard. Luckly I have been able to replace quite a few of the eMachines mobos with a standard mATX mobo, since you can probably remove the IO plate. You'd certainly want to replace the power supply when doing so.
Jan 25, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Emachines problem... PSU works but comp doesnt turn on
Hi, Did you just add the second CD? If you did you may need the driver for the mother board? Make sure the power cord for the cd has voltage plug it into the DVD drive also check the cable make sure red stripe is on the correct side of drive. You can download the driver at http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T2672 User guide is there as well. The start button has a pair of wires with a small pin connector on it. This will connect to the motherboard if there is a 3 pin set you might try moving to the other pin. The new power supply also has to provide a start voltage? Your power supply may not be compatible or it may put the voltage on the third pin.
Aug 22, 2007 | E-Machines eMachines Desktop PC
E-Machines D2046 PC Desktop Logo
244 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
