Question about Epson Stylus Photo R300 InkJet Printer
Stops printing cd half way
When printing cd half way through job printing stops and the tray is ejected .I get a message saying cd tray not set properly.It asks for maintance . trird to run maintance all it did was waste paper and printed all kinds of letters and symbols. I have reinstalled software with no fix,reset printer no fix. any solution? I had my PC repaired recently because it lost the CD ROM. I have had this problem ever since.
  • cavebat Feb 10, 2009
    yes the arrows are aligned perfectly.
  • Stephen Siasico May 11, 2010
    on the cd tray there are arrows on it, is it aligned to the printer's arrows?
  • 55 Answers
It seems your printer cannot seem to recognize the CD tray. Purchase another CD tray. You can try compassmicro.com.
Posted on Feb 13, 2009
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Tip
HP LaserJet LJ 4350 locks up when duplexing
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
on Mar 17, 2010 | HP LaserJet 4350dtn Printer
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
My Epson Artisan 730 Printer keeps ejecting its CD/DVD Print tray, saying that there is a cd there. There, of course isn't. Can anyone help me? I really need to print.
My husband adjusted the CD/DVD tray, then we selected the icon that looks like a wrench on the printer's message window, then "restore default settings" on it. Turned computer off then on again, and it FINALLY started working again :)
Jan 14, 2013 | Epson Artisan 730 All-in-One Printer
Every time when printing there is a message MANUAL FEED, load paper and click continue
Please check your printer driver to see if the default tray is tray 2 or other than the manual feed tray and take the paper out of the manual tray.
May 03, 2011 | HP LaserJet 3200 All-In-One Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Acer desktop computer can not open cd-rom drive
try:-
1. select "my computer", right click on cd drive, and click on eject
2. switch off pc,then manually eject cd tray by inserting a strong paper clip in the small pin hole on the front of the cd drive,insert the clip for about 1.5 cm (half inch) in the pin hole and you will feel it press on a lever to open the tray slightly.
Apr 30, 2009 | Acer Power 1000 PC Desktop
Printer Jam - when i put a sheet of Avery labels, printer jams
When you say TOP TRAY, do you mean a paper drawer, or the BYPASS TRAY? If the labels won't feed into the bypass but bond paper does, check to see if your labels are made for inkjet printers. Go to www.avery.com and contact Avery customer support to see what product they recommend for your MFC. Labels made for plain paper printers sometimes do not work for inkjets, and vice-a-versa.
Aug 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
Printing CDs using the CD tray - now won't work
sometimes those cd label print papers are too thick..and need to fed in one at a time
Feb 25, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Error message "tray set up not correct"
I had the same problem. It's easy to fix.
Simply pull your printer away from the wall about 8". The tray needs to stick out from the back of your printer when it loads. If it hits the wall, it will not work properly and eject. Just try moving your printer forward enough so the tray can stick out from the back and you'll be fine.
RJP
Dec 17, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
157 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
