Question about Craftsman 17765 Canister Wet/Dry Vacuum
Craftman Canister Wet/Dry vac- Motor just stopped working
Is this motor even replacable? Should I just Invest in a new one and throw this vac away?
    President:
  • 1,990 Answers
It is Repairable But, The parts will cost almost as much as a New Vac. I would just get a New Vac and save the Hastle and the Cash. The choice is all yours Though. Please Rate My Response! Thanks!
Posted on Feb 07, 2009
I bought my first craftsman 9 gallong wet/dry vac - i do not know how to operate it and I don't want to break anything. I have a pamphlet but it is still confusing. can I pour a few gallons of water into...
Hello again.
When it says wet vacuuming, it means that the vacuum will pick up water, not dispense it. When you are using the vacuum to pick up water, you'll need to remove the paper filter element under the motor, inside the canister, to avoid ruining it. When the filter is removed, you will see a plactic ball inside a cage under the motor. It's purpose is to float up on the surface of the water being vacuumed up, and prevent the motor from getting water into it. You'll be able to tell when the canister is full; the noise the vacuum makes will change and sound higher. Also, the suction at the hose will quit. At that point, shut off the vacuum and drain the water.
Be sure to replace the paper filter when you swap back from liquids to solids.
Best regards, --W/D--
Apr 02, 2011 | Craftsman 17026 Wet/Dry Vacuum
My Shop-Vac 5870400 was working just fine, and then one day while i vac the floor its just stop working, tried to turn on/off a few times, swicth to different outlet. i did even tried to open it, but found...
Same thing just happened to mine. My solution is to get another one but a different brand. I think it should have lasted longer than four years of fairly light usage. From what I read, if it does as we both described, the motor is shot and not worth replacing.
Feb 18, 2011 | Shop Vac 587-04-00 Canister Wet/Dry Vacuum
Where to by replacement motor
you can buy a replacement vacuum for the same price as the motor on its own. I would recommend getting a new unit altogether as they are not very expensive to but but a fortune to fix. I have been in the vac business for 20 years and have a bit of knowledge on shop vacs and a new one is your best bet.....good luck
Oct 06, 2010 | Shop Vac 952-02-62 Hang Up Pro Canister...
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
Jul 16, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
Aug 02, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Craftsman 17765 Canister Wet/Dry Vacuum Logo
461 people viewed this question
Top Craftsman Vacuums Experts
downhille
Andrew Taylor
Andrew Taylor
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
