Question about Toshiba Portege 3440CT Notebook
No display when turn on the power theres no disply in the screen but i know that it s open because the lights is on can any one help me for this poroblem of mine
  • toneycute Feb 07, 2009
    i cant find the display button that youved telling....for the toshiba portege 3440ct model
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason for ur problem is the
display button.There is a display button
available on the top next to the power button.
Make sure that the display button is turned on,
if ur display button is turned off,ur displayscreen
doesn't appear.It will look black.
check this out..
thank u..
Posted on Feb 07, 2009
My cpu is front light on but not go to disply powr fan is ok runing but not show the disply plz help me any on
check the display monitor cord to CPU if attached perfectly/check on off switch of display screen
Feb 23, 2015 | Computers & Internet
Display problem
this may or may not help but it has worked for me many times in the past in a tight jam. good luck.
Apr 07, 2014 | HP EliteBook 2530p Notebook
Why does my computer screen keep going blank
Has there been any damage? Is the monitor disply timing out due to settings? You didn't post your OS, a Windows 7 solution: Open Control Panel, Power Options, set to High Performance, select Change Plan settings, set Turn off Display time, set Sleep to Never, set dim to 100% olugged in, select Change Advanced Power settings, scrool though and set Sleep and Hibernate to Never, Power Buttons and Lid to Shut Down, Display set to your preference. On battery your laptop will have default setting to conserve Battery power.
Apr 23, 2013 | Samsung NP-NC10-WAS1US Notebook
Phone screen lights up but no display
hi
there must be fault in hardware of your mobile.. kindly restart the phone and use it.if still have the same problem you should format the phone . if still some problem. kindly change the display screen of your mobile. there should be fault in display screen of the mobile. kindly change the screen this will able you to fix this problem
thank you
Dec 20, 2010 | Motorola Mobility i776 Cell Phone
I have use a mobile nokia 6630 but actully on mobile and no disply plesed saj what is the problem , disply , are disply (ic). mobile on uswe the mobile is the cotin working but no disply
The problem is from the ribbon that attach the screen to the main board of the phone, it is not properly connected that is why you do not have display. If the phone should have fallen, then the screen might be faulty. If it did not fall from you, then it means the ribbon of the screen is disconnected from the phone.
First, try to flash the phone, then you open it up carefully. And sit the ribbon that links the screen to the main panel of the phone properly.
And if that does not help, then you need to replace the screen of the phone.
Take care
Oct 13, 2010 | Cell Phones
Turn off clock on my phone.
Main Menu> Settings> Display & light settings> Display> Wallpaper> Choose images (this will just disply a small clock at the top) or choose "Use Theme" (this will let you choose what clock sort you want on your wallpaper (do this by choosing "Use Theme"> Save> My Theme> Select Theme> Chose one of the 3 themes))
DO NOT choose "Living World" as this will display a large clock
Hope this helps
Mar 26, 2009 | Samsung U900 Soul Cellular Phone
China mobile display problem
Disply problem in my china mobile TOP-1 (Super Music King). I have srcreen pin touch mobile. its working on all functions in mobile disply power is on. but disply not showing any function on mobile no. on screen. please help me. how i can solve this problem chsfoods@rediffmail.com
Sep 14, 2008 | Handmark Software MobileLists (950142) for...
Shutting off Filter Cleaning Message
you need to turn OFF the message function under the expert tab on the "on screen menu"
In the state of Power ON, press each key in the order of: HELP, UP, LEFT, HELP
Press the Menu Key to display the menu and confirm that Expert is displayed below the menu.
Once you go into Expert mode, go to the Expert2 tab in the onsreen menu and set the message to OFF.
Hope that helps.
Aug 19, 2008 | Office Equipment & Supplies
No Display On LCD in VP-D351 Samsung camcorder
hi ..had the same problem..had advice from this site two weeks ago..which was spot on..the lcd screen ribon has brocken.. its available from partmaster..www.partmaster.co.uk...part required..no SAMAD9706489A..£11.49.. took me half hour to take camera apart (carefull.y) 10 min to put back togerther.. works brilliantly.. good luck.. Need futher help email me..stefjanet @yahoo.co.uk..
Aug 15, 2008 | Samsung Compact MiniDV Digital Camcorder
LG LS50 SCREEN WILL NOT TURN ON
you need to resit your ram if the problem is not solved then your display adapter is gone, you have to send it for repair
May 19, 2008 | Computers & Internet
Toshiba Portege 3440CT Notebook Logo
237 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
